MTSimpson82
What Should My Max Bitrate Be... I Do Not Wanna Use The Estimator.. Including My internet speeds and A Log...
01:01:08: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
01:01:08: -------------------------------
01:01:08: CPU Name: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz
01:01:08: CPU Speed: 2993MHz
01:01:08: Physical Memory: 4095MB Total, 4095MB Free
01:01:08: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
01:01:08: monitor 1: pos={0, 0}, size={1920, 1080}
01:01:08: Windows Version: 6.1 Build 7601 S
01:01:08: Aero is Disabled
01:01:08: OBS Modules:
01:01:08: Base Address Module
01:01:08: 00070000 OBS.exe
01:01:08: 65D80000 OBSApi.dll
01:01:08: 67EF0000 DShowPlugin.dll
01:01:08: 66E60000 GraphicsCapture.dll
01:01:08: 66E80000 NoiseGate.dll
01:01:08: 66C80000 PSVPlugin.dll
01:01:08: ------------------------------------------
01:01:08: Adapter 1
01:01:08: Video Adapter: NVIDIA GeForce GT 640
01:01:08: Video Adapter Dedicated Video Memory: 1018888192
01:01:08: Video Adapter Shared System Memory: 3221549056
01:01:08: Adapter 2
01:01:08: Video Adapter: Intel(R) HD Graphics
01:01:08: Video Adapter Dedicated Video Memory: 67108864
01:01:08: Video Adapter Shared System Memory: 1711276032
01:01:08: =====Stream Start: 2013-08-09, 01:01:08===============================================
01:01:08: Multithreaded optimizations: On
01:01:08: Base resolution: 1920x1080
01:01:08: Output resolution: 1280x720
01:01:08: Loading up D3D10...
01:01:08: Playback device Default
01:01:08: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:01:08: Audio Encoding: AAC
01:01:08: bitrate: 128
01:01:08: device: Logitech HD Webcam C615,
01:01:08: device id \\?\usb#vid_046d&pid_082c&mi_02#7&32a33e4b&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
01:01:08: chosen type: I420, usingFourCC: false, res: 432x240 - 432x240, frameIntervals: 333333-2000000, fourCC: 'I420'
01:01:08: audio device: Disable,
01:01:08: audio device id Disabled,
01:01:08:
01:01:08: Using directshow input
01:01:08: device: Elgato Game Capture HD,
01:01:08: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:01:08: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:01:08:
01:01:08: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:01:09: ------------------------------------------
01:01:09: Video Encoding: x264
01:01:09: fps: 30
01:01:09: width: 1280, height: 720
01:01:09: preset: veryfast
01:01:09: CBR: yes
01:01:09: CFR: no
01:01:09: max bitrate: 2800
01:01:17: Using bitmap image
01:01:49: Total frames rendered: 1201, number of frames that lagged: 2 (0.17%) (it's okay for some frames to lag)
01:01:52: =====Stream End: 2013-08-09, 01:01:52=================================================
01:02:26: =====Stream Start: 2013-08-09, 01:02:26===============================================
01:02:26: Multithreaded optimizations: On
01:02:26: Base resolution: 1920x1080
01:02:26: Output resolution: 1280x720
01:02:26: ------------------------------------------
01:02:26: Loading up D3D10...
01:02:26: Playback device Default
01:02:26: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:02:26: Audio Encoding: AAC
01:02:26: bitrate: 128
01:02:26: device: Logitech HD Webcam C615,
01:02:26: device id \\?\usb#vid_046d&pid_082c&mi_02#7&32a33e4b&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
01:02:26: chosen type: I420, usingFourCC: false, res: 432x240 - 432x240, frameIntervals: 333333-2000000, fourCC: 'I420'
01:02:26: audio device: Disable,
01:02:26: audio device id Disabled,
01:02:26:
01:02:27: Using directshow input
01:02:27: ------------------------------------------
01:02:27: device: Elgato Game Capture HD,
01:02:27: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:02:27: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:02:27:
01:02:27: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:02:27: Video Encoding: x264
01:02:27: fps: 30
01:02:27: width: 1280, height: 720
01:02:27: preset: veryfast
01:02:27: CBR: yes
01:02:27: CFR: no
01:02:27: max bitrate: 2800
01:02:36: Using bitmap image
01:02:47: Total frames rendered: 600, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:02:50: =====Stream End: 2013-08-09, 01:02:50=================================================
01:02:51:
01:02:51: Profiler results:
01:02:51:
01:02:51: ==============================================================
01:02:51: frame - [100%] [avg time: 3.319 ms (cpu time: avg 2.685 ms, total 4836.03 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.181%]
01:02:51: | frame preprocessing and rendering - [60.5%] [avg time: 2.009 ms (cpu time: avg 1.498 ms, total 2698.81 ms)] [avg calls per frame: 1] [children: 22.4%] [unaccounted: 38.2%]
01:02:51: | | scene->Preprocess - [22.4%] [avg time: 0.742 ms (cpu time: avg 0.727 ms, total 1310.41 ms)] [avg calls per frame: 1]
01:02:51: | video encoding and uploading - [39.3%] [avg time: 1.304 ms (cpu time: avg 1.178 ms, total 2121.61 ms)] [avg calls per frame: 1] [children: 38.2%] [unaccounted: 1.11%]
01:02:51: | | flush - [3.8%] [avg time: 0.126 ms (cpu time: avg 0.025 ms, total 46.801 ms)] [avg calls per frame: 1]
01:02:51: | | CopyResource - [0.693%] [avg time: 0.023 ms (cpu time: avg 0.025 ms, total 46.8 ms)] [avg calls per frame: 0]
01:02:51: | | conversion to 4:2:0 - [0.151%] [avg time: 0.005 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
01:02:51: | | call to encoder - [33.5%] [avg time: 1.112 ms (cpu time: avg 1.1 ms, total 1981.21 ms)] [avg calls per frame: 0]
01:02:51: | | sending stuff out - [0.0301%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
01:02:51: | Convert444Threads - [1.98e+003%] [avg time: 65.878 ms (cpu time: avg 1.143 ms, total 2059.21 ms)] [avg calls per frame: 1]
01:02:51:
01:02:51: Memory Leaks Were Detected.
01:02:51:
01:01:08: Adapter 1
01:01:08: Adapter 2
01:01:08:
01:01:08:
01:01:09: fps: 30
01:01:09: CBR: yes
01:01:09: CFR: no
01:02:26:
01:02:27:
01:02:27: fps: 30
01:02:27: CBR: yes
01:02:27: CFR: no
01:02:51:
01:02:51:
01:02:51:
01:02:51:
