Bug Report Segmentation Fault when starting
jefferyrlc
I recently swapped my old GTX 960 GPU for a RX 570 and ever since making that switch obs studio crashes whenever I try to start it.
When running from terminal, this is the output:
obs
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /usr/share/obs/obs-studio/themes/Dark.qss
info: CPU Name: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
info: CPU Speed: 2309.770MHz
info: Physical Cores: 4, Logical Cores: 8
info: Physical Memory: 16030MB Total, 6175MB Free
info: Kernel Version: Linux 5.2.11-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.5
info: Portable mode: false
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /usr/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
info: OBS 23.2.1-2 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: Initializing OpenGL...
info: Loading up OpenGL on adapter X.Org Radeon RX 570 Series (POLARIS10, DRM 3.32.0, 5.2.11-1-MANJARO, LLVM 8.0.1)
info: OpenGL loaded successfully, version 4.5 (Core Profile) Mesa 19.1.5, shading language 4.50
info: video settings reset:
base resolution: 80x45
output resolution: 80x44
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: 601/Partial
info: NV12 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
info: No blackmagic support
error: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: cannot open shared object file: No such file or directory
info: FFMPEG VAAPI supported
info: VLC found, VLC video source enabled
info: Loaded Modules:
info: vlc-video.so
info: text-freetype2.so
info: rtmp-services.so
info: obs-x264.so
info: obs-transitions.so
info: obs-outputs.so
info: obs-libfdk.so
info: obs-filters.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-pulseaudio.so
info: linux-jack.so
info: linux-decklink.so
info: linux-capture.so
info: linux-alsa.so
info: image-source.so
info: frontend-tools.so
info: decklink-ouput-ui.so
info: ==== Startup complete ===============================================
error: Service '' not found
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'pulseaudio 12.2'
info: pulse-input: Audio format: s16le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_00_1b.0.analog-stereo.monitor'
info: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_input.usb-Focusrite_Scarlett_Solo_USB-00.analog-stereo'
info: Switched to scene 'Scene'
info: Loaded scenes:
info: - scene 'Scene':
info: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
Segmentation fault (core dumped)
EDIT 1: Logging out of XFCE and back into KDE allowed it to launch. I've yet to see what other desktop environments it does and doesn't work on.
EDIT 2: Cinnamon launches but the ui is too small to read. And the same segfault error on Deepin. And for whatever reason i couldn't load GNOME on this PC so I didn't test it on either GNOME or Budgie.
  • 2019-09-15 15-11-51.txt
