Question / Help PC Specs Question
CrazyLeopard128
Hi There, can this gaming PC setup record in High or medium Definition with no, or not much lag whilst playing?
  • AMD A8 7650K Black Edition 3.30GHz (3.80GHz Turbo) Quad Core APU - AMD Radeon R7 Graphics
  • Gigabyte F2A78M-HD2 Motherboard
  • 16GB 1600MHz DDR3 (2 x 8GB) Memory
  • 120GB Solid State Drive
  • 1TB SATA3 6Gbps Hard Drive
  • 24x DVD / CD Re-Writer
  • 500W Power Supply
  • 300Mbps PCI-E WIFI Card
  • Microsoft Windows 10 Home 64 Bit
  • Dynamode M-1100M 2.0MP Webcam
Note: This isn't my PC, so I can't give you any more specs as it's from a website where you customise your PC.
If it can't, can you please tell me what I should make better? Thanks :)
Oh and check me out on youtube if you want!: https://www.youtube.com/channel/UC4MDcEKxi4tAK128qA3Jtyw
alpinlol
No, this PC is a complete Budget Build and will barely be able to play even Games with proper Settings.
You want a dedicated GPU and a proper CPU. GPU anything like a nvidia GTX 1050Ti or a AMD RX 470 is a great start.
For the CPU I would suggest waiting for the AMD RyZen 5 Series since they will most likely offer a really great entry price to performance ratio for gaming and streaming with their 6C/12T Chips.
