Bug Report Screen capture problem
DocVDB
Hi there. I've been streaming for nearly a year now with obs and I'm recently having a problem with the screen capture.
During tests and streams, the screen capture lags a lot, especially when I move window or for any movement. It stutures for about five seconds, shows a frame and stutures again for five seconds no matter what I do.
Also, the compatibility mode on the game capture is greyed out. I can't select the option and I don't know what is causing this.
Here's my log :
16:40:43: CLR host plugin strings not found, dynamically loading 4 strings
16:40:43: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
16:40:43: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
16:40:43: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
16:40:43: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
16:40:43: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
16:40:43: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
16:40:43: CLRHost:: Could not find/load browser settings at location C:\Users\VanDenBan\AppData\Roaming\OBS\pluginData\browser.json
16:40:43: CLRHost:: Exception: System.IO.FileNotFoundException: Impossible de trouver le fichier 'C:\Users\VanDenBan\AppData\Roaming\OBS\pluginData\browser.json'.
16:40:43: Nom de fichier : 'C:\Users\VanDenBan\AppData\Roaming\OBS\pluginData\browser.json'
16:40:43:    à System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
16:40:43:    à System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
16:40:43:    à System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
16:40:43:    à CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
16:40:43: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
16:40:49: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
16:40:49: -------------------------------
16:40:49: CPU Name: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
16:40:49: CPU Speed: 2195MHz
16:40:49: Physical Memory:  4095MB Total, 2427MB Free
16:40:49: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
16:40:49: monitor 1: pos={0, 0}, size={1920, 1080}
16:40:49: Windows Version: 6.2 Build 9200
16:40:49: Aero is Enabled
16:40:49: OBS Modules:
16:40:49: Base Address     Module
16:40:49: 00E90000         OBS.exe
16:40:49: 5B1A0000         OBSApi.dll
16:40:49: 6F820000         CLRHostPlugin.dll
16:40:49: 6F460000         DShowPlugin.dll
16:40:49: 6E940000         GraphicsCapture.dll
16:40:49: 69790000         NoiseGate.dll
16:40:49: 6F440000         PSVPlugin.dll
16:40:49: 6F250000         scenesw.dll
16:40:49: ------------------------------------------
16:40:49: Adapter 1
16:40:49:   Video Adapter: Intel(R) HD Graphics 4000
16:40:49:   Video Adapter Dedicated Video Memory: 100663296
16:40:49:   Video Adapter Shared System Memory: 1778384896
16:40:49:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
16:40:49: Adapter 2
16:40:49:   Video Adapter: NVIDIA GeForce GT 730M
16:40:49:   Video Adapter Dedicated Video Memory: 3221225472
16:40:49:   Video Adapter Shared System Memory: 1073676288
16:40:49: =====Stream Start: 2015-06-25, 16:40:49===============================================
16:40:49:   Multithreaded optimizations: On
16:40:49:   Base resolution: 1920x1080
16:40:49:   Output resolution: 1096x616
16:40:49: Nvidia optimus detected, second adapter selected, ignoring useless second adapter, I guess.
16:40:49: Loading up D3D10 on Intel(R) HD Graphics 4000 (Adapter 1)...
16:40:50: ------------------------------------------
16:40:50: Audio Format: 48000 Hz
16:40:50: Audio Channels: 2 Ch
16:40:50: Playback device {0.0.0.00000000}.{9b7f055b-1b92-4ed7-9ce1-1170897eda02}
16:40:50: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
16:40:50: Global Audio time adjust: 0
16:40:50: Using auxilary audio input: Microphone (Yeti Stereo Microphone)
16:40:50: Mic time offset: 0
16:40:50: Audio Encoding: AAC
16:40:50:     bitrate: 128
16:40:50:     device: HD WebCam,
16:40:50:     device id \\?\usb#vid_04f2&pid_b374&mi_00#7&2c249432&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
16:40:50:     chosen type: MJPG, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
16:40:50:     use buffering: false - 0, fourCC: 'MJPG'
16:40:50:     audio device: Désactiver,
16:40:50:     audio device id Disabled,
16:40:50:     audio time offset 0,
16:40:50:
16:40:50: Using directshow input
16:40:50: Using Monitor Capture
16:40:50: Using bitmap image
16:40:50: Scene buffering time set to 700
16:40:50: Video Encoding: x264
16:40:50:     fps: 30
16:40:50:     width: 1096, height: 616
16:40:50:     preset: veryfast
16:40:50:     profile: main
16:40:50:     keyint: 60
16:40:50:     CBR: yes
16:40:50:     CFR: yes
16:40:50:     max bitrate: 1000
16:40:50:     buffer size: 1000
16:40:50: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
16:40:51: CLRHost:: Browser 2: Status message:
16:40:51: CLRHost:: Browser 1: Status message:
16:40:51: CLRHost:: Browser 2: TypeError: Cannot read property 'length' of undefined @http://www.twitchalerts.com/widgets/alert-box?token=F4ED2C83976C95A21FAD356
16:41:00: Total frames encoded: 276, total frames duplicated: 2 (0.72%)
16:41:00: Total frames rendered: 301, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
16:41:00:
16:41:00: Profiler time results:
16:41:00:
16:41:00: ==============================================================
16:41:00: video thread frame - [100%] [avg time: 10.792 ms] [children: 46.3%] [unaccounted: 53.7%]
16:41:00: | scene->Preprocess - [44.9%] [avg time: 4.849 ms]
16:41:00: | GPU download and conversion - [1.37%] [avg time: 0.148 ms] [children: 1.27%] [unaccounted: 0.102%]
16:41:00: | | flush - [1.15%] [avg time: 0.124 ms]
16:41:00: | | CopyResource - [0.0834%] [avg time: 0.009 ms]
16:41:00: | | conversion to 4:2:0 - [0.0371%] [avg time: 0.004 ms]
16:41:00: Convert444Threads - [100%] [avg time: 0.432 ms] [children: 98.6%] [unaccounted: 1.39%]
16:41:00: | Convert444toNV12 - [98.6%] [avg time: 0.426 ms]
16:41:00: encoder thread frame - [100%] [avg time: 1.093 ms] [children: 0.366%] [unaccounted: 99.6%]
16:41:00: | sending stuff out - [0.366%] [avg time: 0.004 ms]
16:41:00:
16:41:00:
16:41:00: Profiler CPU results:
16:41:00:
16:41:00: video thread frame - [cpu time: avg 1.972 ms, total 593.75 ms] [avg calls per frame: 1]
16:41:00: | scene->Preprocess - [cpu time: avg 0.882 ms, total 265.625 ms] [avg calls per frame: 1]
16:41:00: | GPU download and conversion - [cpu time: avg 0.207 ms, total 62.5 ms] [avg calls per frame: 1]
16:41:00: | | flush - [cpu time: avg 0.103 ms, total 31.25 ms] [avg calls per frame: 1]
16:41:00: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:41:00: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:41:00: Convert444Threads - [cpu time: avg 0.394 ms, total 218.75 ms] [avg calls per frame: 2]
16:41:00: | Convert444toNV12 - [cpu time: avg 0.394 ms, total 218.75 ms] [avg calls per frame: 2]
16:41:00: encoder thread frame - [cpu time: avg 0.509 ms, total 140.625 ms] [avg calls per frame: 1]
16:41:00: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:41:00:
16:41:00: =====Stream End: 2015-06-25, 16:41:00=================================================
16:42:08: CLR host plugin instance deleted; removing dynamically loaded localization strings
16:42:08: Terminating 0x2b40
Last game capture log:
2015-06-25, 16:02:08: we're booting up:
16:02:08: CaptureThread: attached to process ePSXe.exe
16:02:08: GL Present
16:02:08: DirectDraw capture: Windows 8 not supported yet
16:02:08: SwapBuffers(1979784817) Called
16:02:08: NV Capture available
16:02:08: FBO available
16:02:08: setting up gl data
16:02:08: (half life scientist) everything..  seems to be in order
16:02:08: DoGLGPUHook: wglDXOpenDeviceNV failed
16:02:08: ---------------------- Cleared OpenGL Capture ----------------------
16:02:08: DoGLCPUHook: success
16:02:08: wglSwapBuffers(1979784817) Called
16:02:08: successfully capturing gl frames via RAM
16:02:12: DirectDraw capture: Windows 8 not supported yet
16:02:13: stop requested, terminating gl capture
16:02:13: ---------------------- Cleared OpenGL Capture ----------------------
16:02:13: wglSwapBuffers(1979784817) Called
16:02:13: setting up gl data
16:02:13: SwapBuffers(1979784817) Called
16:02:16: DirectDraw capture: Windows 8 not supported yet
Hope anyone can help.
