Resource icon
Simple eased pan animated motion .shader filter plugin 1.0
graveyard420woo
graveyard420woo submitted a new resource:
Simple eased pan animated motion .shader plugin - A simple eased, looping pan for a layer that exceeds the horizontal edges of the frame
I swear this has to exist somewhere.. I have needed this simple animation capability for a panning background layer, with easing, in OBS and could not find a basic plugin to do it quickly and easily. I just wrote this one. hopefully this helps someone.. This .shader file is meant to be used with Exeldro's fantastic OBS-shaderfilter. Simply extract to obs-shaderfilter's examples folder and load the filter from file or copy the text from the .shader file into a new User-defined shader.
