Bug Report Previously happened, lag after usage of OBS
xtremefish
Dear revs and forums, I previously used OBS and it seemed to make my internet connection at home very slow. I am running at 30 down and 4 up. When I tried to stream with obs before it lagged my entire computer's internet connection and now I can hardly use the internet on it. After 2 months it seemed to magically disappear and I figured since I got a new router I'll try to stream again. Now that I tried to stream my lag is back and it is making all of my games slow. This is very frustrating and it only happens after using OBS, because I used X-split to stream and it doesn't lag out my games after I stopped using it. The last answer I got from a similar post was that OBS does not leave files or specifically left over files on the computer after uninstalling the program. I need a post that could truly help me fix this problem, even if it means to not stream again. Thanks I hope you understand my problem and thank you for your time (for reading this). If anyone has any suggestions I am in great need and I will be very active to your responses. Thanks!
