Hi there, Is it possible to use quicksync while running OBS on the Nvidia GPU. I have to use optimus this way because i want to use Gamecapture to stream LoL. The problem then is that OBS doesnt seem to find my HD3000.
Edit: I have included a log file where OBS is running on the Intel GPU:
22:53:16: Open Broadcaster Software v0.541b - 64bit ( ^ω^)
22:53:16: -------------------------------
22:53:16: CPU Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
22:53:16: CPU Speed: 2195MHz
22:53:16: Physical Memory: 8085MB Total, 4961MB Free
22:53:16: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
22:53:16: monitor 1: pos={0, 0}, size={1920, 1080}
22:53:16: monitor 2: pos={-1920, 0}, size={1920, 1080}
22:53:16: Windows Version: 6.2 Build 9200
22:53:16: Aero is Enabled
22:53:16: OBS Modules:
22:53:16: Base Address Module
22:53:16: 00000000E7670000 OBS.exe
22:53:16: 0000000045F60000 OBSApi.dll
22:53:16: 000000004E850000 DShowPlugin.dll
22:53:16: 0000000050E90000 GraphicsCapture.dll
22:53:16: 000000004E420000 NoiseGate.dll
22:53:16: 000000004D8E0000 PSVPlugin.dll
22:53:16: ------------------------------------------
22:53:16: Adapter 1
22:53:16: Video Adapter: NVIDIA GeForce GT 525M
22:53:16: Video Adapter Dedicated Video Memory: 1019867136
22:53:16: Video Adapter Shared System Memory: 3220975616
22:53:16: Adapter 2
22:53:16: Adapter 3
22:53:16: Video Adapter: Microsoft Basic Render Driver
22:53:16: =====Stream Start: 2013-07-11, 22:53:16===============================================
22:53:16: Multithreaded optimizations: On
22:53:16: Base resolution: 1920x1080
22:53:16: Output resolution: 1536x864
22:53:16: Loading up D3D10...
22:53:16: Playback device Default
22:53:16: Using desktop audio input: Speakers (Realtek High Definition Audio)
22:53:17: ------------------------------------------
22:53:17: Using auxilary audio input: Microphone (Realtek High Definition Audio)
22:53:17: Audio Encoding: AAC
22:53:17: bitrate: 128
22:53:17: Using Window Capture
22:53:17: Using bitmap image
22:53:17: Failed to initialize QSV hardware session
22:53:17: Video Encoding: x264
22:53:17: fps: 30
22:53:17: width: 1536, height: 864
22:53:17: preset: veryfast
22:53:17: CBR: no
22:53:17: CFR: no
22:53:17: max bitrate: 4000
22:53:17: buffer size: 4000
22:53:17: quality: 8
13:06:33: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
13:06:33: -------------------------------
13:06:33: CPU Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
13:06:33: CPU Speed: 2195MHz
13:06:33: Physical Memory: 4095MB Total, 4095MB Free
13:06:33: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
13:06:33: monitor 1: pos={0, 0}, size={1920, 1080}
13:06:33: monitor 2: pos={-1920, 0}, size={1536, 864}
13:06:33: Windows Version: 6.2 Build 9200
13:06:33: Aero is Enabled
13:06:33: OBS Modules:
13:06:33: Base Address Module
13:06:33: 008B0000 OBS.exe
13:06:33: 72FA0000 OBSApi.dll
13:06:33: 74400000 DShowPlugin.dll
13:06:33: 741F0000 GraphicsCapture.dll
13:06:33: 741D0000 NoiseGate.dll
13:06:33: 72F20000 PSVPlugin.dll
13:06:33: ------------------------------------------
13:06:33: Adapter 1
13:06:33: Video Adapter: Intel(R) HD Graphics 3000
13:06:33: Video Adapter Dedicated Video Memory: 33554432
13:06:33: Video Adapter Shared System Memory: 1711276032
13:06:33: Adapter 2
13:06:33: Video Adapter: NVIDIA GeForce GT 525M
13:06:33: Video Adapter Dedicated Video Memory: 1019867136
13:06:33: Video Adapter Shared System Memory: 3220975616
13:06:33: =====Stream Start: 2013-07-12, 13:06:33===============================================
13:06:33: Multithreaded optimizations: On
13:06:33: Base resolution: 1920x1080
13:06:33: Output resolution: 1536x864
13:06:33: Loading up D3D10...
13:06:33: Playback device Default
13:06:33: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:06:33: Using auxilary audio input: Microphone (Realtek High Definition Audio)
13:06:33: Audio Encoding: AAC
13:06:33: bitrate: 128
13:06:34: Using Window Capture
13:06:34: Using bitmap image
13:06:34: Found QSV hardware support
13:06:34: ------------------------------------------
13:06:34: QSV version 1.4 using MFX_IMPL_HARDWARE_ANY | MFX_IMPL_VIA_ANY (actual: MFX_IMPL_HARDWARE | MFX_IMPL_VIA_D3D9)
13:06:34: Using 13 encode tasks
13:06:34: Video Encoding: QSV
13:06:34: fps: 30
13:06:34: width: 1536, height: 864
13:06:34: target-usage: MFX_TARGETUSAGE_BEST_QUALITY
13:06:34: CBR: no
13:06:34: CFR: no
13:06:34: max bitrate: 4000
13:06:34: buffer size: 4000
13:06:50: Total frames rendered: 495, number of frames that lagged: 4 (0.81%) (it's okay for some frames to lag)
13:06:50: =====Stream End: 2013-07-12, 13:06:50=================================================
13:06:56:
13:06:56: Profiler results:
13:06:56:
13:06:56: ==============================================================
13:06:56: frame - [100%] [avg time: 6.177 ms (cpu time: avg 5.523 ms, total 2734.38 ms)] [avg calls per frame: 1] [children: 75.8%] [unaccounted: 24.2%]
13:06:56: | scene->Preprocess - [63.4%] [avg time: 3.914 ms (cpu time: avg 3.724 ms, total 1843.75 ms)] [avg calls per frame: 1]
13:06:56: | video encoding and uploading - [12.4%] [avg time: 0.766 ms (cpu time: avg 0.536 ms, total 265.625 ms)] [avg calls per frame: 1] [children: 11.1%] [unaccounted: 1.3%]
13:06:56: | | CopyResource - [5.83%] [avg time: 0.36 ms (cpu time: avg 0.284 ms, total 140.625 ms)] [avg calls per frame: 0]
13:06:56: | | conversion to 4:2:0 - [0.372%] [avg time: 0.023 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
13:06:56: | | call to encoder - [4.81%] [avg time: 0.297 ms (cpu time: avg 0.189 ms, total 93.75 ms)] [avg calls per frame: 0] [children: 3.92%] [unaccounted: 0.89%]
13:06:56: | | | ProcessEncodedFrame - [1.98%] [avg time: 0.122 ms (cpu time: avg 0.094 ms, total 46.875 ms)] [avg calls per frame: 0]
13:06:56: | | | EncodeFrameAsync - [1.94%] [avg time: 0.12 ms (cpu time: avg 0.063 ms, total 31.25 ms)] [avg calls per frame: 0]
13:06:56: | | sending stuff out - [0.0971%] [avg time: 0.006 ms (cpu time: avg 0.031 ms, total 15.625 ms)] [avg calls per frame: 0]
13:06:56: | Convert444Threads - [1.05e+003%] [avg time: 64.766 ms (cpu time: avg 5.808 ms, total 2875 ms)] [avg calls per frame: 1]
13:06:56:
