RedRoomGaming
The log files for every time it has crashed are below.
Now I think that is the crash files if not could you point me on how to get them but when I stream it is fine for about 10 mins then all of a sudden just glitches out and then crashes. I use the hauppauge hdpvr 2 gaming edition to pass through my game and only have google chrome open when My stream is going on. Could you help please as it is very very frustration to have to restart all the time.
12:05:28: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
12:05:28: -------------------------------
12:05:28: CPU Name: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
12:05:28: CPU Speed: 2594MHz
12:05:28: Physical Memory: 4095MB Total, 4095MB Free
12:05:28: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
12:05:28: monitor 1: pos={0, 0}, size={1366, 768}
12:05:28: Windows Version: 6.2 Build 9200
12:05:28: Aero is Enabled
12:05:28: OBS Modules:
12:05:28: Base Address Module
12:05:28: 01340000 OBS.exe
12:05:28: 70C70000 OBSApi.dll
12:05:28: 71070000 DShowPlugin.dll
12:05:28: 71040000 GraphicsCapture.dll
12:05:28: 71010000 NoiseGate.dll
12:05:28: 70FF0000 PSVPlugin.dll
12:05:28: 70FD0000 scenesw.dll
12:05:28: ------------------------------------------
12:05:28: Adapter 1
12:05:28: Video Adapter: Intel(R) HD Graphics 4000
12:05:28: Video Adapter Dedicated Video Memory: 100663296
12:05:28: Video Adapter Shared System Memory: 1778384896
12:05:28: Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
12:05:28: =====Stream Start: 2015-06-02, 12:05:28===============================================
12:05:28: Multithreaded optimizations: On
12:05:28: Base resolution: 1366x768
12:05:28: Output resolution: 1364x768
12:05:28: Loading up D3D10 on Intel(R) HD Graphics 4000 (Adapter 1)...
12:05:29: ------------------------------------------
12:05:29: Audio Format: 48000 Hz
12:05:29: Audio Channels: 2 Ch
12:05:29: Playback device Default
12:05:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:05:29: Global Audio time adjust: 0
12:05:29: Using auxilary audio input: Microphone (Turtle Beach PX21 Headset)
12:05:29: Mic time offset: 0
12:05:29: Audio Encoding: AAC
12:05:29: bitrate: 128
12:05:29: device: HD WebCam,
12:05:29: device id \\?\usb#vid_04f2&pid_b374&mi_00#7&2c0cffed&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
12:05:29: chosen type: MJPG, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
12:05:29: use buffering: false - 0, fourCC: 'MJPG'
12:05:29: audio device: Disable,
12:05:29: audio device id Disabled,
12:05:29: audio time offset 0,
12:05:29:
12:05:30: Using directshow input
12:05:30: Scene buffering time set to 700
12:05:30: ------------------------------------------
12:05:30: Video Encoding: x264
12:05:30: fps: 40
12:05:30: width: 1364, height: 768
12:05:30: preset: veryfast
12:05:30: profile: high
12:05:30: keyint: 250
12:05:30: CBR: yes
12:05:30: CFR: yes
12:05:30: max bitrate: 1000
12:05:30: buffer size: 1000
Warning -- DShowPlugin: Could not get device video pin
12:06:25: Using directshow input
12:07:31: Failed loading CUDA dll
12:07:54: FlushBufferedVideo: Flushing 11 packets over 250 ms
12:07:55: Total frames encoded: 5759, total frames duplicated: 5 (0.09%)
12:07:55: Total frames rendered: 5778, number of late frames: 1 (0.02%) (it's okay for some frames to be late)
12:07:55:
12:07:55: Profiler time results:
12:07:55:
12:07:55: ==============================================================
12:07:55: video thread frame - [100%] [avg time: 0.747 ms] [children: 35.3%] [unaccounted: 64.7%]
12:07:55: | scene->Preprocess - [22.2%] [avg time: 0.166 ms]
12:05:28: Adapter 1
12:05:29:
12:05:30: fps: 40
12:05:30: CBR: yes
12:05:30: CFR: yes
12:07:55:
12:07:55:
12:11:30: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
12:11:30: -------------------------------
12:11:30: CPU Name: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
12:11:30: CPU Speed: 2594MHz
12:11:30: Physical Memory: 4095MB Total, 4095MB Free
12:11:30: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
12:11:30: monitor 1: pos={0, 0}, size={1366, 768}
12:11:30: Windows Version: 6.2 Build 9200
12:11:30: Aero is Enabled
12:11:30: OBS Modules:
12:11:30: Base Address Module
12:11:30: 00320000 OBS.exe
12:11:30: 66DE0000 OBSApi.dll
12:11:30: 66BE0000 DShowPlugin.dll
12:11:30: 66BB0000 GraphicsCapture.dll
12:11:30: 66B80000 NoiseGate.dll
12:11:30: 66B60000 PSVPlugin.dll
12:11:30: 66B40000 scenesw.dll
12:11:30: ------------------------------------------
12:11:30: Adapter 1
12:11:30: Video Adapter: Intel(R) HD Graphics 4000
12:11:30: Video Adapter Dedicated Video Memory: 100663296
12:11:30: Video Adapter Shared System Memory: 1778384896
12:11:30: Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
12:11:30: =====Stream Start: 2015-06-02, 12:11:30===============================================
12:11:30: Multithreaded optimizations: On
12:11:30: Base resolution: 1366x768
12:11:30: Output resolution: 1364x768
12:11:30: Loading up D3D10 on Intel(R) HD Graphics 4000 (Adapter 1)...
12:11:30: Audio Format: 48000 Hz
12:11:30: Audio Channels: 2 Ch
12:11:30: Playback device Default
12:11:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:11:30: Global Audio time adjust: 0
12:11:30: Using auxilary audio input: Microphone (Turtle Beach PX21 Headset)
12:11:30: Mic time offset: 0
12:11:30: Audio Encoding: AAC
12:11:30: bitrate: 128
12:11:30: Using directshow input
12:11:30: Scene buffering time set to 700
12:11:30: Video Encoding: x264
12:11:30: fps: 40
12:11:30: width: 1364, height: 768
12:11:30: preset: veryfast
12:11:30: profile: high
12:11:30: keyint: 250
12:11:30: CBR: yes
12:11:30: CFR: yes
12:11:30: max bitrate: 1000
12:11:30: buffer size: 1000
12:13:22: FlushBufferedVideo: Flushing 11 packets over 250 ms
12:13:22: Total frames encoded: 4446, total frames duplicated: 34 (0.76%)
12:13:22: Number of frames skipped due to encoder lag: 30 (0.67%)
12:13:22: Total frames rendered: 4438, number of late frames: 1 (0.02%) (it's okay for some frames to be late)
12:13:22:
12:13:22: Profiler time results:
12:13:22:
12:13:22: ==============================================================
12:13:22: video thread frame - [100%] [avg time: 0.529 ms] [children: 18.3%] [unaccounted: 81.7%]
12:13:22: | scene->Preprocess - [0.378%] [avg time: 0.002 ms]
12:13:22: | GPU download and conversion - [18%] [avg time: 0.095 ms] [children: 14.4%] [unaccounted: 3.59%]
12:13:22: | | flush - [7.56%] [avg time: 0.04 ms]
12:13:22: | | CopyResource - [6.24%] [avg time: 0.033 ms]
12:13:22: | | conversion to 4:2:0 - [0.567%] [avg time: 0.003 ms]
12:13:22: Convert444Thread - [100%] [avg time: 1.249 ms] [children: 98.7%] [unaccounted: 1.28%]
12:13:22: | Convert444toNV12 - [98.7%] [avg time: 1.233 ms]
12:13:22: encoder thread frame - [100%] [avg time: 1.617 ms] [children: 0.433%] [unaccounted: 99.6%]
12:13:22: | sending stuff out - [0.433%] [avg time: 0.007 ms]
12:13:22:
12:13:22:
12:13:22: Profiler CPU results:
12:13:22:
12:13:22: video thread frame - [cpu time: avg 0.077 ms, total 343.75 ms] [avg calls per frame: 1]
12:13:22: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:13:22: | GPU download and conversion - [cpu time: avg 0.045 ms, total 203.125 ms] [avg calls per frame: 1]
12:13:22: | | flush - [cpu time: avg 0.024 ms, total 109.375 ms] [avg calls per frame: 1]
12:13:22: | | CopyResource - [cpu time: avg 0.014 ms, total 62.5 ms] [avg calls per frame: 1]
12:13:22: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:13:22: Convert444Thread - [cpu time: avg 1.312 ms, total 5781.25 ms] [avg calls per frame: 1]
12:13:22: | Convert444toNV12 - [cpu time: avg 1.305 ms, total 5750 ms] [avg calls per frame: 1]
12:13:22: encoder thread frame - [cpu time: avg 1.617 ms, total 7171.88 ms] [avg calls per frame: 1]
12:13:22: | sending stuff out - [cpu time: avg 0.017 ms, total 78.125 ms] [avg calls per frame: 1]
12:13:22:
12:13:22: =====Stream End: 2015-06-02, 12:13:22=================================================
12:13:22: Terminating 0xeec
12:11:30: Adapter 1
12:11:30: fps: 40
12:11:30: CBR: yes
12:11:30: CFR: yes
12:13:22:
12:13:22:
12:13:22:
12:13:22:
12:13:22:
12:13:22:
