Scenes Grouping and Sync
snss
Hi!
I have some questions that maybe will become some day implemented in OBS. So... these are my questions:
1. Is there a way to have a tree structure or a way to group the scenes from the Scene section? Example:
Scene 0: Intro
Scene 1: Live Streaming Cams
\--LSC 1: Cam 1
\--LSC 2: Cam 2
Scene 2: Media Sources
\--MS: Clip 1
\--MS: Clip 2
2. Is there a way to sync all the scenes/settings to another computer that runs OBS?(besides exporting and copying everything manually). Can this be done? Is this feasible?
Thank you.
snss
Hi!
Suggestion: Can we have a separator between Scenes like in the attached screen shot?
If the user insert in the Scenes section a Separator/Delimiter then a message should appear in the Sources section saying something like this: "When added scene separator/delimiter the Sources is locked and you can't add another source element."
Thank you.
