only one audio track working properly
my audio tracks aren't showing up anymore, I used to be able to have multiple tracks for gameplay, mic, discord, etc. but now they don't appear. It only shows the gameplay audio and nothing else. the audio also doesn't work when viewing in VLC media player.
Verify on the advanced audio settings you're rutting correctly the audio into each track.
Verify the video editing software you're using can in fact read and work with video files with multiple audio tracks.
yes i have, i havent changed anything it just stopped working randomly
Could you please post an image of the advanced audio settings and attach a log file?
In the first image you can see you're recording track 1 to 5. In the advanced audio settings should be set accordingly.
You can't tell which video editor you're using based on the image but it looks basic.
If you've confirmed all is set correctly as it is in this guide, that would mean your issue is not with OBS or the video at all, but instead your editor and its settings.
https://obsproject.com/kb/multiple-audio-track-recording-guide
You can download VLC if you don't have it already, open the video there, and select the audio track from the audio menu at the top to confirm all tracks are there.
ive used vlc to check, the audio tracks are there but they have no audio.
here is the log file https://obsproject.com/logs/iuVzccdpsgEt1HfF ,i also attached a picture of the advanced audio properties i have a lot of different sources, i have tf2 set to monitor and output because when i dont the audio is doubled. the editor im using is premiere pro
prgmitchell
almost certainly a playback issue on your end because you are recording w/ FLAC. record a 10-15 second video where audio should be playing on multiple tracks, upload it to google drive or somewhere to share the file (don't upload to youtube I want the file), and send it here.
im not sure what i did i messed around with a few settings and changed the encoder to AAC and it seems to have fixed the issue, i also reverted premiere back to a previous version. if the problems come back ill let you know. thank you for your help
