Bug Report Problem of image registration
KiinGz
Hello, I write very little English lol
I have announced to you my problem. When I record video I have no picture but I have sound.
I use OBS to check in FIFA 13. So the game is full screen, not windowed.
Someone would help me?
Thank you in advance. KiinGz
KiinGz
09:34:40: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
09:34:40: -------------------------------
09:34:40: CPU Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
09:34:40: CPU Speed: 2195MHz
09:34:40: Physical Memory:  2413MB Total, 923MB Free
09:34:40: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
09:34:40: monitor 1: pos={0, 0}, size={1600, 900}
09:34:40: Windows Version: 6.1 Build 7601 S
09:34:40: Aero is Enabled
09:34:40: OBS Modules:
09:34:40: Base Address     Module
09:34:40: 01280000         OBS.exe
09:34:40: 58D70000         OBSApi.dll
09:34:40: 618A0000         DShowPlugin.dll
09:34:40: 618E0000         GraphicsCapture.dll
09:34:40: 6C860000         NoiseGate.dll
09:34:40: ------------------------------------------
09:34:40: Adapter 1
09:34:40:   Video Adapter: Intel(R) HD Graphics 3000
09:34:40:   Video Adapter Dedicated Video Memory: 2269671424
09:34:40:   Video Adapter Shared System Memory: 997122048
09:34:40: =====Stream Start: 2013-05-25, 09:34:40===============================================
09:34:40:   Multithreaded optimizations: On
09:34:40:   Base resolution: 1600x900
09:34:40:   Output resolution: 1280x720
09:34:40: Loading up D3D10...
09:34:40: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:34:40: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:34:41: ------------------------------------------
09:34:41: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:34:41: Audio Encoding: AAC
09:34:41:     bitrate: 128
09:34:41: Using graphics capture
09:34:41: Video Encoding: x264
09:34:41:     fps: 30
09:34:41:     width: 1280, height: 720
09:34:41:     preset: veryfast
09:34:41:     CBR: no
09:34:41:     CFR: no
09:34:41:     max bitrate: 1000
09:34:41:     buffer size: 1000
09:34:41:     quality: 10
09:36:22: Total frames rendered: 3052, number of frames that lagged: 2 (0.07%) (it's okay for some frames to lag)
09:36:23: =====Stream End: 2013-05-25, 09:36:23=================================================
09:41:45: =====Stream Start: 2013-05-25, 09:41:45===============================================
09:41:45:   Multithreaded optimizations: On
09:41:45:   Base resolution: 1600x900
09:41:45:   Output resolution: 1280x720
09:41:45: ------------------------------------------
09:41:45: Loading up D3D10...
09:41:45: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:41:45: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:41:45: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:41:45: Audio Encoding: AAC
09:41:45:     bitrate: 192
09:41:45: Using Window Capture
09:41:45: Video Encoding: x264
09:41:45:     fps: 30
09:41:45:     width: 1280, height: 720
09:41:45:     preset: veryfast
09:41:45:     CBR: no
09:41:45:     CFR: no
09:41:45:     max bitrate: 1000
09:41:45:     buffer size: 1000
09:41:45:     quality: 10
09:42:34: Using Window Capture
09:42:35: Using graphics capture
09:42:39: Using graphics capture
09:42:41: Using Window Capture
09:42:44: Total frames rendered: 1770, number of frames that lagged: 2 (0.11%) (it's okay for some frames to lag)
09:42:44: =====Stream End: 2013-05-25, 09:42:44=================================================
09:42:57: =====Stream Start: 2013-05-25, 09:42:57===============================================
09:42:57:   Multithreaded optimizations: On
09:42:57:   Base resolution: 1600x900
09:42:57:   Output resolution: 1280x720
09:42:57: ------------------------------------------
09:42:57: Loading up D3D10...
09:42:57: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:42:57: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:42:57: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:42:57: Audio Encoding: AAC
09:42:57:     bitrate: 192
09:42:57: Using graphics capture
09:42:57: Video Encoding: x264
09:42:57:     fps: 30
09:42:57:     width: 1280, height: 720
09:42:57:     preset: veryfast
09:42:57:     CBR: no
09:42:57:     CFR: no
09:42:57:     max bitrate: 1000
09:42:57:     buffer size: 1000
09:42:57:     quality: 10
09:44:11: SharedTexCapture hooked
09:44:23: Total frames rendered: 2548, number of frames that lagged: 4 (0.16%) (it's okay for some frames to lag)
09:44:23: =====Stream End: 2013-05-25, 09:44:23=================================================
09:44:25: =====Stream Start: 2013-05-25, 09:44:25===============================================
09:44:25:   Multithreaded optimizations: On
09:44:25:   Base resolution: 1600x900
09:44:25:   Output resolution: 1280x720
09:44:25: ------------------------------------------
09:44:25: Loading up D3D10...
09:44:25: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:44:25: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:44:25: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:44:25: Audio Encoding: AAC
09:44:25:     bitrate: 192
09:44:25: Using graphics capture
09:44:25: Video Encoding: x264
09:44:25:     fps: 30
09:44:25:     width: 1280, height: 720
09:44:25:     preset: veryfast
09:44:25:     CBR: no
09:44:25:     CFR: no
09:44:25:     max bitrate: 1000
09:44:25:     buffer size: 1000
09:44:25:     quality: 10
09:44:27: Using Window Capture
09:44:31: Using graphics capture
09:44:52: Total frames rendered: 814, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
09:44:52: =====Stream End: 2013-05-25, 09:44:52=================================================
09:44:53: =====Stream Start: 2013-05-25, 09:44:53===============================================
09:44:53:   Multithreaded optimizations: On
09:44:53:   Base resolution: 1600x900
09:44:53:   Output resolution: 1280x720
09:44:53: ------------------------------------------
09:44:53: Loading up D3D10...
09:44:53: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:44:53: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:44:53: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:44:53: Audio Encoding: AAC
09:44:53:     bitrate: 192
09:44:53: Using graphics capture
09:44:53: Video Encoding: x264
09:44:53:     fps: 30
09:44:53:     width: 1280, height: 720
09:44:53:     preset: veryfast
09:44:53:     CBR: no
09:44:53:     CFR: no
09:44:53:     max bitrate: 1000
09:44:53:     buffer size: 1000
09:44:53:     quality: 10
09:45:21: Using Window Capture
09:45:38: Using Window Capture
09:46:00: ------------------------------------------
09:46:00:     device: 1.3M HD WebCam,
09:46:00:     device id \\?\usb#vid_04f2&pid_b21b&mi_00#7&131dfcb&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
09:46:00:     chosen type: YUY2, usingFourCC: false, res: 1280x800 - 1280x800, frameIntervals: 1333333-1333333, fourCC: 'YUY2'
09:46:00:     audio device: Désactiver,
09:46:00:     audio device id Disabled,
09:46:00:
09:46:01: Using directshow input
09:46:06: Total frames rendered: 2165, number of frames that lagged: 5 (0.23%) (it's okay for some frames to lag)
09:46:06: =====Stream End: 2013-05-25, 09:46:06=================================================
09:46:08: =====Stream Start: 2013-05-25, 09:46:08===============================================
09:46:08:   Multithreaded optimizations: On
09:46:08:   Base resolution: 1600x900
09:46:08:   Output resolution: 1280x720
09:46:08: ------------------------------------------
09:46:08: Loading up D3D10...
09:46:08: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:46:08: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:46:08: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:46:08: Audio Encoding: AAC
09:46:08:     bitrate: 192
09:46:08:     device: 1.3M HD WebCam,
09:46:08:     device id \\?\usb#vid_04f2&pid_b21b&mi_00#7&131dfcb&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
09:46:08:     chosen type: YUY2, usingFourCC: false, res: 1280x800 - 1280x800, frameIntervals: 1333333-1333333, fourCC: 'YUY2'
09:46:08:     audio device: Désactiver,
09:46:08:     audio device id Disabled,
09:46:08:
09:46:08: Using directshow input
09:46:08: Video Encoding: x264
09:46:08:     fps: 30
09:46:08:     width: 1280, height: 720
09:46:08:     preset: veryfast
09:46:08:     CBR: no
09:46:08:     CFR: no
09:46:08:     max bitrate: 1000
09:46:08:     buffer size: 1000
09:46:08:     quality: 10
09:46:14: Using Window Capture
09:46:48: Total frames rendered: 1177, number of frames that lagged: 4 (0.34%) (it's okay for some frames to lag)
09:46:48: =====Stream End: 2013-05-25, 09:46:48=================================================
09:47:07: =====Stream Start: 2013-05-25, 09:47:07===============================================
09:47:07:   Multithreaded optimizations: On
09:47:07:   Base resolution: 1600x900
09:47:07:   Output resolution: 1280x720
09:47:07: ------------------------------------------
09:47:07: Loading up D3D10...
09:47:07: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:47:07: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:47:07: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:47:07: Audio Encoding: AAC
09:47:07:     bitrate: 192
09:47:07: Using graphics capture
09:47:07: Video Encoding: x264
09:47:07:     fps: 30
09:47:07:     width: 1280, height: 720
09:47:07:     preset: veryfast
09:47:07:     CBR: no
09:47:07:     CFR: no
09:47:07:     max bitrate: 1000
09:47:07:     buffer size: 1000
09:47:07:     quality: 10
09:47:07: SharedTexCapture hooked
09:47:08: Total frames rendered: 34, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
09:47:08: =====Stream End: 2013-05-25, 09:47:08=================================================
09:48:09: =====Stream Start: 2013-05-25, 09:48:09===============================================
09:48:09:   Multithreaded optimizations: On
09:48:09:   Base resolution: 1600x900
09:48:09:   Output resolution: 1280x720
09:48:09: ------------------------------------------
09:48:09: Loading up D3D10...
09:48:10: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:48:10: ------------------------------------------
09:48:10: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:48:10: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:48:10: Audio Encoding: AAC
09:48:10:     bitrate: 192
09:48:10: Using graphics capture
09:48:10: Video Encoding: x264
09:48:10:     fps: 30
09:48:10:     width: 1280, height: 720
09:48:10:     preset: veryfast
09:48:10:     CBR: no
09:48:10:     CFR: no
09:48:10:     max bitrate: 1000
09:48:10:     buffer size: 1000
09:48:10:     quality: 10
09:48:17: Total frames rendered: 236, number of frames that lagged: 1 (0.42%) (it's okay for some frames to lag)
09:48:18: =====Stream End: 2013-05-25, 09:48:18=================================================
09:49:30: =====Stream Start: 2013-05-25, 09:49:30===============================================
09:49:30:   Multithreaded optimizations: On
09:49:30:   Base resolution: 1600x900
09:49:30:   Output resolution: 1280x720
09:49:30: ------------------------------------------
09:49:30: Loading up D3D10...
09:49:30: Playback device {0.0.0.00000000}.{c8495463-a2f1-4fe8-9046-561fe3330248}
09:49:30: Using desktop audio input: Haut-parleurs (Realtek High Definition Audio)
09:49:30: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:49:30: Audio Encoding: AAC
09:49:30:     bitrate: 192
09:49:30: Using graphics capture
09:49:30: Video Encoding: x264
09:49:30:     fps: 30
09:49:30:     width: 1280, height: 720
09:49:30:     preset: veryfast
09:49:30:     CBR: no
09:49:30:     CFR: no
09:49:30:     max bitrate: 1000
09:49:30:     buffer size: 1000
09:49:30:     quality: 10
09:49:40: Total frames rendered: 290, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
09:49:40: =====Stream End: 2013-05-25, 09:49:40=================================================
09:50:08:
09:50:08: Profiler results:
09:50:08:
09:50:08: ==============================================================
09:50:08: frame - [100%] [avg time: 3.064 ms] [avg calls per frame: 1] [children: 85.4%] [unaccounted: 14.6%]
09:50:08: | scene->Preprocess - [17.5%] [avg time: 0.536 ms] [avg calls per frame: 1]
09:50:08: | video encoding and uploading - [68%] [avg time: 2.082 ms] [avg calls per frame: 1] [children: 67%] [unaccounted: 0.979%]
09:50:08: | | CopyResource - [2.51%] [avg time: 0.077 ms] [avg calls per frame: 0]
09:50:08: | | conversion to 4:2:0 - [0.555%] [avg time: 0.017 ms] [avg calls per frame: 0]
09:50:08: | | call to encoder - [63.8%] [avg time: 1.954 ms] [avg calls per frame: 0]
09:50:08: | | sending stuff out - [0.131%] [avg time: 0.004 ms] [avg calls per frame: 0]
09:50:08:
Lain
Lain
It's not a bug in this case, it's a common issue that laptops have. You have to go to nvidia/amd control panel and make sure that OBS is set to use the nvidia/amd card, not the intel, otherwise you will get a black screen.
Because I don't have a laptop, I don't know the exact procedure of how to do so.
Note: do not set you GPU using the video section, there's a bug with the selection on some laptops. Use the nvidia/amd control panel to control what GPU OBS uses instead.
KiinGz
When I want to select the graphics card to be used in the OBS selects me Intel HD Graphics 3000 instead of AMD Radeon HD7670M.
And the screen remains black
dodgepong
Administrator
Community Helper
He just said not to use the OBS selection. Go into your nVidia control panel, find OBS.exe, and tell it to run on the high-performance nVidia card.
