From time to time audio in my recording is skipping few miliseconds.
It sounds like this:
(00:02sec and 00:30sec)
http://youtu.be/zvbXAoKPDA0
Here is full log file for this recording:
More info:
> Changing codec between MP3 and AAC does nothing.
> Increasing scene buffering time delays the moment when audio starts skipping. (Around 1min per 1000buff time).
> Force desktop audio to use video timestamps as base.. does nothing.
> Use mic QPC timestamps is enabled, when disabled it skips more frequently.
> Changing windows -> microphone settings -> format to match 48kHz does nothing.
It's a bit annoying.. Any idea how to fix it?
12:45:39: Open Broadcaster Software v0.60b - 32bit (´・ω・`)
12:45:39: -------------------------------
12:45:39: CPU Name: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
12:45:39: CPU Speed: 2672MHz
12:45:39: Physical Memory: 4095MB Total, 3352MB Free
12:45:39: stepping id: 5, model 26, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
12:45:39: monitor 1: pos={0, 0}, size={1920, 1200}
12:45:39: Windows Version: 6.1 Build 7601 S
12:45:39: Aero is Enabled
12:45:39: OBS Modules:
12:45:39: Base Address Module
12:45:39: 01200000 OBS.exe
12:45:39: 709C0000 OBSApi.dll
12:45:39: 731B0000 DShowPlugin.dll
12:45:39: 73480000 GraphicsCapture.dll
12:45:39: 73170000 NoiseGate.dll
12:45:39: 73190000 PSVPlugin.dll
12:45:39: ------------------------------------------
12:45:39: Adapter 1
12:45:39: Video Adapter: NVIDIA GeForce GTX 660
12:45:39: Video Adapter Dedicated Video Memory: 2086469632
12:45:39: Video Adapter Shared System Memory: 2147807232
12:45:39: Video Adapter Output 1: pos={0, 0}, size={1920, 1200}, attached=true
12:45:39: =====Stream Start: 2014-02-09, 12:45:39===============================================
12:45:39: Multithreaded optimizations: On
12:45:39: Base resolution: 1600x900
12:45:39: Output resolution: 1280x720
12:45:39: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
12:45:39: Audio Format: 48000hz
12:45:39: Playback device {0.0.0.00000000}.{ce6b4e9a-5081-48ff-a0a2-2b9ddd78a2c9}
12:45:39: Using desktop audio input: Speakers (ASUS Xonar DG Audio Device)
12:45:39: Using auxilary audio input: Microphone (ASUS Xonar DG Audio Device)
12:45:39: Using Mic QPC timestamps
12:45:39: Audio Encoding: AAC
12:45:39: bitrate: 128
12:45:39: Using Window Capture
12:45:39: Scene buffering time set to 900
12:45:39: Video Encoding: x264
12:45:39: fps: 30
12:45:39: width: 1280, height: 720
12:45:39: preset: veryfast
12:45:39: profile: main
12:45:39: keyint: 60
12:45:39: CBR: yes
12:45:39: CFR: yes
12:45:39: max bitrate: 2500
12:45:39: buffer size: 2500
12:45:40: Audio timestamp for device 'Microphone (ASUS Xonar DG Audio Device)' was behind target timestamp by 43
12:45:43: Audio timestamp for device 'Microphone (ASUS Xonar DG Audio Device)' was behind target timestamp by 64
12:46:16: Total frames encoded: 1076, total frames duplicated: 0 (0.00%)
12:46:16: Total frames rendered: 1080, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:46:16:
12:46:16: Profiler time results:
12:46:16:
12:46:16: ==============================================================
12:46:16: video thread frame - [100%] [avg time: 1.404 ms] [children: 90.1%] [unaccounted: 9.9%]
12:46:16: | scene->Preprocess - [82.1%] [avg time: 1.153 ms]
12:46:16: | GPU download and conversion - [7.98%] [avg time: 0.112 ms] [children: 7.41%] [unaccounted: 0.57%]
12:46:16: | | flush - [5.7%] [avg time: 0.08 ms]
12:46:16: | | CopyResource - [1.5%] [avg time: 0.021 ms]
12:46:16: | | conversion to 4:2:0 - [0.214%] [avg time: 0.003 ms]
12:46:16: Convert444Threads - [100%] [avg time: 0.533 ms] [children: 98.9%] [unaccounted: 1.13%]
12:46:16: | Convert444toNV12 - [98.9%] [avg time: 0.527 ms]
12:46:16: encoder thread frame - [100%] [avg time: 1.332 ms]
12:46:16:
12:46:16:
12:46:16: Profiler CPU results:
12:46:16:
12:46:16: video thread frame - [cpu time: avg 0.563 ms, total 608.403 ms] [avg calls per frame: 1]
12:46:16: | scene->Preprocess - [cpu time: avg 0.086 ms, total 93.601 ms] [avg calls per frame: 1]
12:46:16: | GPU download and conversion - [cpu time: avg 0.086 ms, total 93.601 ms] [avg calls per frame: 1]
12:46:16: | | flush - [cpu time: avg 0.043 ms, total 46.801 ms] [avg calls per frame: 1]
12:46:16: | | CopyResource - [cpu time: avg 0.029 ms, total 31.2 ms] [avg calls per frame: 1]
12:46:16: | | conversion to 4:2:0 - [cpu time: avg 0.014 ms, total 15.6 ms] [avg calls per frame: 1]
12:46:16: Convert444Threads - [cpu time: avg 0.178 ms, total 374.402 ms] [avg calls per frame: 2]
12:46:16: | Convert444toNV12 - [cpu time: avg 0.178 ms, total 374.402 ms] [avg calls per frame: 2]
12:46:16: encoder thread frame - [cpu time: avg 0.773 ms, total 811.205 ms] [avg calls per frame: 1]
12:46:16:
12:46:16: =====Stream End: 2014-02-09, 12:46:16=================================================
More info:
