Bug Report Sound crashes with OBS on
Mezko
Hi,
I've been using OBS for more or less a week and since today, I have big troubles with the sound.
I uploaded a video to make it clear:
Once I quit OBS, those problems disappear. I use Loopback.
Thanks for any help, I'm kind of lost here.
  • 2018-04-04 14-58-45.txt
Narcogen
Your GPU is having trouble rendering frames fast enough to keep up with your stream. I'm not sure what to suggest to resolve it given that you're already only attempting 720p30 and the content doesn't look demanding.
15:21:34.884: ==== Recording Start ===============================================
15:21:34.884: [ffmpeg muxer: 'simple_file_output'] Writing file '/Users/Matt/Movies/2018-04-04 15-21-34.mp4'...
15:21:47.401: Unexpected pixel format: 0 (
15:22:07.036: [rtmp stream: 'simple_stream'] User stopped the stream
15:22:07.037: Output 'simple_stream': stopping
15:22:07.037: Output 'simple_stream': Total frames output: 1009
15:22:07.037: Output 'simple_stream': Total drawn frames: 825 (1088 attempted)
15:22:07.037: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 263 (24.2%)
15:22:07.054: ==== Streaming Stop ================================================
15:22:07.932: [ffmpeg muxer: 'simple_file_output'] Output of file '/Users/Matt/Movies/2018-04-04 15-21-34.mp4' stopped
15:22:07.932: Output 'simple_file_output': stopping
15:22:07.932: Output 'simple_file_output': Total frames output: 962
15:22:07.932: Output 'simple_file_output': Total drawn frames: 752 (991 attempted)
15:22:07.932: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 239 (24.1%)
15:22:07.933: ==== Recording Stop ================================================
Mezko
Ok, thank you !
Maybe if I shut down other programs (even though I don't have many that run meanwhile). A 2009 machine got its limits.
