Bug Report Seg fault whenever press "Apply" or "OK" in File->Settings
ericfont
Whenever I goto File->Settings and either change settings and press "Apply" or don't change settings by press "OK", then I always get a segfault...see attached gdb output, which ends with:
Thread 1 "obs" received signal SIGSEGV, Segmentation fault.
0x00007ffff6127300 in QAbstractButton::isChecked() const () from /usr/lib/libQt5Widgets.so.5
When I run obs again, any new settings are indeed applied.
I'm on a fresh Arch Linux (kernel version 5.5.10) with Qt version 5.14.1.
  • obs-seg-fault-when-apply-settings.txt
Tuna
