Push to talk not working while pressing shift
Rwi
Hello guys, i need a bit of assistance. I use push to talk on obs on a specific button. I had issues alot of times with mic cutting off randomly and i didn't know what could cause the issue. I manage to discover that my mic is cutting off when i play game and use SHIFT button for running for instance.
Looks like obs push to talk shortcut don't work in the same time as shift button. This needs to be listed somehow as a bug with high priority.
Any of you know how to fix this? Thank you.
Rwi
SOLVED. Solution is to add PPT for CTRL, SHIFT, ALT
hakomo2020
this will not fix the problem. it will still cut off the sound when pressing shift. but you know what? streamlabs doesn't have this problem. and don't ask me how it's possible. streamlabs is based on a fork of obs studio
Suslik V
...it will still cut off the sound when pressing shift
You may try to set "Push-to-talk delay" about 50 ms in OBS Settings > Audio. This may help to workaround small cuts. Option available when audio input source is present in the scene. Edit: Hotkeys thread itself in OBS is about 25 ms.
