Recent "Encoding Overloaded" Error with AMF "No Output Packet"
plp
Good evening, this is my first post.
I've recently been running into an issue that disconnects my stream without any warning other than seeing that my upload is 0 kb/s and "encoder overloaded". Changing settings doesn't do anything and the only to get things working again is to quit out of OBS and reenter. This only happens when using AMD Hardware encoding, this has never happened with x264 so far. I'm hoping that I don't have a dying graphics card because it is fairly new. I've tried updating my graphics drivers and this still happens.
I'll post the end of the log below:
00:41:14.162: Settings changed (outputs)
00:41:14.162: ------------------------------------------------
00:41:20.903: [AMF] [H264]<Id: 5> Encoder Parameters:
00:41:20.903: [AMF] [H264]<Id: 5> Backend:
00:41:20.903: [AMF] [H264]<Id: 5> Video API: Direct3D 11
00:41:20.903: [AMF] [H264]<Id: 5> Video Adapter: AMD Radeon RX 5700 (VEN_1002/DEV_731f/SUB_38111462/REV_00c4)
00:41:20.903: [AMF] [H264]<Id: 5> OpenCL: Not Supported
00:41:20.903: [AMF] [H264]<Id: 5> Transfer: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> Conversion: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> Multi-Threading: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> Queue Size: 8
00:41:20.903: [AMF] [H264]<Id: 5> Frame:
00:41:20.903: [AMF] [H264]<Id: 5> Format: NV12 601 Partial
00:41:20.903: [AMF] [H264]<Id: 5> Resolution: 1920x1080
00:41:20.903: [AMF] [H264]<Id: 5> Frame Rate: 60/1
00:41:20.903: [AMF] [H264]<Id: 5> Aspect Ratio: 1:1
00:41:20.903: [AMF] [H264]<Id: 5> Static:
00:41:20.903: [AMF] [H264]<Id: 5> Usage: Transcoding
00:41:20.903: [AMF] [H264]<Id: 5> Quality Preset: Quality
00:41:20.903: [AMF] [H264]<Id: 5> Profile: High 4.2
00:41:20.903: [AMF] [H264]<Id: 5> Coding Type: Automatic
00:41:20.903: [AMF] [H264]<Id: 5> Max. Reference Frames: 4
00:41:20.903: [AMF] [H264]<Id: 5> Max. Long-Term Reference Frames: 0
00:41:20.903: [AMF] [H264]<Id: 5> Rate Control:
00:41:20.903: [AMF] [H264]<Id: 5> Method: Constant Bitrate
00:41:20.903: [AMF] [H264]<Id: 5> Pre-Pass Mode: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> QP:
00:41:20.903: [AMF] [H264]<Id: 5> Range: 18 - 51
00:41:20.903: [AMF] [H264]<Id: 5> I-Frame: 22
00:41:20.903: [AMF] [H264]<Id: 5> P-Frame: 22
00:41:20.903: [AMF] [H264]<Id: 5> B-Frame: 22
00:41:20.903: [AMF] [H264]<Id: 5> Bitrate:
00:41:20.903: [AMF] [H264]<Id: 5> Target: 6000000 bit/s
00:41:20.903: [AMF] [H264]<Id: 5> Peak: 6000000 bit/s
00:41:20.903: [AMF] [H264]<Id: 5> Flags:
00:41:20.903: [AMF] [H264]<Id: 5> Filler Data: Enabled
00:41:20.903: [AMF] [H264]<Id: 5> Frame Skipping: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> Period: 0 Frames
00:41:20.903: [AMF] [H264]<Id: 5> Behaviour: Skip every Nth frame
00:41:20.903: [AMF] [H264]<Id: 5> Variance Based Adaptive Quantization: Disabled
00:41:20.903: [AMF] [H264]<Id: 5> Enforce Hypothetical Reference Decoder: Enabled
00:41:20.903: [AMF] [H264]<Id: 5> Video Buffering Verfier:
00:41:20.903: [AMF] [H264]<Id: 5> Buffer Size: 6000000 bits
00:41:20.903: [AMF] [H264]<Id: 5> Initial Fullness: 100 %
00:41:20.903: [AMF] [H264]<Id: 5> Max. Access Unit Size: 0
00:41:20.903: [AMF] [H264]<Id: 5> Picture Control:
00:41:20.903: [AMF] [H264]<Id: 5> IDR: 120 Frames
00:41:20.903: [AMF] [H264]<Id: 5> I: 0 Frames
00:41:20.903: [AMF] [H264]<Id: 5> P: 0 Frames
00:41:20.903: [AMF] [H264]<Id: 5> B: 0 Frames
00:41:20.903: [AMF] [H264]<Id: 5> Header Insertion Spacing: 0
00:41:20.903: [AMF] [H264]<Id: 5> GOP Alignment: Enabled
00:41:20.903: [AMF] [H264]<Id: 5> Deblocking Filter: Enabled
00:41:20.903: [AMF] [H264]<Id: 5> Motion Estimation: Quarter, Half
00:41:20.903: [AMF] [H264]<Id: 5> B-Frames:
00:41:20.903: [AMF] [H264]<Id: 5> Pattern: 0
00:41:20.904: [AMF] [H264]<Id: 5> Delta QP: N/A
00:41:20.904: [AMF] [H264]<Id: 5> Reference: Disabled
00:41:20.904: [AMF] [H264]<Id: 5> Reference Delta QP: N/A
00:41:20.904: [AMF] [H264]<Id: 5> Intra-Refresh:
00:41:20.904: [AMF] [H264]<Id: 5> Number of Macroblocks Per Slot: 0
00:41:20.904: [AMF] [H264]<Id: 5> Number of Stripes: 1
00:41:20.905: [CoreAudio AAC: 'avc_aac_stream']: settings:
00:41:20.905: mode: AAC
00:41:20.905: bitrate: 320
00:41:20.905: sample rate: 48000
00:41:20.905: cbr: on
00:41:20.905: output buffer: 1536
00:41:20.905: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live.restream.io/live...
00:41:20.906: [AMF] [H264]<Id: 5> Encoder Parameters:
00:41:20.906: [AMF] [H264]<Id: 5> Backend:
00:41:20.907: [AMF] [H264]<Id: 5> Video API: Direct3D 11
00:41:20.907: [AMF] [H264]<Id: 5> Video Adapter: AMD Radeon RX 5700 (VEN_1002/DEV_731f/SUB_38111462/REV_00c4)
00:41:20.907: [AMF] [H264]<Id: 5> OpenCL: Not Supported
00:41:20.907: [AMF] [H264]<Id: 5> Transfer: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Conversion: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Multi-Threading: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Queue Size: 8
00:41:20.907: [AMF] [H264]<Id: 5> Frame:
00:41:20.907: [AMF] [H264]<Id: 5> Format: NV12 601 Partial
00:41:20.907: [AMF] [H264]<Id: 5> Resolution: 1920x1080
00:41:20.907: [AMF] [H264]<Id: 5> Frame Rate: 60/1
00:41:20.907: [AMF] [H264]<Id: 5> Aspect Ratio: 1:1
00:41:20.907: [AMF] [H264]<Id: 5> Static:
00:41:20.907: [AMF] [H264]<Id: 5> Usage: Transcoding
00:41:20.907: [AMF] [H264]<Id: 5> Quality Preset: Quality
00:41:20.907: [AMF] [H264]<Id: 5> Profile: High 4.2
00:41:20.907: [AMF] [H264]<Id: 5> Coding Type: Automatic
00:41:20.907: [AMF] [H264]<Id: 5> Max. Reference Frames: 4
00:41:20.907: [AMF] [H264]<Id: 5> Max. Long-Term Reference Frames: 0
00:41:20.907: [AMF] [H264]<Id: 5> Rate Control:
00:41:20.907: [AMF] [H264]<Id: 5> Method: Constant Bitrate
00:41:20.907: [AMF] [H264]<Id: 5> Pre-Pass Mode: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> QP:
00:41:20.907: [AMF] [H264]<Id: 5> Range: 18 - 51
00:41:20.907: [AMF] [H264]<Id: 5> I-Frame: 22
00:41:20.907: [AMF] [H264]<Id: 5> P-Frame: 22
00:41:20.907: [AMF] [H264]<Id: 5> B-Frame: 22
00:41:20.907: [AMF] [H264]<Id: 5> Bitrate:
00:41:20.907: [AMF] [H264]<Id: 5> Target: 6000000 bit/s
00:41:20.907: [AMF] [H264]<Id: 5> Peak: 6000000 bit/s
00:41:20.907: [AMF] [H264]<Id: 5> Flags:
00:41:20.907: [AMF] [H264]<Id: 5> Filler Data: Enabled
00:41:20.907: [AMF] [H264]<Id: 5> Frame Skipping: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Period: 0 Frames
00:41:20.907: [AMF] [H264]<Id: 5> Behaviour: Skip every Nth frame
00:41:20.907: [AMF] [H264]<Id: 5> Variance Based Adaptive Quantization: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Enforce Hypothetical Reference Decoder: Enabled
00:41:20.907: [AMF] [H264]<Id: 5> Video Buffering Verfier:
00:41:20.907: [AMF] [H264]<Id: 5> Buffer Size: 6000000 bits
00:41:20.907: [AMF] [H264]<Id: 5> Initial Fullness: 100 %
00:41:20.907: [AMF] [H264]<Id: 5> Max. Access Unit Size: 0
00:41:20.907: [AMF] [H264]<Id: 5> Picture Control:
00:41:20.907: [AMF] [H264]<Id: 5> IDR: 120 Frames
00:41:20.907: [AMF] [H264]<Id: 5> I: 0 Frames
00:41:20.907: [AMF] [H264]<Id: 5> P: 0 Frames
00:41:20.907: [AMF] [H264]<Id: 5> B: 0 Frames
00:41:20.907: [AMF] [H264]<Id: 5> Header Insertion Spacing: 0
00:41:20.907: [AMF] [H264]<Id: 5> GOP Alignment: Enabled
00:41:20.907: [AMF] [H264]<Id: 5> Deblocking Filter: Enabled
00:41:20.907: [AMF] [H264]<Id: 5> Motion Estimation: Quarter, Half
00:41:20.907: [AMF] [H264]<Id: 5> B-Frames:
00:41:20.907: [AMF] [H264]<Id: 5> Pattern: 0
00:41:20.907: [AMF] [H264]<Id: 5> Delta QP: N/A
00:41:20.907: [AMF] [H264]<Id: 5> Reference: Disabled
00:41:20.907: [AMF] [H264]<Id: 5> Reference Delta QP: N/A
00:41:20.907: [AMF] [H264]<Id: 5> Intra-Refresh:
00:41:20.907: [AMF] [H264]<Id: 5> Number of Macroblocks Per Slot: 0
00:41:20.907: [AMF] [H264]<Id: 5> Number of Stripes: 1
00:41:20.909: [CoreAudio AAC: '4 All']: settings:
00:41:20.909: mode: AAC
00:41:20.909: bitrate: 320
00:41:20.909: sample rate: 48000
00:41:20.909: cbr: on
00:41:20.909: output buffer: 1536
00:41:20.912: ==== Replay Buffer Start ===========================================
00:41:20.939: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GbE Family Controller (ethernet, 1000 mbps)
00:41:21.068: [AMF] <Id: 5> Initial Frame Latency is 125331300 nanoseconds.
00:41:21.789: [rtmp stream: 'adv_stream'] Connection to rtmp://live.restream.io/live successful
00:41:21.789: [rtmp stream: 'adv_stream'] New socket loop enabled by user
00:41:21.790: ==== Streaming Start ===============================================
00:41:23.128: socket_thread_windows: Increasing send buffer to ISB 131072 (buffer: 16999 / 808960)
00:41:23.136: socket_thread_windows: Increasing send buffer to ISB 262144 (buffer: 0 / 808960)
00:41:25.099: socket_thread_windows: Increasing send buffer to ISB 524288 (buffer: 0 / 808960)
00:41:28.570: User switched to scene 'Mushihimesama Futari'
00:41:28.584: [game-capture: 'Plane9 Visualizer'] attempting to hook process: Plane9.exe
00:41:28.636: [game-capture: 'Plane9 Visualizer'] gl shared texture capture successful
00:41:28.645: [game-capture: 'Plane9 Visualizer'] shared texture capture successful
00:41:29.165: warning: Could not update timestamps for skipped samples.
00:42:10.241: User added filter 'Gain MAME Mushi' (gain_filter) to source '1 Desktop Audio'
00:43:55.984: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.021: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.060: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.098: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.136: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.175: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.213: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.251: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.288: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.288: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.323: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.323: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.359: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.359: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.394: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.394: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.431: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.431: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.466: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.466: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.501: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.501: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.537: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.537: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.572: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.572: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.608: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.608: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.644: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:43:56.644: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:43:56.681: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.493: Last log entry repeated for 1831 more lines
00:44:29.493: socket_thread_windows: Received FD_CLOSE, 33501 ms since last send (buffer: 0 / 808960)
00:44:29.493: socket_thread_windows: Aborting due to FD_CLOSE, error 0
00:44:29.527: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.527: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.564: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.564: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.600: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.600: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.635: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.635: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.671: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.671: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.707: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.707: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.743: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.743: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.778: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.778: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.814: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.814: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.850: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.850: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.885: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.885: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.921: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.921: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.957: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.957: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:29.993: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:29.993: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:30.029: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
00:44:30.029: [AMF] <Id: 5> No output Packet, encoder is overloaded!
00:44:30.065: [AMF] <Id: 5> Input Queue is full, encoder is overloaded!
Can someone help me? Attached is the full log.
  • 2020-06-07 00-35-53.txt
qhobbes
1.The version of Windows you are running has a limitation which causes performance issues in hardware accelerated applications (such as games) if multiple monitors with different refresh rates are present. Your system's monitors have 3 different refresh rates, so you are affected by this limitation. You can fix this performance problem by setting all displays to use the same refresh rate.
This problem is fixed in the '2004' release of Windows 10. Update your Windows.
2. In Windows 10 versions 1809 and newer, we recommend that "Game Mode" be enabled for maximum gaming performance. Game Mode can be enabled via the Windows 10 "Settings" app, under Gaming > Game Mode
3. Display and Game Capture Sources interfere with each other. Never put them in the same scene
4. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other. You can use the same Game Capture for all your games! If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
plp
1. If I switch to x264 it does not have any issues. If this error was occuring because of my Windows version, would it be crashing on x264? Unfortunately I can only use x264 when I am using my capture card, its not powerful enough to do x264 and PC games at the same time.
I'm not able to upgrade to the 2004 release of Windows since it says my computer isn't ready for it yet. Is there a stable version of Windows that I could rollback to?
2. I've enabled Game Mode and the encoder still got overloaded and disconnected my stream.
3. I've removed display and game capture sources from the same scene and the encoder still got overloaded.
4. I have multiple game capture sources on the same scene because they use 3 different aspect ratios: 16:9, 4:3, and 3:4 so I would prefer not to make any changes since it has not been having issues for years until recently -- but I made sure to stay on a single scene that did not have multiple game sources after going live and the encoder still got overloaded.
Here is a new log:
03:54:24.916: ------------------------------------------------
03:54:24.933: [game-capture: 'Game Capture 4:3'] attempting to hook process: pcsx2.exe
03:54:24.948: [game-capture: 'Game Capture 4:3'] d3d11 shared texture capture successful
03:54:25.049: [game-capture: 'Game Capture 4:3'] shared texture capture successful
03:54:32.981: [AMF] [H264]<Id: 3> Encoder Parameters:
03:54:32.981: [AMF] [H264]<Id: 3> Backend:
03:54:32.981: [AMF] [H264]<Id: 3> Video API: Direct3D 11
03:54:32.981: [AMF] [H264]<Id: 3> Video Adapter: AMD Radeon RX 5700 (VEN_1002/DEV_731f/SUB_38111462/REV_00c4)
03:54:32.981: [AMF] [H264]<Id: 3> OpenCL: Not Supported
03:54:32.981: [AMF] [H264]<Id: 3> Transfer: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Conversion: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Multi-Threading: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Queue Size: 8
03:54:32.981: [AMF] [H264]<Id: 3> Frame:
03:54:32.981: [AMF] [H264]<Id: 3> Format: NV12 601 Partial
03:54:32.981: [AMF] [H264]<Id: 3> Resolution: 1920x1080
03:54:32.981: [AMF] [H264]<Id: 3> Frame Rate: 60/1
03:54:32.981: [AMF] [H264]<Id: 3> Aspect Ratio: 1:1
03:54:32.981: [AMF] [H264]<Id: 3> Static:
03:54:32.981: [AMF] [H264]<Id: 3> Usage: Transcoding
03:54:32.981: [AMF] [H264]<Id: 3> Quality Preset: Quality
03:54:32.981: [AMF] [H264]<Id: 3> Profile: High 4.2
03:54:32.981: [AMF] [H264]<Id: 3> Coding Type: Automatic
03:54:32.981: [AMF] [H264]<Id: 3> Max. Reference Frames: 4
03:54:32.981: [AMF] [H264]<Id: 3> Max. Long-Term Reference Frames: 0
03:54:32.981: [AMF] [H264]<Id: 3> Rate Control:
03:54:32.981: [AMF] [H264]<Id: 3> Method: Constant Bitrate
03:54:32.981: [AMF] [H264]<Id: 3> Pre-Pass Mode: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> QP:
03:54:32.981: [AMF] [H264]<Id: 3> Range: 18 - 51
03:54:32.981: [AMF] [H264]<Id: 3> I-Frame: 22
03:54:32.981: [AMF] [H264]<Id: 3> P-Frame: 22
03:54:32.981: [AMF] [H264]<Id: 3> B-Frame: 22
03:54:32.981: [AMF] [H264]<Id: 3> Bitrate:
03:54:32.981: [AMF] [H264]<Id: 3> Target: 6000000 bit/s
03:54:32.981: [AMF] [H264]<Id: 3> Peak: 6000000 bit/s
03:54:32.981: [AMF] [H264]<Id: 3> Flags:
03:54:32.981: [AMF] [H264]<Id: 3> Filler Data: Enabled
03:54:32.981: [AMF] [H264]<Id: 3> Frame Skipping: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Period: 0 Frames
03:54:32.981: [AMF] [H264]<Id: 3> Behaviour: Skip every Nth frame
03:54:32.981: [AMF] [H264]<Id: 3> Variance Based Adaptive Quantization: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Enforce Hypothetical Reference Decoder: Enabled
03:54:32.981: [AMF] [H264]<Id: 3> Video Buffering Verfier:
03:54:32.981: [AMF] [H264]<Id: 3> Buffer Size: 6000000 bits
03:54:32.981: [AMF] [H264]<Id: 3> Initial Fullness: 100 %
03:54:32.981: [AMF] [H264]<Id: 3> Max. Access Unit Size: 0
03:54:32.981: [AMF] [H264]<Id: 3> Picture Control:
03:54:32.981: [AMF] [H264]<Id: 3> IDR: 120 Frames
03:54:32.981: [AMF] [H264]<Id: 3> I: 0 Frames
03:54:32.981: [AMF] [H264]<Id: 3> P: 0 Frames
03:54:32.981: [AMF] [H264]<Id: 3> B: 0 Frames
03:54:32.981: [AMF] [H264]<Id: 3> Header Insertion Spacing: 0
03:54:32.981: [AMF] [H264]<Id: 3> GOP Alignment: Enabled
03:54:32.981: [AMF] [H264]<Id: 3> Deblocking Filter: Enabled
03:54:32.981: [AMF] [H264]<Id: 3> Motion Estimation: Quarter, Half
03:54:32.981: [AMF] [H264]<Id: 3> B-Frames:
03:54:32.981: [AMF] [H264]<Id: 3> Pattern: 0
03:54:32.981: [AMF] [H264]<Id: 3> Delta QP: N/A
03:54:32.981: [AMF] [H264]<Id: 3> Reference: Disabled
03:54:32.981: [AMF] [H264]<Id: 3> Reference Delta QP: N/A
03:54:32.981: [AMF] [H264]<Id: 3> Intra-Refresh:
03:54:32.981: [AMF] [H264]<Id: 3> Number of Macroblocks Per Slot: 0
03:54:32.981: [AMF] [H264]<Id: 3> Number of Stripes: 1
03:54:32.983: [CoreAudio AAC: 'avc_aac_stream']: settings:
03:54:32.983: mode: AAC
03:54:32.983: bitrate: 320
03:54:32.983: sample rate: 48000
03:54:32.983: cbr: on
03:54:32.983: output buffer: 1536
03:54:32.984: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live.restream.io/live...
03:54:32.985: [AMF] [H264]<Id: 3> Encoder Parameters:
03:54:32.985: [AMF] [H264]<Id: 3> Backend:
03:54:32.985: [AMF] [H264]<Id: 3> Video API: Direct3D 11
03:54:32.985: [AMF] [H264]<Id: 3> Video Adapter: AMD Radeon RX 5700 (VEN_1002/DEV_731f/SUB_38111462/REV_00c4)
03:54:32.985: [AMF] [H264]<Id: 3> OpenCL: Not Supported
03:54:32.985: [AMF] [H264]<Id: 3> Transfer: Disabled
03:54:32.985: [AMF] [H264]<Id: 3> Conversion: Disabled
03:54:32.985: [AMF] [H264]<Id: 3> Multi-Threading: Disabled
03:54:32.985: [AMF] [H264]<Id: 3> Queue Size: 8
03:54:32.985: [AMF] [H264]<Id: 3> Frame:
03:54:32.985: [AMF] [H264]<Id: 3> Format: NV12 601 Partial
03:54:32.985: [AMF] [H264]<Id: 3> Resolution: 1920x1080
03:54:32.985: [AMF] [H264]<Id: 3> Frame Rate: 60/1
03:54:32.985: [AMF] [H264]<Id: 3> Aspect Ratio: 1:1
03:54:32.985: [AMF] [H264]<Id: 3> Static:
03:54:32.985: [AMF] [H264]<Id: 3> Usage: Transcoding
03:54:32.985: [AMF] [H264]<Id: 3> Quality Preset: Quality
03:54:32.985: [AMF] [H264]<Id: 3> Profile: High 4.2
03:54:32.985: [AMF] [H264]<Id: 3> Coding Type: Automatic
03:54:32.985: [AMF] [H264]<Id: 3> Max. Reference Frames: 4
03:54:32.985: [AMF] [H264]<Id: 3> Max. Long-Term Reference Frames: 0
03:54:32.986: [AMF] [H264]<Id: 3> Rate Control:
03:54:32.986: [AMF] [H264]<Id: 3> Method: Constant Bitrate
03:54:32.986: [AMF] [H264]<Id: 3> Pre-Pass Mode: Disabled
03:54:32.986: [AMF] [H264]<Id: 3> QP:
03:54:32.986: [AMF] [H264]<Id: 3> Range: 18 - 51
03:54:32.986: [AMF] [H264]<Id: 3> I-Frame: 22
03:54:32.986: [AMF] [H264]<Id: 3> P-Frame: 22
03:54:32.986: [AMF] [H264]<Id: 3> B-Frame: 22
03:54:32.986: [AMF] [H264]<Id: 3> Bitrate:
03:54:32.986: [AMF] [H264]<Id: 3> Target: 6000000 bit/s
03:54:32.986: [AMF] [H264]<Id: 3> Peak: 6000000 bit/s
03:54:32.986: [AMF] [H264]<Id: 3> Flags:
03:54:32.986: [AMF] [H264]<Id: 3> Filler Data: Enabled
03:54:32.986: [AMF] [H264]<Id: 3> Frame Skipping: Disabled
03:54:32.986: [AMF] [H264]<Id: 3> Period: 0 Frames
03:54:32.986: [AMF] [H264]<Id: 3> Behaviour: Skip every Nth frame
03:54:32.986: [AMF] [H264]<Id: 3> Variance Based Adaptive Quantization: Disabled
03:54:32.986: [AMF] [H264]<Id: 3> Enforce Hypothetical Reference Decoder: Enabled
03:54:32.986: [AMF] [H264]<Id: 3> Video Buffering Verfier:
03:54:32.986: [AMF] [H264]<Id: 3> Buffer Size: 6000000 bits
03:54:32.986: [AMF] [H264]<Id: 3> Initial Fullness: 100 %
03:54:32.986: [AMF] [H264]<Id: 3> Max. Access Unit Size: 0
03:54:32.986: [AMF] [H264]<Id: 3> Picture Control:
03:54:32.986: [AMF] [H264]<Id: 3> IDR: 120 Frames
03:54:32.986: [AMF] [H264]<Id: 3> I: 0 Frames
03:54:32.986: [AMF] [H264]<Id: 3> P: 0 Frames
03:54:32.986: [AMF] [H264]<Id: 3> B: 0 Frames
03:54:32.986: [AMF] [H264]<Id: 3> Header Insertion Spacing: 0
03:54:32.986: [AMF] [H264]<Id: 3> GOP Alignment: Enabled
03:54:32.986: [AMF] [H264]<Id: 3> Deblocking Filter: Enabled
03:54:32.986: [AMF] [H264]<Id: 3> Motion Estimation: Quarter, Half
03:54:32.986: [AMF] [H264]<Id: 3> B-Frames:
03:54:32.986: [AMF] [H264]<Id: 3> Pattern: 0
03:54:32.986: [AMF] [H264]<Id: 3> Delta QP: N/A
03:54:32.986: [AMF] [H264]<Id: 3> Reference: Disabled
03:54:32.986: [AMF] [H264]<Id: 3> Reference Delta QP: N/A
03:54:32.986: [AMF] [H264]<Id: 3> Intra-Refresh:
03:54:32.986: [AMF] [H264]<Id: 3> Number of Macroblocks Per Slot: 0
03:54:32.986: [AMF] [H264]<Id: 3> Number of Stripes: 1
03:54:32.988: [CoreAudio AAC: '4 All']: settings:
03:54:32.988: mode: AAC
03:54:32.988: bitrate: 320
03:54:32.988: sample rate: 48000
03:54:32.988: cbr: on
03:54:32.988: output buffer: 1536
03:54:32.994: ==== Replay Buffer Start ===========================================
03:54:33.023: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GbE Family Controller (ethernet, 1000 mbps)
03:54:33.159: [AMF] <Id: 3> Initial Frame Latency is 114903200 nanoseconds.
03:54:34.031: [rtmp stream: 'adv_stream'] Connection to rtmp://live.restream.io/live successful
03:54:34.031: [rtmp stream: 'adv_stream'] New socket loop enabled by user
03:54:34.031: ==== Streaming Start ===============================================
03:54:37.178: socket_thread_windows: Increasing send buffer to ISB 131072 (buffer: 121946 / 808960)
03:54:39.178: socket_thread_windows: Increasing send buffer to ISB 262144 (buffer: 48910 / 808960)
03:54:45.182: socket_thread_windows: Increasing send buffer to ISB 524288 (buffer: 0 / 808960)
03:57:01.375: User switched to scene '4:3 Scene'
03:57:01.392: A sprite cannot be drawn without a width/height
03:57:01.988: warning: Could not update timestamps for skipped samples.
04:09:07.208: socket_thread_windows: Increasing send buffer to ISB 1048576 (buffer: 0 / 808960)
04:13:01.486: User added filter 'Color Correction' (color_filter) to source 'Black Marble bkg'
05:39:57.507: [AMF] <Id: 3> No output Packet, encoder is overloaded!
05:39:57.550: [AMF] <Id: 3> Input Queue is full, encoder is overloaded!
05:40:30.704: Last log entry repeated for 1573 more lines
05:40:30.704: socket_thread_windows: Received FD_CLOSE, 33500 ms since last send (buffer: 0 / 808960)
05:40:30.704: socket_thread_windows: Aborting due to FD_CLOSE, error 0
05:40:30.739: [AMF] <Id: 3> Input Queue is full, encoder is overloaded!
05:40:30.739: [AMF] <Id: 3> No output Packet, encoder is overloaded!
06:03:06.501: Last log entry repeated for 70567 more lines
06:03:06.501: [game-capture: 'Game Capture 4:3'] capture window no longer exists, terminating capture
06:03:06.502: [game-capture: 'Game Capture 4:3'] capture stopped
06:03:06.504: [AMF] <Id: 3> Input Queue is full, encoder is overloaded!
06:03:06.504: [AMF] <Id: 3> No output Packet, encoder is overloaded!
06:03:06.515: [game-capture: 'Game Capture 4:3'] attempting to hook process: pcsx2.exe
06:03:06.530: [game-capture: 'Game Capture 4:3'] capture stopped
06:03:06.539: [AMF] <Id: 3> Input Queue is full, encoder is overloaded!
06:03:06.539: [AMF] <Id: 3> No output Packet, encoder is overloaded!
I appreciate your help.
plp
I forgot to ask these questions in my last post --
Recently I set up a replay buffer for instant replay. I haven't tried turning this off and testing yet but that is the only recent change I can remember making in OBS other than the gfx card update. Could replay buffer be causing this weird error?
I am able to use Quicksync H.264 but will this affect my computers performance the same way that x264 does?
Thanks again.
qhobbes
1. Your log is incomplete.
2. If you cannot update your Windows then set your all refresh rates on your attached monitors to the same value.
3. Quicksync is a hardware encoder and should not drastically impact your computers performance.
plp
Hi all,
I was able to resolve my issue by switching to Quicksync. I am still using different refresh rates on my monitors, using multiple game capture sources, and using display and game capture in the same scene without any issues.
ZapojKabel
Hi there, i have the same problem there, three days ago everything working fine, now I streaming 1 or 2 hours and my bitrate going done from 6000 to 2000 or 0 for no reasons (internet conection is fine), when i restart stream everything working fine for hour ad the same problem again
  • 2020-11-05 00-38-42 log.txt
qhobbes
@ZapojKabel get the issues mentioned in the log analyzer out of the way first and let us know if you're still having issues:
1. If available via Windows Update, update to Windows 2004 or 20H2 per https://obsproject.com/blog/five-simple-tips-for-new-streamers
2. To ensure that OBS Studio has the hardware resources it needs for realtime streaming and recording, we recommend disabling the "Game DVR Background Recording" feature via these instructions.
3. Your gigabit-capable network card is only connecting at 100mbps. This may indicate a bad network cable or outdated router / switch which could be impacting network performance.
4. At least one of your audio devices has a sample rate that doesn't match the rest. This can result in audio drift over time or sound distortion. Check your audio devices in Windows settings (both Playback and Recording) and ensure the Default Format (under Advanced) is consistent. 48000 Hz is recommended.
OBS Sample Rate: 44100 Hz
VoiceMeeter Aux Output (VB-Audio VoiceMeeter AUX VAIO): 44100 Hz
VoiceMeeter VAIO3 Input (VB-Audio VoiceMeeter VAIO3): 48000 Hz
VoiceMeeter Input (VB-Audio VoiceMeeter VAIO): 48000 Hz
OBS Settings, Audio, General, Change Sample Rate to 48 kHz
This log is only 14 minutes long and doesn't show the issue.
ZapojKabel
@qhobbes Thanks for quick response..
1) i have version Windows 2009 which is the latest release (20H2)
2) i disabled these functions
3) well my internet conection is 100/100 so there is no need to have a router with a maximum speed of 1 gbit, and when this happend a tested my speed and stability of my network (even contact my ISP) and everything was fine upload was 100Mbits
4) i fix these settings
I thought the mistake was what was written from the middle of the log where it is written
00:51:49.075: [AMF] <Id: 3> No output Packet, encoder is overloaded!
00:51:49.109: [AMF] <Id: 3> Input Queue is full, encoder is overloaded!
Anyway i fix number two and four this morning and let you know.
Once again, thanks for help
rockbottom
Why do you have StreamFX installed?
Why don't you fix Tuna?
Why haven't you fixed your ethernet connection?
LAME
CLUELESS
Sorry, all I see is a waste of effort/time, you don't deserve help...
