Please add .ajpg files to work and animate
Nalfeyn
Since I am using animated jpg files for my alerts, because they simply look better and allow half-transparent pixels, I would like you to add those.
i tried using them with Streamlabs - they are animating correctly on the Streamlabs side, but when the alert is triggered the image shows up in OBS but don't start to animate.
Fenrir
Just to clarify, you're talking about the browser source? Or are you adding these images directly to OBS with a media or image source?
Nalfeyn
Exactly. The file is uploaded on streamlabs, and linked with the browsersource to obs.
If I put the file as a mediasource it is animated correctly.
dodgepong
Administrator
Community Helper
Can you post an example image to test with? I don't think I've ever seen an animated JPG in my life.
H4ndy
Please post an actual file that you want to try for us to replicate the issue (please attach it here to your post zipped).
Two sources for you:
Uhm both links tell you how to fiddle with a GIF file until it seems to be a JPEG.
dodgepong
Administrator
Community Helper
Renaming an extension from gif to jpg does not make it a jpg. It's still a gif, just with a misleading name. My guess is that Chrome is ignoring the extension and reading the file headers, while the browser source is trying to take the file name at its word that it's an jpg and getting confused when it turns out it isn't.
Rename the "animated jpg" back to a .gif extension, re-upload it to StreamLabs, and try it that way.
Nalfeyn
H4ndy
Your demo file is an APNG (animated PNG).
Those are not yet supported in the browser source.
APNG support is with Chromium 59, browser source is on v57 at the moment.
You have to switch to GIF and/or wait for browser source plugin to get updated.
dodgepong
Administrator
Community Helper
The links you posted both suggested that the file was a gif that was renamed to jpg.
If we're talking animated PNG, I believe support for those was only added to Chrome in version 59 (the latest version). The browser source currently uses version 57.
Why are you renaming an animated png to jpg anyway? You do understand that doesn't make it an animated jpg, right? It's still an animated png, just with a jpg name.
Nalfeyn
And a animated PNG can be easily converted into a animated JPG, because both file types support half-transparency and are using over 16 billions colours. Therefore it doesnt matter if apng or ajpg.
Thank you for your response!
It's the only answer which was needed, from a guy which knows what hes talking about.
I would like to ask everybody else to dont response if you really dont know what you are talking about.
If you dont know those files types dont say there arent any of those.
Your wasting everybody elses time.
Nalfeyn
Yes. It doenst really make a difference if jpg or png.
I need the half-transparency of the pixels for the image to be shown correctly and in the right colours.
But gif's sadly dont support that.
Thank you for your response.
Osiris
We know perfectly well what we are talking about.
The JPEG format does not support animation. Changing the extension of files does not change them to a different format, an apng (or gif) renamed to .jpg will still be in the PNG (or GIF) format.
Nalfeyn
Saying: Just rename the png to a gif file is just rubbish. Because youre changing the whole format and colour pattern and the half-transparency will be lost. So people do not know what they are talking about.
Osiris
But that's what you said you did? You even gave me links to guides that essentially create a gif then rename it to .jpg.
Nalfeyn
Do you know when the browser source will be updated?
Cheers, Nalfeyn.
