i just partition my hd and installed windows 7 64 it, for main purpose to stream from it. (fresh install. list of all software that's been installed 1.all windows updates, 2.chrome, 3.directx 9, 4.easeus partition master 9.2.2, 5.KMPlayer, 6.revo uninstaller, 7.OBS. that's it nothing els ). so i started obs changed settings to
Encoding:
Quality Balance – 9/10
Max Bitrate (kb/s) – 3000 (i have Comcast 10 up 50 down. lol more like 6 down 38 up according to http://testmy.net/)
Audio Encoding: default
Broadcast Settings: default
Video:
Base Resolution - 1037 x 788 (i need this to be in this rang +, - 10 Pix)
Resolution Downscale - 1037 x 788
FPS – 30 FPS
Audio: default
Advanced: default (except these ↓ )
Use Multithreaded Optimizations - High
x264 cpu Preset - veryfast
OK when i Adding a Screen Region i use this ↓ but my position and size is different
my is
Position 0, 0,
size 1037, 788,
so now that we now how i have it set up. lets look in to the problem. every time i try to cast my idle FPS is 20-25 (no mater on what x264 cpu Preset i use or how high i set FPS)
and when play a video or play BOI my FPS drops to 7-10
i have
CPU X6800 @2.93 OR overclocked to 3.5
RAM 4 GB
NVIDIA 8600GT (latest Drivers )
OS 64-bit
if i did't know any better i would say that my system is to week but like i sad this is a second partition on this HD. my firs one has same copy of windows but with bunch of other !@#$%^& installed and OBS on this one works just fine 30+ fps on Fast : x264 cpu Preset setting. Why it's being stupid on this one is beyond me.
i also trade reinstalling OBS, use test build, and deleting Config Folder (so it resets completely ) no luck.
Encoding:
Video:
FPS – 30 FPS
Audio: default
my is
Position 0, 0,
size 1037, 788,
i have
RAM 4 GB
OS 64-bit
