Skips/desync in audio, long term issue
newbornkilik
I have been working with this issue for about 7 months now and could really use a hand!
My mic will skip as if it is resyncing. I believe it is resyncing because as a test I set up a second track that can be used as a patch if need be (all different vst plugins used on track 2) and noticed that it skips (usually) in different places. I have included my log and an example of both tracks skipping in the same recording session.
One is a more obvious blip and seems to pull the audio back (track 2) while the other seems like it is smashing the audio back together to compensate.
I have audio of the incidents, but can't upload the audio here.
I am also having the issue in Streamlabs obs, which makes me believe it could be either the "New" NVENC encoder (using it for both) or a hardware issue.
Note: a few months ago I tried to set my default mic (Blue Yeti) as a separate audio track for testing purposes as well with no filters or anything the skipping was still present.
Any help is really appreciated cheers!
  • 2020-09-09 21-23-50.txt
  • 2020-09-12 17-33-14.txt
