Smart Lower Thirds
Smart Lower Thirds 1.1
Smart@
Smart@obs submitted a new resource:
Smart Lower Thirds - Advanced Lower Thirds with Control Panel (11 Animations, Custom Colors, Typewriter Effect)
Take your stream's production value to the next level with this fully customizable, browser-based Lower Thirds system. It comes with a dedicated Control Panel that docks directly into OBS, giving you live control over 4 (or more) idependent lower third slots. (built with Googles Antigravity)
Smart@
Smart@ updated Smart Lower Thirds with a new update entry:
OBS Lower Thirds - Animation out Fix Update
Critical Bug Fix: Exit Animations​
Fixed: Exit animations now properly respect the timing settings instead of disappearing instantly.
The Problem:
  • When hiding a lower third, it would vanish immediately instead of animating out
  • The "Animation Out" duration setting was being ignored
  • All transitions (Slide, Bounce, Fade, etc.) were affected
The Solution:
  • Completely rewrote all exit animation keyframes to include...
