Question / Help Problem with Dropped Frames
DeathCaban
I have been trying to stream some of my gameplay to twitch.tv, mostly mmo, like neverwinter or aion, or some dead island, mostly this games, or something like them.
But the red bar appears and here com the dropped frames, so i've been struggling to get it right unsuccessfully, so i'm here asking for help.
I believe you can see the computer spec in the log but i can put it here:
CPU - Intel Xeon W3520 @ 4.0GHz
Ram - 6 x 2 GB Gskill Trident @ 1600Mhz
GPU - NVIDIA GTX570
Speedtests:
Local
Germany,Frankfurt
Here is the log file ( when i tried 2 mins of "How to test your stream/bitrate at it's limits."
15:45:36: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
15:45:36: -------------------------------
15:45:36: CPU Name: Intel(R) Xeon(R) CPU           W3520  @ 2.67GHz
15:45:36: CPU Speed: 4009MHz
15:45:36: Physical Memory:  12279MB Total, 9034MB Free
15:45:36: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
15:45:36: monitor 1: pos={0, 0}, size={1920, 1080}
15:45:36: Windows Version: 6.1 Build 7601 S
15:45:36: Aero is Disabled
15:45:36: OBS Modules:
15:45:36: Base Address     Module
15:45:36: 000000003FCF0000 OBS.exe
15:45:36: 00000000EF9F0000 OBSApi.dll
15:45:36: 00000000F56F0000 DShowPlugin.dll
15:45:36: 00000000F56C0000 GraphicsCapture.dll
15:45:36: 00000000F58F0000 NoiseGate.dll
15:45:36: ------------------------------------------
15:45:36: Adapter 1
15:45:36:   Video Adapter: NVIDIA GeForce GTX 570
15:45:36:   Video Adapter Dedicated Video Memory: 1293352960
15:45:36:   Video Adapter Shared System Memory: 2952343552
15:45:36: =====Stream Start: 2013-05-13, 15:45:36===============================================
15:45:36:   Multithreaded optimizations: On
15:45:36:   Base resolution: 1920x1080
15:45:36:   Output resolution: 1280x720
15:45:36: Loading up D3D10...
15:45:36: Playback device Default
15:45:36: Using desktop audio input: Speakers (Creative SB X-Fi)
15:45:36: Using auxilary audio input: Microphone (Creative SB X-Fi)
15:45:36: Audio Encoding: AAC
15:45:36:     bitrate: 192
15:45:36: Using Monitor Capture
15:45:36: Video Encoding: x264
15:45:36:     fps: 30
15:45:36:     width: 1280, height: 720
15:45:36:     preset: superfast
15:45:36:     CBR: yes
15:45:36:     CFR: no
15:45:36:     max bitrate: 2500
15:49:50: Using text output
15:51:41: Total frames rendered: 10914, number of frames that lagged: 5 (0.05%) (it's okay for some frames to lag)
15:51:41: =====Stream End: 2013-05-13, 15:51:41=================================================
15:51:42: Using fixed low latency mode, factor 20
15:51:42: =====Stream Start: 2013-05-13, 15:51:42===============================================
15:51:42:   Multithreaded optimizations: On
15:51:42:   Base resolution: 1920x1080
15:51:42:   Output resolution: 1280x720
15:51:42: ------------------------------------------
15:51:42: Loading up D3D10...
15:51:43: Playback device Default
15:51:43: ------------------------------------------
15:51:43: Using desktop audio input: Speakers (Creative SB X-Fi)
15:51:43: Using auxilary audio input: Microphone (Creative SB X-Fi)
15:51:43: Audio Encoding: AAC
15:51:43:     bitrate: 192
15:51:43: Using text output
15:51:43: Using Monitor Capture
15:51:43: Video Encoding: x264
15:51:43:     fps: 30
15:51:43:     width: 1280, height: 720
15:51:43:     preset: superfast
15:51:43:     CBR: yes
15:51:43:     CFR: no
15:51:43:     max bitrate: 2500
15:51:44: Using RTMP service: Twitch / Justin.tv
15:51:44:   Server selection: rtmp://live-fra.justin.tv/app
15:51:46: SO_SNDBUF was at 8192
15:51:46: SO_SNDBUF is now 65536
15:53:45: Total frames rendered: 3655, number of frames that lagged: 1 (0.03%) (it's okay for some frames to lag)
15:53:45: RTMPPublisher::SocketLoop: Aborting due to loop exit
15:53:45: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
15:53:45: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
15:53:45: Number of times waited to send: 663, Waited for a total of 2341255 bytes
15:53:45: Number of b-frames dropped: 318 (9%), Number of p-frames dropped: 944 (27%), Total 1262 (36%)
15:53:45: =====Stream End: 2013-05-13, 15:53:45=================================================
15:54:49:
15:54:49: Profiler results:
15:54:49:
15:54:49: ==============================================================
15:54:49: frame - [100%] [avg time: 5.05 ms] [avg calls per frame: 1] [children: 91.3%] [unaccounted: 8.69%]
15:54:49: | scene->Preprocess - [67.9%] [avg time: 3.428 ms] [avg calls per frame: 1]
15:54:49: | video encoding and uploading - [23.4%] [avg time: 1.183 ms] [avg calls per frame: 1] [children: 18.5%] [unaccounted: 4.91%]
15:54:49: | | CopyResource - [0.198%] [avg time: 0.01 ms] [avg calls per frame: 0]
15:54:49: | | conversion to 4:2:0 - [0.158%] [avg time: 0.008 ms] [avg calls per frame: 0]
15:54:49: | | call to encoder - [18.1%] [avg time: 0.912 ms] [avg calls per frame: 0]
15:54:49: | | sending stuff out - [0.099%] [avg time: 0.005 ms] [avg calls per frame: 0]
15:54:49:
DeathCaban
Hm, still dropping fps in the main London server.
London test
20:01:11: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
20:01:11: -------------------------------
20:01:11: CPU Name: Intel(R) Xeon(R) CPU           W3520  @ 2.67GHz
20:01:11: CPU Speed: 4009MHz
20:01:11: Physical Memory:  12279MB Total, 7492MB Free
20:01:11: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
20:01:11: monitor 1: pos={0, 0}, size={1920, 1080}
20:01:11: Windows Version: 6.1 Build 7601 S
20:01:11: Aero is Disabled
20:01:11: OBS Modules:
20:01:11: Base Address     Module
20:01:11: 000000003F5A0000 OBS.exe
20:01:11: 00000000F5050000 OBSApi.dll
20:01:11: 00000000F74B0000 DShowPlugin.dll
20:01:11: 00000000F73E0000 GraphicsCapture.dll
20:01:11: 00000000F73C0000 NoiseGate.dll
20:01:11: ------------------------------------------
20:01:11: Adapter 1
20:01:11:   Video Adapter: NVIDIA GeForce GTX 570
20:01:11:   Video Adapter Dedicated Video Memory: 1293352960
20:01:11:   Video Adapter Shared System Memory: 2952343552
20:01:11: Using fixed low latency mode, factor 20
20:01:11: =====Stream Start: 2013-05-13, 20:01:11===============================================
20:01:11:   Multithreaded optimizations: On
20:01:11:   Base resolution: 1920x1080
20:01:11:   Output resolution: 1280x720
20:01:11: Loading up D3D10...
20:01:11: Playback device Default
20:01:11: Using desktop audio input: Speakers (Creative SB X-Fi)
20:01:11: Using auxilary audio input: Microphone (Creative SB X-Fi)
20:01:11: Audio Encoding: AAC
20:01:11:     bitrate: 192
20:01:11: Using text output
20:01:11: Using Monitor Capture
20:01:11: Video Encoding: x264
20:01:11:     fps: 30
20:01:11:     width: 1280, height: 720
20:01:11:     preset: superfast
20:01:11:     CBR: yes
20:01:11:     CFR: no
20:01:11:     max bitrate: 2500
20:01:12: Using RTMP service: Twitch / Justin.tv
20:01:12:   Server selection: rtmp://live-lhr.justin.tv/app
20:01:14: SO_SNDBUF was at 8192
20:01:14: SO_SNDBUF is now 65536
20:04:53: Total frames rendered: 6656, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
20:04:53: RTMPPublisher::SocketLoop: Aborting due to loop exit
20:04:53: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
20:04:53: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
20:04:53: Number of times waited to send: 1291, Waited for a total of 4593031 bytes
20:04:53: Number of b-frames dropped: 568 (8.7%), Number of p-frames dropped: 1481 (23%), Total 2049 (31%)
20:04:53: =====Stream End: 2013-05-13, 20:04:53=================================================
20:05:44:
20:05:44: Profiler results:
20:05:44:
20:05:44: ==============================================================
20:05:44: frame - [100%] [avg time: 6.446 ms] [avg calls per frame: 1] [children: 93.3%] [unaccounted: 6.67%]
20:05:44: | scene->Preprocess - [68.9%] [avg time: 4.44 ms] [avg calls per frame: 1]
20:05:44: | video encoding and uploading - [24.4%] [avg time: 1.576 ms] [avg calls per frame: 1] [children: 16.1%] [unaccounted: 8.32%]
20:05:44: | | CopyResource - [0.171%] [avg time: 0.011 ms] [avg calls per frame: 0]
20:05:44: | | conversion to 4:2:0 - [0.403%] [avg time: 0.026 ms] [avg calls per frame: 0]
20:05:44: | | call to encoder - [15.3%] [avg time: 0.984 ms] [avg calls per frame: 0]
20:05:44: | | sending stuff out - [0.295%] [avg time: 0.019 ms] [avg calls per frame: 0]
20:05:44:
Krazy
Town drunk
And Amsterdam?
Erm, I never actually clicked your speedtest image links, but they appear to just link to speedtest.net. Can you try a speedtest at speedof.me instead, though? It's generally more accurate.
DeathCaban
Amesterdan stream test 3 mins
22:17:40: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
22:17:40: -------------------------------
22:17:40: CPU Name: Intel(R) Xeon(R) CPU           W3520  @ 2.67GHz
22:17:40: CPU Speed: 4009MHz
22:17:40: Physical Memory:  12279MB Total, 9427MB Free
22:17:40: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
22:17:40: monitor 1: pos={0, 0}, size={1920, 1080}
22:17:40: Windows Version: 6.1 Build 7601 S
22:17:40: Aero is Disabled
22:17:40: OBS Modules:
22:17:40: Base Address     Module
22:17:40: 000000003F740000 OBS.exe
22:17:40: 00000000F50B0000 OBSApi.dll
22:17:40: 00000000F7420000 DShowPlugin.dll
22:17:40: 00000000F73F0000 GraphicsCapture.dll
22:17:40: 00000000F81D0000 NoiseGate.dll
22:17:40: ------------------------------------------
22:17:40: Adapter 1
22:17:40:   Video Adapter: NVIDIA GeForce GTX 570
22:17:40:   Video Adapter Dedicated Video Memory: 1293352960
22:17:40:   Video Adapter Shared System Memory: 2952343552
22:17:40: Using fixed low latency mode, factor 20
22:17:40: =====Stream Start: 2013-05-13, 22:17:40===============================================
22:17:40:   Multithreaded optimizations: On
22:17:40:   Base resolution: 1920x1080
22:17:40:   Output resolution: 1280x720
22:17:40: Loading up D3D10...
22:17:40: Playback device Default
22:17:40: Using desktop audio input: Speakers (Creative SB X-Fi)
22:17:40: Using auxilary audio input: Microphone (Creative SB X-Fi)
22:17:40: Audio Encoding: AAC
22:17:40:     bitrate: 192
22:17:40: Using bitmap image
22:17:40: Using text output
22:17:40: Video Encoding: x264
22:17:40:     fps: 30
22:17:40:     width: 1280, height: 720
22:17:40:     preset: superfast
22:17:40:     CBR: yes
22:17:40:     CFR: no
22:17:40:     max bitrate: 2500
22:17:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:17:42:   New Scene
22:17:42: Using Monitor Capture
22:17:42: Using RTMP service: Twitch / Justin.tv
22:17:42:   Server selection: rtmp://live-ams.justin.tv/app
22:17:45: SO_SNDBUF was at 8192
22:17:45: SO_SNDBUF is now 65536
22:20:44: Total frames rendered: 5501, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
22:20:44: okay, this is strange
22:20:44: RTMPPublisher::SocketLoop: Aborting due to loop exit
22:20:44: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
22:20:44: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
22:20:44: Number of times waited to send: 1006, Waited for a total of 3575635 bytes
22:20:44: Number of b-frames dropped: 93 (1.7%), Number of p-frames dropped: 850 (16%), Total 943 (18%)
22:20:44: =====Stream End: 2013-05-13, 22:20:44=================================================
22:22:27:
22:22:27: Profiler results:
22:22:27:
22:22:27: ==============================================================
22:22:27: frame - [100%] [avg time: 7.297 ms] [avg calls per frame: 1] [children: 93%] [unaccounted: 7.03%]
22:22:27: | scene->Preprocess - [65.5%] [avg time: 4.776 ms] [avg calls per frame: 1]
22:22:27: | video encoding and uploading - [27.5%] [avg time: 2.008 ms] [avg calls per frame: 1] [children: 13.9%] [unaccounted: 13.7%]
22:22:27: | | CopyResource - [0.151%] [avg time: 0.011 ms] [avg calls per frame: 0]
22:22:27: | | conversion to 4:2:0 - [0.397%] [avg time: 0.029 ms] [avg calls per frame: 0]
22:22:27: | | call to encoder - [13%] [avg time: 0.951 ms] [avg calls per frame: 0]
22:22:27: | | sending stuff out - [0.274%] [avg time: 0.02 ms] [avg calls per frame: 0]
22:22:27:
http://speedof.me/show.php?img=130513070410-8891.png
DeathCaban
Hm i cant really get an accurate test from speedof.me bcs when i get to the 128mb sample download test it crashes the browser tab, with the mensage "Aw snap, something went wron, bla bla bla..." @120mb/s download so i cant test the right upload there.
testmy.net - http://testmy.net/compID/817563082023
measurementlab.net didnt give me any type of tool to copy the info, unless you want the detailed or advanced info
UPLOAD SPEED - 2.0 Mb/s
DOWNLOAD SPEED - 74 Mb/s
Network latency: 96 msec round trip time
Jitter: 43 msec
Krazy
Town drunk
Ugh, your speeds really are all over the place. Can you try a bitrate of 1800 and see if you still get dropped frames?
dodgepong
Administrator
Community Helper
That testmy.net link is neat, you can see your whole history of tests:
DeathCaban
It improved a bit, but i still got like 5% dropped frames in 5 mins of test.
btw, thank you so much for the help so far =)
23:23:01: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
23:23:01: -------------------------------
23:23:01: CPU Name: Intel(R) Xeon(R) CPU           W3520  @ 2.67GHz
23:23:01: CPU Speed: 4009MHz
23:23:01: Physical Memory:  12279MB Total, 8199MB Free
23:23:01: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
23:23:01: monitor 1: pos={0, 0}, size={1920, 1080}
23:23:01: Windows Version: 6.1 Build 7601 S
23:23:01: Aero is Disabled
23:23:01: OBS Modules:
23:23:01: Base Address     Module
23:23:01: 000000003F4C0000 OBS.exe
23:23:01: 00000000EF550000 OBSApi.dll
23:23:01: 00000000FACB0000 DShowPlugin.dll
23:23:01: 00000000FAB40000 GraphicsCapture.dll
23:23:01: 00000000FAB20000 NoiseGate.dll
23:23:01: ------------------------------------------
23:23:01: Adapter 1
23:23:01:   Video Adapter: NVIDIA GeForce GTX 570
23:23:01:   Video Adapter Dedicated Video Memory: 1293352960
23:23:01:   Video Adapter Shared System Memory: 2952343552
23:23:01: =====Stream Start: 2013-05-13, 23:23:01===============================================
23:23:01:   Multithreaded optimizations: On
23:23:01:   Base resolution: 1920x1080
23:23:01:   Output resolution: 1280x720
23:23:01: Loading up D3D10...
23:23:01: Playback device Default
23:23:01: Using desktop audio input: Speakers (Creative SB X-Fi)
23:23:01: Using auxilary audio input: Microphone (Creative SB X-Fi)
23:23:01: Audio Encoding: AAC
23:23:01:     bitrate: 192
23:23:01: Using text output
23:23:01: Using Monitor Capture
23:23:01: Video Encoding: x264
23:23:01:     fps: 30
23:23:01:     width: 1280, height: 720
23:23:01:     preset: superfast
23:23:01:     CBR: yes
23:23:01:     CFR: no
23:23:01:     max bitrate: 1800
23:23:03: Total frames rendered: 57, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
23:23:03: =====Stream End: 2013-05-13, 23:23:03=================================================
23:23:06: Using fixed low latency mode, factor 20
23:23:06: =====Stream Start: 2013-05-13, 23:23:06===============================================
23:23:06:   Multithreaded optimizations: On
23:23:06:   Base resolution: 1920x1080
23:23:06:   Output resolution: 1280x720
23:23:06: ------------------------------------------
23:23:06: Loading up D3D10...
23:23:06: Playback device Default
23:23:06: Using desktop audio input: Speakers (Creative SB X-Fi)
23:23:06: Using auxilary audio input: Microphone (Creative SB X-Fi)
23:23:06: Audio Encoding: AAC
23:23:06:     bitrate: 192
23:23:06: Using text output
23:23:06: Using Monitor Capture
23:23:06: Video Encoding: x264
23:23:06:     fps: 30
23:23:06:     width: 1280, height: 720
23:23:06:     preset: superfast
23:23:06:     CBR: yes
23:23:06:     CFR: no
23:23:06:     max bitrate: 1800
23:23:08: Using RTMP service: Twitch / Justin.tv
23:23:08:   Server selection: rtmp://live-ams.justin.tv/app
23:23:10: SO_SNDBUF was at 8192
23:23:10: SO_SNDBUF is now 65536
23:28:45: Total frames rendered: 10162, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
23:28:45: RTMPPublisher::SocketLoop: Aborting due to loop exit
23:28:45: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
23:28:45: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
23:28:45: Number of times waited to send: 744, Waited for a total of 2515759 bytes
23:28:45: Number of b-frames dropped: 66 (0.66%), Number of p-frames dropped: 248 (2.5%), Total 314 (3.1%)
23:28:45: =====Stream End: 2013-05-13, 23:28:45=================================================
23:28:59:
23:28:59: Profiler results:
23:28:59:
23:28:59: ==============================================================
23:28:59: frame - [100%] [avg time: 6.398 ms] [avg calls per frame: 1] [children: 93.1%] [unaccounted: 6.88%]
23:28:59: | scene->Preprocess - [63.7%] [avg time: 4.078 ms] [avg calls per frame: 1]
23:28:59: | video encoding and uploading - [29.4%] [avg time: 1.88 ms] [avg calls per frame: 1] [children: 15.9%] [unaccounted: 13.5%]
23:28:59: | | CopyResource - [0.172%] [avg time: 0.011 ms] [avg calls per frame: 0]
23:28:59: | | conversion to 4:2:0 - [0.219%] [avg time: 0.014 ms] [avg calls per frame: 0]
23:28:59: | | call to encoder - [15.3%] [avg time: 0.978 ms] [avg calls per frame: 0]
23:28:59: | | sending stuff out - [0.234%] [avg time: 0.015 ms] [avg calls per frame: 0]
23:28:59:
DeathCaban
Well i did a "test" stream last night and it ran pretty well, only 1 or 2 % drop frames.
In the past i did stream like every days using xplit with bitrates like ~2500 and it worked pretty fine, i guess my isp is kind crappy now :S
this was the result:
01:40:36: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
01:40:36: -------------------------------
01:40:36: CPU Name: Intel(R) Xeon(R) CPU           W3520  @ 2.67GHz
01:40:36: CPU Speed: 4009MHz
01:40:36: Physical Memory:  10231MB Total, 6907MB Free
01:40:36: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
01:40:36: monitor 1: pos={0, 0}, size={1920, 1080}
01:40:36: Windows Version: 6.1 Build 7601 S
01:40:36: Aero is Disabled
01:40:36: OBS Modules:
01:40:36: Base Address     Module
01:40:36: 000000003F290000 OBS.exe
01:40:36: 00000000F0280000 OBSApi.dll
01:40:36: 00000000F6E10000 DShowPlugin.dll
01:40:36: 00000000F6DE0000 GraphicsCapture.dll
01:40:36: 00000000FB330000 NoiseGate.dll
01:40:36: ------------------------------------------
01:40:36: Adapter 1
01:40:36:   Video Adapter: NVIDIA GeForce GTX 570
01:40:36:   Video Adapter Dedicated Video Memory: 1293352960
01:40:36:   Video Adapter Shared System Memory: 2952343552
01:40:36: =====Stream Start: 2013-05-15, 01:40:36===============================================
01:40:36:   Multithreaded optimizations: On
01:40:36:   Base resolution: 1920x1080
01:40:36:   Output resolution: 1280x720
01:40:36: Loading up D3D10...
01:40:36: Playback device Default
01:40:36: Using desktop audio input: Speakers (Creative SB X-Fi)
01:40:36: Using auxilary audio input: Microphone (Creative SB X-Fi)
01:40:36: Audio Encoding: AAC
01:40:36:     bitrate: 192
01:40:36: Using text output
01:40:36: Using Monitor Capture
01:40:36: Video Encoding: x264
01:40:36:     fps: 30
01:40:36:     width: 1280, height: 720
01:40:36:     preset: superfast
01:40:36:     CBR: yes
01:40:36:     CFR: no
01:40:36:     max bitrate: 1800
01:40:37: Total frames rendered: 31, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:40:37: =====Stream End: 2013-05-15, 01:40:37=================================================
01:40:47: Using fixed low latency mode, factor 20
01:40:47: =====Stream Start: 2013-05-15, 01:40:47===============================================
01:40:47:   Multithreaded optimizations: On
01:40:47:   Base resolution: 1920x1080
01:40:47:   Output resolution: 1280x720
01:40:47: ------------------------------------------
01:40:47: Loading up D3D10...
01:40:47: Playback device Default
01:40:47: Using desktop audio input: Speakers (Creative SB X-Fi)
01:40:47: Using auxilary audio input: Microphone (Creative SB X-Fi)
01:40:47: Audio Encoding: AAC
01:40:47:     bitrate: 192
01:40:47: Using text output
01:40:47: Using Monitor Capture
01:40:47: Video Encoding: x264
01:40:47:     fps: 30
01:40:47:     width: 1280, height: 720
01:40:47:     preset: superfast
01:40:47:     CBR: yes
01:40:47:     CFR: no
01:40:47:     max bitrate: 1800
01:40:48: Using RTMP service: Twitch / Justin.tv
01:40:48:   Server selection: rtmp://live-lhr.justin.tv/app
01:40:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:40:50:   New Scene
01:40:50: Using bitmap image
01:40:50: Using text output
01:40:50: SO_SNDBUF was at 8192
01:40:50: SO_SNDBUF is now 65536
01:41:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:41:03:   New Scene
01:44:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:44:36:   New Scene
04:17:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
04:17:54:   New Scene
04:17:54: Using text output
04:17:54: Using bitmap image
04:19:36: Total frames rendered: 285882, number of frames that lagged: 7 (0.00%) (it's okay for some frames to lag)
04:19:36: RTMPPublisher::SocketLoop: Aborting due to loop exit
04:19:36: Number of times waited to send: 17099, Waited for a total of 57872064 bytes
04:19:36: Number of b-frames dropped: 2603 (0.91%), Number of p-frames dropped: 2219 (0.78%), Total 4822 (1.7%)
04:19:36: =====Stream End: 2013-05-15, 04:19:36=================================================
04:20:05:
04:20:05: Profiler results:
04:20:05:
04:20:05: ==============================================================
04:20:05: frame - [100%] [avg time: 8.637 ms] [avg calls per frame: 1] [children: 95.5%] [unaccounted: 4.47%]
04:20:05: | scene->Preprocess - [81.2%] [avg time: 7.016 ms] [avg calls per frame: 1]
04:20:05: | video encoding and uploading - [14.3%] [avg time: 1.235 ms] [avg calls per frame: 1] [children: 12.8%] [unaccounted: 1.54%]
04:20:05: | | CopyResource - [0.127%] [avg time: 0.011 ms] [avg calls per frame: 0]
04:20:05: | | conversion to 4:2:0 - [0.405%] [avg time: 0.035 ms] [avg calls per frame: 0]
04:20:05: | | call to encoder - [12%] [avg time: 1.038 ms] [avg calls per frame: 0]
04:20:05: | | sending stuff out - [0.208%] [avg time: 0.018 ms] [avg calls per frame: 0]
04:20:05:
Ty for all the help ! =)
