RTMPSockBuf_Fill, remote host closed connection
Sml13
Hi,
Been running into this error after updating my obs to latest version. The stream gets disconnected in between and i have to generate a new stream key to resume the stream leading to so many interruptions. I've attached the log file. If anyone could let me know if this is some error because of obs or the stream server I use, that would be so helpful. I've been streaming to vk website.
  • 2022-03-10 04-35-48.txt
Dezsni
I've recently gotten similar issues that I managed to fix. For me it was a routing issue, the data just took a bad path across the internet to the server. I fixed it by using a VPN. It sounds far fetched but it worked for me, I can now stream un-interupted for multiple hours Hopefully this helps anyone else, good luck!
