I set up OBS using the various internet guides, and I can successfully see the game in the preview screen. When I go to view the files in the output folder, it either shows up as a .mp4, which accurately plays the recorded sound and only the sound, or if I change the setting to .flv, it gives me a file that opens in windows movie maker as a 5 second clip of a white box (I actually timed the recording to be longer than five seconds, so there's something wrong there). Is there some other setting I missed? I'm running SC2, first in fullscreen, then windowed, both show up in the preview, but again, the saved file is audio only.
As for the log file, the folder contained two sessions for today's date, so here's the latter, though I believe it contains multiple logs. I'm pretty new to all of this so I really don't know.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU Speed: 3292MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 550 Ti
Video Adapter Dedicated Video Memory: 2095579136
Video Adapter Shared System Memory: 2147627008
Adapter 2
Video Adapter: Intel(R) HD Graphics 3000
Video Adapter Dedicated Video Memory: 67108864
Video Adapter Shared System Memory: 1711276032
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Playback device {0.0.0.00000000}.{c83545df-6f3c-4ab8-a6a8-6ee963e5db2d}
Using desktop audio input: Speakers (2- Logitech USB Headset)
Using auxilary audio input: Microphone (2- Logitech USB Headset)
Audio Encoding: AAC
bitrate: 128
Using graphics capture
Using custom x264 settings: "crf=0 vbv-maxrate=0 vbv-bufsize=0"
x264: profile High 4:4:4 Predictive, level 4.0, 4:2:0 8-bit
Video Encoding: x264
fps: 30
width: 1920, height: 1080
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 981, number of frames that lagged: 8 (0.82%) (it's okay for some frames to lag)
x264: frame I:4 Avg QP: 0.00 size: 6836
x264: frame P:952 Avg QP: 0.00 size: 9054
x264: mb I I16..4: 100.0% 0.0% 0.0%
x264: mb P I16..4: 98.5% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0.0% skip: 1.5%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 100% 0% 0% 0%
x264: i8c dc,h,v,p: 100% 0% 0% 0%
x264: kb/s:2157.31
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 227, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1 Avg QP: 0.00 size: 7227
x264: frame P:201 Avg QP: 0.00 size: 9054
x264: kb/s:2169.61
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
SharedTexCapture hooked
Total frames rendered: 2742, number of frames that lagged: 3 (0.11%) (it's okay for some frames to lag)
x264: frame I:11 Avg QP: 0.00 size: 6802
x264: frame P:2706 Avg QP: 0.00 size: 9072
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.1% 0.1%
x264: kb/s:2165.70
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 25, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 1684, number of frames that lagged: 3 (0.18%) (it's okay for some frames to lag)
x264: frame I:7 Avg QP: 0.00 size: 6780
x264: frame P:1652 Avg QP: 0.00 size: 9054
x264: kb/s:2167.56
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 1751, number of frames that lagged: 4 (0.23%) (it's okay for some frames to lag)
x264: frame P:1719 Avg QP: 0.00 size: 9054
x264: kb/s:2162.12
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using Monitor Capture
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 4402, number of frames that lagged: 2 (0.05%) (it's okay for some frames to lag)
x264: frame I:18 Avg QP: 0.00 size: 6735
x264: frame P:4359 Avg QP: 0.00 size: 9054
x264: kb/s:2169.06
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 480, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:2 Avg QP: 0.00 size: 6967
x264: frame P:453 Avg QP: 0.00 size: 9054
x264: kb/s:2170.71
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: ultrafast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 4553, number of frames that lagged: 15 (0.33%) (it's okay for some frames to lag)
x264: frame I:19 Avg QP: 0.00 size:535530
x264: frame P:4508 Avg QP: 0.00 size: 72415
x264: mb P I16..4: 24.7% 0.0% 0.0% P16..4: 14.5% 0.0% 0.0% 0.0% 0.0% skip:60.8%
x264: coded y,uvDC,uvAC intra: 10.0% 13.3% 13.1% inter: 16.0% 17.9% 17.8%
x264: i16 v,h,dc,p: 94% 6% 0% 0%
x264: i8c dc,h,v,p: 83% 9% 8% 0%
x264: kb/s:17782.49
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
x264: profile High, level 4.0
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 869, number of frames that lagged: 8 (0.92%) (it's okay for some frames to lag)
x264: frame I:5 Avg QP:25.33 size: 53708
x264: frame P:239 Avg QP:25.11 size: 5223
x264: frame B:587 Avg QP:28.22 size: 253
x264: consecutive B-frames: 4.8% 1.2% 4.3% 89.7%
x264: mb I I16..4: 61.4% 29.6% 9.0%
x264: mb P I16..4: 2.9% 1.1% 0.1% P16..4: 9.2% 1.5% 0.5% 0.0% 0.0% skip:84.6%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.6% 0.1% 0.0% direct: 0.1% skip:99.1% L0:42.9% L1:53.2% BI: 3.9%
x264: 8x8 transform intra:27.6% inter:30.7%
x264: coded y,uvDC,uvAC intra: 31.3% 22.2% 6.5% inter: 0.8% 0.8% 0.1%
x264: i16 v,h,dc,p: 46% 33% 15% 6%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 23% 42% 3% 5% 3% 4% 3% 5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 25% 19% 7% 6% 5% 6% 5% 5%
x264: i8c dc,h,v,p: 65% 23% 9% 2%
x264: Weighted P-Frames: Y:5.0% UV:4.6%
x264: kb/s:475.33
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 527, number of frames that lagged: 54 (10.25%) (it's okay for some frames to lag)
x264: frame I:5 Avg QP: 0.00 size:546741
x264: frame P:497 Avg QP: 0.00 size:226138
x264: mb I I16..4: 67.4% 11.6% 21.0%
x264: mb P I16..4: 27.7% 0.5% 1.4% P16..4: 26.7% 3.7% 5.3% 0.0% 0.0% skip:34.6%
x264: 8x8 transform intra:2.0% inter:0.0%
x264: coded y,uvDC,uvAC intra: 12.1% 12.1% 12.1% inter: 45.8% 48.9% 48.7%
x264: i16 v,h,dc,p: 97% 3% 0% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 44% 49% 3% 1% 1% 1% 0% 0% 1%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 33% 39% 3% 4% 6% 4% 4% 3% 4%
x264: i8c dc,h,v,p: 89% 8% 4% 0%
x264: kb/s:50476.53
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 616, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:3 Avg QP: 0.00 size:1007446
x264: frame P:588 Avg QP: 0.00 size: 8679
x264: mb I I16..4: 39.3% 13.6% 47.1%
x264: mb P I16..4: 9.9% 0.0% 0.0% P16..4: 0.7% 0.2% 0.1% 0.0% 0.0% skip:88.9%
x264: 8x8 transform intra:0.8% inter:0.0%
x264: coded y,uvDC,uvAC intra: 5.0% 5.7% 5.4% inter: 1.1% 1.2% 1.2%
x264: i16 v,h,dc,p: 99% 1% 0% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 47% 42% 4% 1% 1% 1% 1% 1% 2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 35% 32% 6% 5% 5% 4% 3% 5% 5%
x264: i8c dc,h,v,p: 94% 3% 2% 0%
x264: kb/s:3299.60
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 533, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:3 Avg QP: 0.00 size:1091672
x264: frame P:505 Avg QP: 0.00 size: 724
x264: mb I I16..4: 32.7% 12.5% 54.8%
x264: mb P I16..4: 9.8% 0.0% 0.0% P16..4: 0.1% 0.0% 0.0% 0.0% 0.0% skip:90.1%
x264: 8x8 transform intra:0.7% inter:0.0%
x264: coded y,uvDC,uvAC intra: 5.2% 5.4% 5.3% inter: 0.1% 0.1% 0.1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 48% 42% 3% 1% 1% 1% 1% 1% 2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 36% 31% 6% 5% 5% 4% 3% 5% 5%
x264: i8c dc,h,v,p: 95% 3% 2% 0%
x264: kb/s:1719.84
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 0
buffer size: 0
quality: 32
Total frames rendered: 445, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:2 Avg QP: 0.00 size:1097083
x264: frame P:418 Avg QP: 0.00 size: 1623
x264: mb I I16..4: 32.6% 12.4% 55.0%
x264: mb P I16..4: 9.8% 0.0% 0.0% P16..4: 0.2% 0.0% 0.0% 0.0% 0.0% skip:89.9%
x264: 8x8 transform intra:0.6% inter:0.0%
x264: coded y,uvDC,uvAC intra: 4.4% 4.6% 4.5% inter: 0.2% 0.2% 0.2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 36% 31% 5% 5% 5% 4% 3% 5% 5%
x264: kb/s:1641.27
Profiler results:
frame - [100%] [avg time: 4.74 ms] [avg calls per frame: 1] [children: 87.3%] [unaccounted: 12.7%]
| scene->Preprocess - [0.0633%] [avg time: 0.003 ms] [avg calls per frame: 1]
| video encoding and uploading - [87.3%] [avg time: 4.136 ms] [avg calls per frame: 1] [children: 27.7%] [unaccounted: 59.5%]
| | CopyResource - [0.527%] [avg time: 0.025 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.506%] [avg time: 0.024 ms] [avg calls per frame: 0]
| | call to encoder - [26.4%] [avg time: 1.251 ms] [avg calls per frame: 0]
| | sending stuff out - [0.295%] [avg time: 0.014 ms] [avg calls per frame: 0]
