bananaa101
Alright listen up if you are having this problem continue to read this as I did hours worth of testing and have finally figured out the problem.
Even if your internet's upload speed is more than sufficient for streaming (and don't fucking listen to testmy.net shit because its incorrect for every person I've asked to try it) you can NOT go over 4000 kbps when streaming to twitch if you are not a premium account member. They limit your bandwidth to this roughly .5MB/s cap so that even if you go up to 4500kbps, people will start to see freezing. This cap as far as I can tell is also the same with Hashd.tv and probably for any other widely used streaming site.
Next thing to note is your ping to the load server you are streaming to. This is extremely important, as it dictated whether or not my stream froze when using 4000kbps.
Download JTVPing http://www.teamliquid.net/staff/R1CH/JTVPing.zip (credit to R1CH who I believe is the same person that replied to me on this forum)
This tool is essentially the same as Xsplit's latency checking tool which can be accessed when choosing your location when editing your channel. Unsure if it works for other streaming sites or only Twitch.
It should look like this when you open it.
The most important thing to note is your ping to the server. Like all things, the lower your ping, the better. This will decide your ideal bitrate.
Time of day can be a factor determining whether or not your stream will be smooth, as well as MLG events. Regardless, choose the server with the lowest ping. Jitter is also important, as it is how much your ping fluctuates to the server, but not nearly as much as your average ping to the servers
When I tested streaming at 3500kbps to New York, my stream was freezing out the ass non stop. Only when I dropped it to 3000 did it become watchable. As you can see based on my ping in the above picture, I get about 100ms to New York. Not bad, but also not ideal. With this in mind, if your lowest ping is 100, make sure to remember the fact that I could not stream at 3500kbps with non-freezing quality. I did not test 3400kbps or anything else in between, but the difference in quality between 3000 and 3500 is already very minimal.
Furthermore, make sure your audio bitrate is set to 192. When you decide your max bitrate, it does not take into account your audio. This means your actual total is 4192kbps if your bitrate is set to 4000. This comes back to the .5MB/s limit, as 4000 compared to 4192 does not make a huge difference, however if you set the audio to 256 or 320, you can start to see freezing occur. For some streamers, 256 is the preferred, so if you want to have marginally better audio quality, you may want to drop to 3900kbps.
Going back to testmy.net quickly. According to speedtest.net, this is my speed.
This would allow for a little over 10,000kbps streaming, enough for almost any stream to be max quality at high resolution.
Now lets take a look at testmy.net
According to this, my sustained upload speed should only be about 3080kilobits per second. So why can I stream at 4000kbps? Whether or not testmy.net is more correct than speedtest.net, using speedtest is more than sufficient for the purposes of finding your streaming bitrate.
Below are my final OBS settings.
If everything is setup correctly, you should not have any more problems.
If you have any further problems regarding your stream freezing, don't hesitate to ask.
~~~~~Everything below is my original post~~~~~
I would like to reiterate my previous title which said I am dropping frames. OBS says I drop 0 frames on everything I stream, however my Twitch.tv stream has constant freezing.
I've been having this problem only starting about a week ago. Any time I try to use game capture (not to mention a lot of games aren't working when using it) I start to drop frames seemingly at random, but a consistent amount each time. I've tried almost every setting on/off with different combinations and even tried the settings that my friend uses and I still have the same problem. Here's a few speedtests of my connection:
I am connected hardline to my router.
And here are my system specs.
My GPU is a HD 7950
Also, I was able to stream a few games earlier this month with almost no problem while having the same connection.
During my stream if I take a speed test it will always have the same readout with slight deviations of course in download/upload based on Comcast's current bandwidth output. Below is my current OBS settings while streaming desktop which has no problems with dropping frames.
Now here's my average game capture stream.
As you can see, RTMPPublisher::BufferedSend: Socket buffer is full shows up multiple times. I deleted most of them because the log is extremely long. If there is any known solution to this socket buffer full problem, I believe it would solve my problem.
Any help solving this would be appreciated.
My GPU is a HD 7950
Base resolution: 1280x1024
Output resolution: 1280x1024
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 192
Using graphics capture
Using Monitor Capture
Using custom x264 settings: "vbvmaxrate=<6000>"
The custom x264 command 'vbvmaxrate=<6000>' failed
x264: profile High, level 4.2
Video Encoding: x264
fps: 60
width: 1280, height: 1024
preset: veryfast
CBR: no
CFR: no
max bitrate: 6000
buffer size: 6000
quality: 10
Syncing audio to video time
Server selection: rtmp://live-jfk.justin.tv/app
bufferTime: 2245, outputRateWindowTime: 1000, dropThreshold: 2745
Total frames rendered: 1876, number of frames that lagged: 1876 (100.00%) (it's okay for some frames to lag)
x264: frame I:8 Avg QP:21.29 size:150134
x264: frame P:536 Avg QP:25.62 size: 6041
x264: frame B:1295 Avg QP:30.82 size: 356
x264: consecutive B-frames: 5.0% 2.8% 1.1% 91.0%
x264: mb I I16..4: 53.0% 8.6% 38.3%
x264: mb P I16..4: 4.7% 0.4% 0.8% P16..4: 2.3% 0.6% 0.4% 0.0% 0.0% skip:90.8%
x264: mb B I16..4: 0.4% 0.0% 0.0% B16..8: 0.4% 0.1% 0.0% direct: 0.2% skip:98.8% L0:40.4% L1:38.6% BI:21.1%
x264: 8x8 transform intra:6.8% inter:30.7%
x264: coded y,uvDC,uvAC intra: 24.5% 11.5% 8.8% inter: 0.8% 0.3% 0.1%
x264: i16 v,h,dc,p: 57% 42% 1% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 36% 33% 1% 1% 1% 1% 1% 2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 39% 14% 2% 3% 3% 3% 2% 4%
x264: i8c dc,h,v,p: 77% 17% 5% 0%
x264: kb/s:621.56
Loading up D3D10...
Audio Encoding: AAC
bitrate: 192
Using Window Capture
Using custom x264 settings: "vbvmaxrate=<4800>"
The custom x264 command 'vbvmaxrate=<4800>' failed
fps: 60
preset: veryfast
CBR: no
CFR: no
max bitrate: 4800
buffer size: 4800
quality: 10
SharedTexCapture hooked
bufferTime: 2028, outputRateWindowTime: 1000, dropThreshold: 2528
RTMPPublisher::BufferedSend: Socket buffer is full (636386 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (635126 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638315 / 638976 bytes), waiting to send 1248 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (635294 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638634 / 638976 bytes), waiting to send 678 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (637335 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638569 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (637377 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (637348 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638473 / 638976 bytes), waiting to send 643 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638618 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638248 / 638976 bytes), waiting to send 3657 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (636597 / 638976 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (637265 / 638976 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638425 / 638976 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (635936 / 638976 bytes), waiting to send 4097 bytes
~~~~~~~~~~~~~~~~~~~~~~~~~~(excluding a lot of lines to shorten this)~~~~~~~~~~~~~~~~~~~~~~~~~
RTMPPublisher::BufferedSend: Socket buffer is full (638802 / 638976 bytes), waiting to send 533 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (638598 / 638976 bytes), waiting to send 3737 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (636087 / 638976 bytes), waiting to send 4104 bytes
Total frames rendered: 158498, number of frames that lagged: 9035 (5.70%) (it's okay for some frames to lag)
Number of b-frames dropped: 9978 (6.3%), Number of p-frames dropped: 8933 (5.6%), Total 18911 (12%)
x264: frame I:1180 Avg QP:22.72 size: 49325
x264: frame P:68296 Avg QP:24.83 size: 10563
x264: frame B:88968 Avg QP:26.15 size: 1855
x264: consecutive B-frames: 19.0% 14.5% 11.5% 54.9%
x264: mb I I16..4: 32.8% 51.9% 15.3%
x264: mb P I16..4: 9.7% 10.4% 0.4% P16..4: 19.1% 6.5% 1.9% 0.0% 0.0% skip:52.2%
x264: mb B I16..4: 0.7% 0.4% 0.0% B16..8: 8.0% 1.6% 0.1% direct: 1.0% skip:88.0% L0:41.2% L1:53.7% BI: 5.1%
x264: 8x8 transform intra:49.9% inter:37.8%
x264: coded y,uvDC,uvAC intra: 32.2% 17.6% 4.2% inter: 3.0% 2.4% 0.2%
x264: i16 v,h,dc,p: 44% 28% 20% 8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 21% 33% 4% 4% 4% 5% 4% 5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 23% 19% 6% 7% 6% 7% 5% 6%
x264: i8c dc,h,v,p: 72% 14% 13% 1%
x264: Weighted P-Frames: Y:2.4% UV:1.3%
x264: kb/s:2700.12
