Saved Recordings not present?
mothlike
I always used to be able to record my output no problem on my Mac. Today however I was trying to test my audio filters and bizarrely even though OBS gives a notification that recordings have been successfully saved to the location I specified, when I look for them, there are no files there. I checked the path and it was correct. I changed it a couple of times to different locations, same problem. Checked permissions, all granted for OBS. Checked for updates and have the latest version. Checked the log files and that indicates the recording was made but it's not there.... would be most grateful for any help you can offer. Log attached, recording is right at the bottom.
  • 2025-04-17 14-18-49.txt
