01:11:07: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
01:11:07: CUDA loaded successfully
01:11:07: 1 CUDA capable devices found
01:11:07: [ GPU #0 - < GeForce GTX 660 > has Compute SM 3.0, NVENC Available ]
01:11:22: Open Broadcaster Software v0.613b - 32bit (´・ω・`)
01:11:22: -------------------------------
01:11:22: CPU Name: AMD FX(tm)-6350 Six-Core Processor
01:11:22: CPU Speed: 3917MHz
01:11:22: Physical Memory: 4095MB Total, 4095MB Free
01:11:22: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
01:11:22: monitor 1: pos={0, 0}, size={1600, 900}
01:11:22: Windows Version: 6.1 Build 7601 S
01:11:22: Aero is Enabled
01:11:22: OBS Modules:
01:11:22: Base Address Module
01:11:22: 00D30000 OBS.exe
01:11:22: 0F380000 OBSApi.dll
01:11:22: 77EA0000 DShowPlugin.dll
01:11:22: 77E80000 GraphicsCapture.dll
01:11:22: 77E60000 NoiseGate.dll
01:11:22: 777D0000 PSVPlugin.dll
01:11:22: ------------------------------------------
01:11:22: Adapter 1
01:11:22: Video Adapter: NVIDIA GeForce GTX 660
01:11:22: Video Adapter Dedicated Video Memory: 2086469632
01:11:22: Video Adapter Shared System Memory: 2147807232
01:11:22: Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
01:11:22: =====Stream Start: 2014-03-23, 01:11:22===============================================
01:11:22: Multithreaded optimizations: On
01:11:22: Base resolution: 1600x900
01:11:22: Output resolution: 1280x720
01:11:22: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
01:11:22: Audio Format: 48000 Hz
01:11:22: Audio Channels: 2 Ch
01:11:22: Playback device Default
01:11:22: Using desktop audio input: Speakers (High Definition Audio Device)
01:11:22: Using auxilary audio input: Microphone (High Definition Audio Device)
01:11:22: Audio Encoding: AAC
01:11:22: bitrate: 160
01:11:22: Scene buffering time set to 700
01:11:22: Video Encoding: x264
01:11:22: fps: 30
01:11:22: width: 1280, height: 720
01:11:22: preset: veryfast
01:11:22: profile: main
01:11:22: keyint: 250
01:11:22: CBR: yes
01:11:22: CFR: yes
01:11:22: max bitrate: 4000
01:11:22: buffer size: 4000
01:11:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:11:23: New Scene
01:11:23: Using Window Capture
01:11:23: New Scene
01:11:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:11:24: New Scene
01:11:24: Using Window Capture
01:11:24: Using RTMP service: Twitch / Justin.tv
01:11:24: Server selection: rtmp://live-jfk.justin.tv/app
01:11:24: Interface: RNX-N180UBE Wireless LAN 802.11n USB 2.0 Network Adapter (802.11, 144 mbps)
01:11:25: Completed handshake with rtmp://live-jfk.justin.tv/app in 173 ms.
01:11:26: SO_SNDBUF was at 8192
01:11:26: SO_SNDBUF is now 65536
01:52:53: Total frames encoded: 74704, total frames duplicated: 72 (0.10%)
01:52:53: Number of frames skipped due to encoder lag: 2 (0.00%)
01:52:53: Total frames rendered: 74699, number of late frames: 9 (0.01%) (it's okay for some frames to be late)
01:52:53: RTMPPublisher::SocketLoop: Graceful loop exit
01:52:53: Average send payload: 8852 bytes, average send interval: 16 ms
01:52:53: Number of times waited to send: 0, Waited for a total of 0 bytes
01:52:53: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
01:52:53: Number of bytes sent: 1295785697
01:52:53:
01:52:53: Profiler time results:
01:52:53:
01:52:53: ==============================================================
01:52:53: video thread frame - [100%] [avg time: 2.251 ms] [children: 68.5%] [unaccounted: 31.5%]
01:52:53: | scene->Preprocess - [64.9%] [avg time: 1.462 ms]
01:52:53: | GPU download and conversion - [3.6%] [avg time: 0.081 ms] [children: 2.93%] [unaccounted: 0.666%]
01:52:53: | | flush - [1.73%] [avg time: 0.039 ms]
01:52:53: | | CopyResource - [1.07%] [avg time: 0.024 ms]
01:52:53: | | conversion to 4:2:0 - [0.133%] [avg time: 0.003 ms]
01:52:53: Convert444Thread - [100%] [avg time: 1.144 ms] [children: 99.2%] [unaccounted: 0.787%]
01:52:53: | Convert444toNV12 - [99.2%] [avg time: 1.135 ms]
01:52:53: encoder thread frame - [100%] [avg time: 1.561 ms] [children: 3.52%] [unaccounted: 96.5%]
01:52:53: | sending stuff out - [3.52%] [avg time: 0.055 ms]
01:52:53:
01:52:53:
01:52:53: Profiler CPU results:
01:52:53:
01:52:53: video thread frame - [cpu time: avg 0.782 ms, total 58453.6 ms] [avg calls per frame: 1]
01:52:53: | scene->Preprocess - [cpu time: avg 0.062 ms, total 4680.03 ms] [avg calls per frame: 1]
01:52:53: | GPU download and conversion - [cpu time: avg 0.075 ms, total 5616.03 ms] [avg calls per frame: 1]
01:52:53: | | flush - [cpu time: avg 0.036 ms, total 2698.82 ms] [avg calls per frame: 1]
01:52:53: | | CopyResource - [cpu time: avg 0.026 ms, total 1950.01 ms] [avg calls per frame: 1]
01:52:53: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 327.602 ms] [avg calls per frame: 1]
01:52:53: Convert444Thread - [cpu time: avg 1.083 ms, total 80917.7 ms] [avg calls per frame: 1]
01:52:53: | Convert444toNV12 - [cpu time: avg 1.079 ms, total 80574.5 ms] [avg calls per frame: 1]
01:52:53: encoder thread frame - [cpu time: avg 1.033 ms, total 77173.7 ms] [avg calls per frame: 1]
01:52:53: | sending stuff out - [cpu time: avg 0.007 ms, total 592.801 ms] [avg calls per frame: 1]
01:52:53:
01:52:53: =====Stream End: 2014-03-23, 01:52:53=================================================
Is this what you needed?
