Only mic audio gets recorded
FatzyCat
No other sources in obs are recorded other than my mic. I can see the Desktop Audio green bar go up and nothing is muted. I run obs as admin, checked settings a bunch and nothing seems to fix it. I was using multiple audio tracks before it broke and they worked. I've tried changing the audio tracks and nothing. I use premier pro to check audio with more than one track. The latest log is attached.
  • 2022-05-31 17-21-29.txt
