Hello.
So as a big twitch fan i found many people on their streams are counting something (e.g. followers, subscribers, vodka shots ect.) and then they are having hard times updating their TXT file with right count ( it may be intended Kappa ).
I did not really noticed anyone using some litle program like this.
This program is ( i belive it is ) easy to use and run on as low ressources as possible ( ~30kB with text document ).
How to install?
1.Simple unpack it to some folder which do not require administrator permision to modify text document (e.g. your desktop ).
2. OBS -: resources -> add -> text -> "name" -> use text from file -> \\.../CounterText.txt
How it works? After adding/removing/reseting count with button ( ++, -- , reset ) it replace and rewrite the CounterText.txt file ( so make sure you are not running it on background or it may not work as intended ) with current number value. It have "0" lag between change -to- OBS display.
Images:
Download: v.1.0 - tested on win8.1 64bit
https://obsproject.com/forum/attach...9/?temp_hash=a807cb39fa98101771d176f72b05c6a0
Hope you will enjoy.
And sorry for my bad english =d
*Edit: Any bug reports, ideas, etc., are welcomed
How to install?
Images:
