Bug Report Sound is working but recording stuck at one frame
Taymour Abdelal
I tired doing everything but failed.
00:01:16: CLR host plugin strings not found, dynamically loading 4 strings
00:01:16: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
00:01:16: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
00:01:16: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
00:01:16: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
00:01:16: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
00:01:16: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
00:01:16: CLRHost:: Could not find/load browser settings at location C:\Users\timmy\AppData\Roaming\OBS\pluginData\browser.json
00:01:16: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\timmy\AppData\Roaming\OBS\pluginData\browser.json'.
00:01:16: File name: 'C:\Users\timmy\AppData\Roaming\OBS\pluginData\browser.json'
00:01:16: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
00:01:16: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
00:01:16: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
00:01:16: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
00:01:16: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
00:01:17: Open Broadcaster Software v0.659b - 32bit (´・ω・`)
00:01:17: -------------------------------
00:01:17: CPU Name: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
00:01:17: CPU Speed: 3504MHz
00:01:17: Physical Memory: 4095MB Total, 4095MB Free
00:01:17: stepping id: 3, model 94, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 4, total cores 4
00:01:17: monitor 1: pos={0, 0}, size={1920, 1080}
00:01:17: Windows Version: 10.0 Build 14393 (revision 0)
00:01:17: Aero is Enabled
00:01:17: OBS Modules:
00:01:17: Base Address Module
00:01:17: 00CF0000 OBS.exe
00:01:17: 0FD10000 OBSApi.dll
00:01:17: 0F1C0000 CLRHostPlugin.dll
00:01:17: 0F7C0000 DShowPlugin.dll
00:01:17: 0DD70000 GraphicsCapture.dll
00:01:17: 0F620000 NoiseGate.dll
00:01:17: 0F290000 PSVPlugin.dll
00:01:17: 0FA00000 scenesw.dll
00:01:18: ------------------------------------------
00:01:18: Adapter 1
00:01:18: Video Adapter: NVIDIA GeForce GTX 980
00:01:18: Video Adapter Dedicated Video Memory: 3221225472
00:01:18: Video Adapter Shared System Memory: 1073676288
00:01:18: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
00:01:18: =====Stream Start: 2017-03-18, 00:01:18===============================================
00:01:18: Multithreaded optimizations: On
00:01:18: Base resolution: 1920x1080
00:01:18: Output resolution: 1920x1080
00:01:18: Loading up D3D10 on NVIDIA GeForce GTX 980 (Adapter 1)...
00:01:18: Audio Format: 48000 Hz
00:01:18: Audio Channels: 2 Ch
00:01:18: Playback device Default
00:01:18: Using desktop audio input: Headphones (2- Astro MixAmp Pro Game)
00:01:18: Global Audio time adjust: 0
00:01:18: Using 5.1 surround speaker setup
00:01:18: Audio Encoding: AAC
00:01:18: bitrate: 128
00:01:18: Using Monitor Capture
00:01:18: Using graphics capture
00:01:18: Trying to hook process: RainbowSixGame.exe
Warning -- GraphicsCaptureSource::AttemptCapture: Failed to inject library, error code = 5
00:01:18: Scene buffering time set to 700
00:01:18: Using custom x264 settings: "crf=15"
00:01:18: x264: VBV maxrate specified, but no bufsize, ignored
00:01:18: Video Encoding: x264
00:01:18: fps: 60
00:01:18: width: 1920, height: 1080
00:01:18: preset: ultrafast
00:01:18: profile: high
00:01:18: keyint: 120
00:01:18: CBR: no
00:01:18: CFR: yes
00:01:18: max bitrate: 1000
00:01:18: buffer size: 0
00:01:18: quality: 17
00:02:19: Using graphics capture
00:02:19: Trying to hook process: RainbowSixGame.exe
00:02:21: Using graphics capture
00:02:43: FlushBufferedVideo: Flushing 61 packets over 1000 ms
00:02:44: Total frames encoded: 5090, total frames duplicated: 1690 (33.20%)
00:02:44: Number of frames skipped due to encoder lag: 1510 (29.67%)
00:02:44: Total frames rendered: 3420, number of late frames: 18 (0.53%) (it's okay for some frames to be late)
00:02:44:
00:02:44: Profiler time results:
00:02:44:
00:02:44: ==============================================================
00:02:44: video thread frame - [100%] [avg time: 1.473 ms] [children: 50.2%] [unaccounted: 49.8%]
00:02:44: | scene->Preprocess - [22.4%] [avg time: 0.33 ms]
00:02:44: | GPU download and conversion - [27.8%] [avg time: 0.409 ms] [children: 25.1%] [unaccounted: 2.72%]
00:02:44: | | flush - [24.2%] [avg time: 0.356 ms]
00:02:44: | | CopyResource - [0.679%] [avg time: 0.01 ms]
00:02:44: | | conversion to 4:2:0 - [0.204%] [avg time: 0.003 ms]
00:02:44: Convert444Threads - [100%] [avg time: 0.903 ms] [children: 99.4%] [unaccounted: 0.554%]
00:02:44: | Convert444toNV12 - [99.4%] [avg time: 0.898 ms]
00:02:44: encoder thread frame - [100%] [avg time: 5.826 ms] [children: 0.275%] [unaccounted: 99.7%]
00:02:44: | sending stuff out - [0.275%] [avg time: 0.016 ms]
00:02:44:
00:02:44:
00:02:44: Profiler CPU results:
00:02:44:
00:02:44: video thread frame - [cpu time: avg 0.077 ms, total 265.625 ms] [avg calls per frame: 1]
00:02:44: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:02:44: | GPU download and conversion - [cpu time: avg 0.063 ms, total 218.75 ms] [avg calls per frame: 1]
00:02:44: | | flush - [cpu time: avg 0.05 ms, total 171.875 ms] [avg calls per frame: 1]
00:02:44: | | CopyResource - [cpu time: avg 0.004 ms, total 15.625 ms] [avg calls per frame: 1]
00:02:44: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:02:44: Convert444Threads - [cpu time: avg 0.913 ms, total 6156.25 ms] [avg calls per frame: 2]
00:02:44: | Convert444toNV12 - [cpu time: avg 0.91 ms, total 6140.63 ms] [avg calls per frame: 2]
00:02:44: encoder thread frame - [cpu time: avg 1.037 ms, total 5218.75 ms] [avg calls per frame: 1]
00:02:44: | sending stuff out - [cpu time: avg 0.012 ms, total 62.5 ms] [avg calls per frame: 1]
00:02:44:
00:02:44: =====Stream End: 2017-03-18, 00:02:44=================================================
00:02:44: =====Stream Start: 2017-03-18, 00:02:44===============================================
00:02:44: Multithreaded optimizations: On
00:02:44: Base resolution: 1920x1080
00:02:44: Output resolution: 1920x1080
00:02:44: ------------------------------------------
00:02:44: Loading up D3D10 on NVIDIA GeForce GTX 980 (Adapter 1)...
00:02:44: Audio Format: 48000 Hz
00:02:44: Audio Channels: 2 Ch
00:02:44: Playback device Default
00:02:44: Using desktop audio input: Headphones (2- Astro MixAmp Pro Game)
00:02:44: Global Audio time adjust: 0
  • 2017-03-18-0001-16.log
