Question / Help Recording Blurry, Laggy And CPU Usage Is Really High
D
Deleted member 212467
So my specs are:
Processor
Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
Video Card
NVIDIA GeForce GTX 1060 6GB
RAM
16 GB
Operating System
Windows 10
My OBS settings are:
http://prntscr.com/pl78dz
http://prntscr.com/pl78lk
http://prntscr.com/pl78pu
So when I try and record a game or something with these current settings, it says that the CPU usage is too high and I need to change my encoder settings, even when I am just recoding something such as my desktop it is on 10-15% CPU usage, if someone could help me it would be appreciated.
  • 2019-10-18 18-21-37.txt
Tomasz Góral
Game Bar OFF
Game DVR OFF
CPU & GPU too busy for encoding, free up resources, I don't know what you have running and whether you can limit what you are streaming.
D
Game Bar OFF
Game DVR OFF
I already have all of those off, and nothing is running in the background.
D
Deleted member 121471
1) Change colour format back to "NV12", Colour Space to "709", Colour Range to "Partial";
2) Use NVENC (new), "Quality" preset, "CQP" rate control set to 16-23 (lower values = higher quality and diskpace requirements), disable "Lookahead" and "Psycho Visual Tuning";
3) Use "Game capture" instead of "Display capture";
4) Run OBS as administrator;
5) Under Windows 10 settings, "Gaming" category, enable "Game mode" and disable every other option you can find.
Unrelated to your problem, change recording format to .mkv then use File--->Remux recordings, after you end your session, if you really need .mp4 for editing purposes.
D
Ok thanks for the help.
D
Did all them and it now says encoding overloaded? But I can see my CPU % is decreased a lot and is now on 5%
D
Post a new logfile with a recording session and the changed settings.
D
Here you go.
  • 2019-10-18 19-23-00.txt
D
It isn't a constant encoding overload message, it records, and every 10-20 seconds it says encoding overloaded for about 6 seconds.
D
Try capping your ingame FPS with VSYNC, ingame FPS cap or Rivatuner. Other than this, there's nothing else I can see that is wrong with your settings.
