Smart Gamma
Smart Gamma 0.1.3
mirkonz
mirkonz submitted a new resource:
Smart Gamma - Automatic luminance-aware shader filter
Smart Gamma is a single-pass GPU shader filter for OBS Studio. It samples scene luminance, applies gamma/brightness/contrast/saturation boosts when captures drop below a configurable threshold, and fades back as soon as things brighten up. The state machine drives everything through one `effect_strength` scalar, so the filter can stay idle without extra overhead.
Key capabilities
  • Automatic brightness guard: Observes...
sneaky4oe
Oh man, you have no idea how much I wanted exactly THAT. Tired of toggling scene with increased brightness!
Struggle to get it working on windows 10 tho.
Added downloaded github windows x64 unarchived folder to `C:\Program Files\obs-studio\data\obs-plugins` and to `C:\Program Files\obs-studio\obs-plugins\64bit` and to `%appdata%\Roaming\obs-studio\plugins` but doesn't work. Any ideas? Should it be invoked with shader filter?
mirkonz
Hey @sneaky4oe,
Sorry I didn't check the Windows version, I only have a mac myself (I probably should have mentioned it).
Thanks for trying (testing) the plugin for me though :)
I've just published a new version with an installer. Let me know if that works.
By the way, the plugin is standalone, you can't invoke it via the "user-defined shader" plugin.
sneaky4oe
Hey I've also been playing a lot of arc raiders lately with this plugin. It seems like in main menu which is pretty bright I can't have original brightness - it only changes between 0.01 and 0.00 values for brightness threshold. I did see it changing dynamically during gameplay with dark/bright scenes, but looks like topmost slider doesn't work exactly as it should? Can you please doublecheck logics? @mirkonz
