Question / Help Sound is consistantly increasing?
synyst3rbl4d3
If anyone has played with an electric guitar amp, when the gain on the amp is too high, the reverb continues to build until it becomes too high and risks overall sound. I am trying to stream Call of Duty, and just games in general. I have a Hauppauge PVR and I am streaming the gameplay through the monitor capture of OBS. The issue I am having is when I preview the stream with it recording CoD, the speaker output continues to build until it ruins the overall quality of the stream. I have tried every setting for the desktop audio and the problem is still persistant. Any suggestions? Thanks!
synyst3rbl4d3
It does it even when I live stream. I am new to OBS, and muting the audio would keep others from hearing it, but I have no idea what the problem would be.
synyst3rbl4d3
22:08:38: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
22:08:38: -------------------------------
22:08:38: CPU Name: AMD A8-3500M APU with Radeon(tm) HD Graphics
22:08:38: CPU Speed: 1497MHz
22:08:38: Physical Memory: 4095MB Total, 4095MB Free
22:08:38: stepping id: 0, model 1, family 15, type 0, extmodel 8, extfamily 1, HTT 1, logical cores 4, total cores 4
22:08:38: monitor 1: pos={0, 0}, size={1366, 768}
22:08:38: Windows Version: 6.1 Build 7601 S
22:08:38: Aero is Disabled
22:08:38: OBS Modules:
22:08:38: Base Address Module
22:08:38: 009F0000 OBS.exe
22:08:38: 6AAA0000 OBSApi.dll
22:08:38: 72930000 DShowPlugin.dll
22:08:38: 72970000 GraphicsCapture.dll
22:08:38: 72370000 NoiseGate.dll
22:08:38: 72390000 PSVPlugin.dll
22:08:38: ------------------------------------------
22:08:38: Adapter 1
22:08:38: Video Adapter: AMD Radeon(TM) HD 6620G
22:08:38: Video Adapter Dedicated Video Memory: 517066752
22:08:38: Video Adapter Shared System Memory: 3747035136
22:08:38: =====Stream Start: 2013-07-20, 22:08:38===============================================
22:08:38: Multithreaded optimizations: Off
22:08:38: Base resolution: 1280x720
22:08:38: Output resolution: 1280x720
22:08:38: Loading up D3D10...
22:08:38: Playback device Default
22:08:38: Using desktop audio input: Speakers and Headphones (IDT High Definition Audio CODEC)
22:08:38: Audio Encoding: MP3
22:08:38: bitrate: 256
22:08:38: Using Monitor Capture
22:08:38: Video Encoding: x264
22:08:38: fps: 60
22:08:38: width: 1280, height: 720
22:08:38: preset: faster
22:08:38: CBR: no
22:08:38: CFR: no
22:08:38: max bitrate: 1800
22:08:38: buffer size: 2000
22:08:38: quality: 10
22:08:48: Total frames rendered: 348, number of frames that lagged: 144 (41.38%) (it's okay for some frames to lag)
22:08:48: =====Stream End: 2013-07-20, 22:08:48=================================================
22:09:46:
22:09:46: Profiler results:
22:09:46:
22:09:46: ==============================================================
22:09:46: frame - [100%] [avg time: 20.865 ms (cpu time: avg 7.172 ms, total 2496.02 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.101%]
22:09:46: | frame preprocessing and rendering - [20.2%] [avg time: 4.222 ms (cpu time: avg 1.568 ms, total 546.004 ms)] [avg calls per frame: 1] [children: 12%] [unaccounted: 8.25%]
22:09:46: | | scene->Preprocess - [12%] [avg time: 2.5 ms (cpu time: avg 0.941 ms, total 327.602 ms)] [avg calls per frame: 1]
22:09:46: | video encoding and uploading - [79.7%] [avg time: 16.622 ms (cpu time: avg 5.603 ms, total 1950.01 ms)] [avg calls per frame: 1] [children: 79.3%] [unaccounted: 0.34%]
22:09:46: | | flush - [2.05%] [avg time: 0.427 ms (cpu time: avg 0.134 ms, total 46.8 ms)] [avg calls per frame: 1]
22:09:46: | | CopyResource - [0.0288%] [avg time: 0.006 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:09:46: | | conversion to 4:2:0 - [15.8%] [avg time: 3.304 ms (cpu time: avg 3.317 ms, total 1154.41 ms)] [avg calls per frame: 0]
22:09:46: | | call to encoder - [61.4%] [avg time: 12.811 ms (cpu time: avg 2.106 ms, total 733.202 ms)] [avg calls per frame: 0]
22:09:46: | | sending stuff out - [0.0144%] [avg time: 0.003 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
22:09:46:
