Emiya Shirou
For now my x64 OBS doesn't detect my PS3 eye camera (It works fine with 32 bit version) someone has any idea how to make it work with 64 bit version of OBS?
That is very sad to hear but how it can't have 64bit drivers yet work fine on 64bit OS?dodgepong said:It doesn't have 64bit drivers, so I don't know if it's possible without some sort of hacky workaround with window capture.
That is the driver I am using.AmericanNinja said:Have you tried this http://codelaboratories.com/products/eye/driver/ ?
I only know about one driver, the one from Code Laboratories.Jim said:The PS3 Eye drivers are homebrew, and some have issues. There are two known sets of drivers, one works with OBS and has proper directshow data, the other does not. Not sure which though. You'll probably have to use 32bit, but 32bit is not that big of a deal.
I don't know about the second link, because all i can see it talks about CL-Eye driver which I already use, but is the first think an actual different driver than CL Eye? You maybe know what are the differences between CL-Eye I am using right now and this?Andrewj said:It is not compatible with 64 bit however take a look at this link http://createdigitalmotion.com/2009/08/ ... esomeness/. This explains about drivers to make it work on 64 bit. It may be what you are looking for. I also want to refer you here http://www.techyv.com/questions/searchi ... toy-camera as there is useful information.
