Bug Report Segmentation fault when entering stream key
derekkeats
Since the update yesterday, I have been getting segmentation faults when entering the stream key. This was on Ubuntu 19.10, Gnome. The seg fault happens instantly on hitting apply or OK. It happens whether or not a .config settings folder exists.
Here are the last few lines from starting it in a terminal:
info: [obs-ndi] starting NDI main output with name 'OBS'
info: [obs-ndi] 'OBS': ndi output started
info: [obs-ndi] starting NDI preview output with name 'OBS Preview'
info: [obs-ndi] 'OBS Preview': ndi output started
Attempted path: share/obs/obs-studio/images/overflow.png
Attempted path: /usr/share/obs/obs-studio/images/overflow.png
[swscaler @ 0x7ff1f9246800] deprecated pixel format used, make sure you did set range correctly
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/
Attempted path: /usr/share/obs/obs-studio/themes/
info: Settings changed (stream 1)
info: ------------------------------------------------
Segmentation fault
It did not happen with the previous update as far as I can recall.
Regards
Derek
  • 2020-03-22 16-02-06.txt
Tuna
Probably:
