First i'd like to say i have this problem using both speakers or my headphones.
The volume i hear is deafening if i make it loud enough for stream to hear clearly. If i reduce the volume so it's barely not hurting my ears from how loud it is, it can't be heard in stream. No problem with mic.
I maxed out the OBS volume in Volume Mixer and in the broadcast option.
I have also tried messing around with the Audio Bitrate and nothing seems to help. I can either make it so i get deaf and people in stream can hear or where i'm not in pain but stream can't hear the game.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
CPU Speed: 2664MHz
Physical Memory: 2047MB Total, 1738MB Free
stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1176, 664}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GT 240
Video Adapter Dedicated Video Memory: 1026031616
Video Adapter Shared System Memory: 1471934464
Base resolution: 960x540
Output resolution: 960x540
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (2- Sennheiser USB Headset)
Using auxilary audio input: Microphone (2- Sennheiser USB Headset)
Audio Encoding: AAC
bitrate: 64
Using Window Capture
device: USB2.0 Camera,
device id \\?\usb#vid_1e4e&pid_0102&mi_00#7&2b088825&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, fps: 30-30, fourCC: 'YUY2'
Using directshow input
Using bitmap image
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264: profile High, level 3.1
Video Encoding: x264
fps: 45
width: 960, height: 540
preset: veryfast
CBR: no
CFR: no
max bitrate: 1850
buffer size: 1850
quality: 9
Total frames rendered: 6879, number of frames that lagged: 1019 (14.81%) (it's okay for some frames to lag)
x264: frame I:28 Avg QP:22.57 size: 28767
x264: frame P:3092 Avg QP:22.56 size: 2322
x264: frame B:3713 Avg QP:21.27 size: 66
x264: consecutive B-frames: 23.8% 9.6% 5.2% 61.5%
x264: mb I I16..4: 56.7% 15.6% 27.7%
x264: mb P I16..4: 4.4% 3.2% 0.3% P16..4: 7.7% 3.5% 1.6% 0.0% 0.0% skip:79.3%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 1.3% 0.0% 0.0% direct: 0.1% skip:98.5% L0:60.8% L1:37.6% BI: 1.6%
x264: 8x8 transform intra:38.2% inter:43.4%
x264: coded y,uvDC,uvAC intra: 29.9% 24.5% 8.3% inter: 2.2% 2.0% 0.1%
x264: i16 v,h,dc,p: 70% 22% 6% 3%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 27% 31% 1% 3% 3% 2% 3% 3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 22% 14% 6% 6% 7% 6% 6% 6%
x264: i8c dc,h,v,p: 70% 15% 12% 2%
x264: kb/s:402.55
Profiler results:
frame - [100%] [avg time: 14.504 ms] [avg calls per frame: 1] [children: 96.6%] [unaccounted: 3.44%]
| scene->Preprocess - [48.1%] [avg time: 6.977 ms] [avg calls per frame: 1]
| video encoding and uploading - [48.5%] [avg time: 7.028 ms] [avg calls per frame: 1] [children: 6.54%] [unaccounted: 41.9%]
| | CopyResource - [0.0827%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.324%] [avg time: 0.047 ms] [avg calls per frame: 0]
| | call to encoder - [6.12%] [avg time: 0.888 ms] [avg calls per frame: 0]
| | sending stuff out - [0.00689%] [avg time: 0.001 ms] [avg calls per frame: 0]
