Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) II X4 965 Processor
CPU Speed: 3398MHz
Physical Memory: 2047MB Total, 1525MB Free
stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
Windows Version: 6.0 Build 6002 S
Aero is Disabled
Adapter 1
Video Adapter: ATI Radeon HD 5670
Video Adapter Dedicated Video Memory: 1064939520
Video Adapter Shared System Memory: 1341747200
Base resolution: 1600x900
Output resolution: 1600x900
Loading up D3D10...
Using auxilary audio input: Mikrofoni (2- USB PnP Sound Device)
Audio Encoding: MP3
bitrate: 128
Video Encoding: x264
fps: 30
width: 1600, height: 900
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
New Scene
Warning -- DShowPlugin: Could not get device video pin
Warning -- D3D10Texture::CreateTexture: CreateTexture2D failed, result = 0x80070057
Using directshow input
Using Monitor Capture
Total frames rendered: 5532, number of frames that lagged: 23 (0.42%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 110, number of frames that lagged: 4 (3.64%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Using RTMP service: Own3D.tv
Server selection:
rtmp://live.eu.own3d.tv/live
bufferTime: 1401, outputRateWindowTime: 1000, dropThreshold: 1901
Warning -- Capture BitBlt failed.. just so you know
Total frames rendered: 89101, number of frames that lagged: 1077 (1.21%) (it's okay for some frames to lag)
Number of b-frames dropped: 118 (0.058%), Number of p-frames dropped: 118 (0.058%), Total 236 (0.12%)
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Server selection:
bufferTime: 1491, outputRateWindowTime: 1000, dropThreshold: 1991
RTMPPublisher::BufferedSend: Buffer is full (144341 / 144384 bytes), waiting to send 423 bytes
RTMPPublisher::BufferedSend: Buffer is full (144337 / 144384 bytes), waiting to send 427 bytes
Total frames rendered: 155633, number of frames that lagged: 3980 (2.56%) (it's okay for some frames to lag)
Number of b-frames dropped: 679 (0.19%), Number of p-frames dropped: 668 (0.18%), Total 1347 (0.37%)
Profiler results:
frame - [100%] [avg time: 21.058 ms] [avg calls per frame: 1] [children: 95.8%] [unaccounted: 4.17%]
| scene->Preprocess - [50.3%] [avg time: 10.592 ms] [avg calls per frame: 0]
| video encoding and uploading - [45.5%] [avg time: 9.588 ms] [avg calls per frame: 1] [children: 18.4%] [unaccounted: 27.2%]
| | CopyResource - [0.494%] [avg time: 0.104 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.038%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | call to encoder - [17.7%] [avg time: 3.726 ms] [avg calls per frame: 0]
| | sending stuff out - [0.147%] [avg time: 0.031 ms] [avg calls per frame: 0]
