Question / Help Odd audio crackling/interference/godknowswhat.
Jamesborg99
Did a test stream with a friend yesterday(day before? can't remember when exactly) to tweak settings and make sure everything was alright. I eventually got my stream looking and sounding like I'd like it to.
Then today, I'm bored and decide I want to stream some Tera to an empty crowd(gotta start somewhere). After I go live, I make sure my stream is looking and sounding like it should and I have this weird crackling sound coming from my mic.
To be clear, this isn't sound I hear from my headset, it only comes across in a broadcast or local recording. I changed no settings from yesterday to today.
http://www.twitch.tv/jamesborg99/b/374295846 a sample of what it sounds like, please turn down your speakers.
Here's a log file, for what it's worth.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU Speed: 3292MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 2: pos={1920, 0}, size={1920, 1080}
Aero is Disabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 460 SE
  Video Adapter Dedicated Video Memory: 1041694720
  Video Adapter Shared System Memory: 3221061632
Adapter 2
  Video Adapter: Intel(R)  HD Graphics Family
  Video Adapter Dedicated Video Memory: 67108864
  Video Adapter Shared System Memory: 1711276032
  Base resolution: 1920x1080
  Output resolution: 1920x1080
Loading up D3D10...
Playback device {0.0.0.00000000}.{b4aebcfc-877b-40b2-b5f1-eb711d153f44}
Using desktop audio input: Realtek HD Audio 2nd output (Realtek High Definition Audio)
Using auxilary audio input: Mic in at front panel (Pink) (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 128
Using Monitor Capture
x264: profile High, level 4.0
Video Encoding: x264
    fps: 30
    width: 1920, height: 1080
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 94, number of frames that lagged: 88 (93.62%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:29.38  size:121858
x264: frame P:15    Avg QP:30.16  size: 22526
x264: frame B:45    Avg QP:35.42  size:  3804
x264: consecutive B-frames:  1.6%  0.0%  0.0% 98.4%
x264: mb I  I16..4: 16.8% 42.1% 41.1%
x264: mb P  I16..4:  0.4%  0.6%  0.3%  P16..4: 15.2%  6.7%  5.4%  0.0%  0.0%    skip:71.4%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  2.9%  1.7%  0.3%  direct: 2.7%  skip:92.3%  L0:27.6% L1:42.3% BI:30.1%
x264: 8x8 transform intra:42.2% inter:20.7%
x264: coded y,uvDC,uvAC intra: 74.2% 49.0% 13.7% inter: 5.0% 1.3% 0.1%
x264: i16 v,h,dc,p: 31% 39% 17% 13%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 28% 19%  3%  6%  4%  4%  5%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 23% 10%  6%  7%  8%  7%  7%  6%
x264: i8c dc,h,v,p: 50% 25% 20%  5%
x264: kb/s:1630.86
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
  Server selection: rtmp://live-mia.justin.tv/app
bufferTime: 1665, outputRateWindowTime: 1000, dropThreshold: 2165
RTMPPublisher::BufferedSend: Socket buffer is full (361943 / 364544 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (361217 / 364544 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (362083 / 364544 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (363286 / 364544 bytes), waiting to send 4097 bytes
Total frames rendered: 10181, number of frames that lagged: 6438 (63.24%) (it's okay for some frames to lag)
Number of b-frames dropped: 76 (0.75%), Number of p-frames dropped: 55 (0.54%), Total 131 (1.3%)
x264: frame I:41    Avg QP:24.03  size:213395
x264: frame P:2606  Avg QP:28.64  size: 23648
x264: frame B:7501  Avg QP:33.19  size:  3825
x264: consecutive B-frames:  1.0%  0.2%  3.3% 95.5%
x264: mb I  I16..4: 12.8% 25.9% 61.4%
x264: mb P  I16..4:  0.4%  0.5%  0.4%  P16..4: 10.7%  6.1%  5.6%  0.0%  0.0%    skip:76.2%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  3.6%  1.7%  0.4%  direct: 2.2%  skip:92.1%  L0:32.7% L1:42.4% BI:24.9%
x264: 8x8 transform intra:30.7% inter:19.0%
x264: coded y,uvDC,uvAC intra: 74.7% 58.2% 25.5% inter: 4.7% 1.1% 0.1%
x264: i16 v,h,dc,p: 35% 44% 12%  8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 23% 22%  3%  6%  5%  4%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 24% 11%  6%  7%  8%  7%  7%  6%
x264: i8c dc,h,v,p: 44% 27% 22%  6%
x264: kb/s:1696.33
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 354, number of frames that lagged: 327 (92.37%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:27.11  size:158004
x264: frame P:81    Avg QP:28.89  size: 25143
x264: frame B:237   Avg QP:33.48  size:  4773
x264: consecutive B-frames:  0.6%  0.0%  2.8% 96.6%
x264: mb I  I16..4: 14.7% 34.9% 50.5%
x264: mb P  I16..4:  0.4%  0.6%  0.5%  P16..4: 12.6%  6.8%  6.0%  0.0%  0.0%    skip:73.1%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  3.4%  1.9%  0.4%  direct: 3.1%  skip:91.1%  L0:30.4% L1:38.2% BI:31.4%
x264: 8x8 transform intra:37.6% inter:18.6%
x264: coded y,uvDC,uvAC intra: 75.6% 56.8% 19.7% inter: 5.4% 1.2% 0.1%
x264: i16 v,h,dc,p: 35% 37% 17% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 25% 21%  3%  5%  5%  4%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 23% 11%  6%  7%  8%  7%  7%  6%
x264: i8c dc,h,v,p: 47% 25% 22%  6%
x264: kb/s:1797.00
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
bufferTime: 1663, outputRateWindowTime: 1000, dropThreshold: 2163
Total frames rendered: 476, number of frames that lagged: 305 (64.08%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:27.58  size:152465
x264: frame P:113   Avg QP:28.91  size: 24750
x264: frame B:326   Avg QP:33.55  size:  4395
x264: consecutive B-frames:  0.5%  0.0%  7.4% 92.1%
x264: mb I  I16..4: 15.2% 36.7% 48.2%
x264: mb P  I16..4:  0.3%  0.5%  0.4%  P16..4: 12.5%  6.7%  5.9%  0.0%  0.0%    skip:73.5%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  3.4%  1.8%  0.4%  direct: 2.8%  skip:91.5%  L0:32.3% L1:39.7% BI:28.0%
x264: 8x8 transform intra:38.6% inter:19.9%
x264: coded y,uvDC,uvAC intra: 77.0% 52.3% 17.6% inter: 5.3% 1.2% 0.1%
x264: i16 v,h,dc,p: 33% 39% 17% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 24% 21%  3%  6%  5%  4%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 22% 12%  6%  7%  8%  7%  7%  6%
x264: i8c dc,h,v,p: 49% 24% 21%  5%
x264: kb/s:1826.89
Loading up D3D10...
Playback device Default
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 351, number of frames that lagged: 323 (92.02%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:28.91  size:127706
x264: frame P:105   Avg QP:29.93  size: 25925
x264: frame B:208   Avg QP:34.35  size:  5259
x264: consecutive B-frames:  1.3% 27.7%  9.4% 61.6%
x264: mb I  I16..4: 15.7% 42.0% 42.2%
x264: mb P  I16..4:  1.6%  3.1%  1.4%  P16..4: 13.6%  6.7%  4.9%  0.0%  0.0%    skip:68.6%
x264: mb B  I16..4:  0.2%  0.3%  0.1%  B16..8:  4.4%  2.3%  0.4%  direct: 2.8%  skip:89.5%  L0:32.1% L1:42.8% BI:25.1%
x264: 8x8 transform intra:49.5% inter:24.3%
x264: coded y,uvDC,uvAC intra: 66.8% 41.7% 10.7% inter: 6.2% 2.1% 0.1%
x264: i16 v,h,dc,p: 40% 34% 16% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 23% 20%  3%  6%  6%  4%  5%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 20% 14%  6%  7%  9%  7%  7%  5%
x264: i8c dc,h,v,p: 56% 20% 20%  4%
x264: kb/s:2106.97
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 160, number of frames that lagged: 1 (0.63%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:27.46  size:115831
x264: frame P:31    Avg QP:30.18  size:  6607
x264: frame B:91    Avg QP:33.14  size:  1174
x264: consecutive B-frames:  0.8%  0.0%  0.0% 99.2%
x264: mb I  I16..4: 50.5% 16.2% 33.3%
x264: mb P  I16..4:  0.5%  0.3%  0.1%  P16..4:  4.7%  2.4%  1.6%  0.0%  0.0%    skip:90.5%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  1.2%  0.4%  0.0%  direct: 1.0%  skip:97.3%  L0:35.2% L1:46.3% BI:18.5%
x264: 8x8 transform intra:18.4% inter:21.8%
x264: coded y,uvDC,uvAC intra: 42.2% 30.2% 14.3% inter: 1.7% 0.2% 0.0%
x264: i16 v,h,dc,p: 67% 27%  3%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 29% 22%  3%  6%  5%  3%  4%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 31% 13%  4%  5%  5%  5%  5%  6%
x264: i8c dc,h,v,p: 63% 20% 14%  2%
x264: kb/s:834.16
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 121, number of frames that lagged: 1 (0.83%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:28.32  size:124589
x264: frame P:21    Avg QP:30.09  size:  6234
x264: frame B:62    Avg QP:33.52  size:   890
x264: consecutive B-frames:  1.2%  0.0%  0.0% 98.8%
x264: mb I  I16..4: 46.2% 18.5% 35.2%
x264: mb P  I16..4:  0.4%  0.2%  0.0%  P16..4:  4.9%  2.5%  1.6%  0.0%  0.0%    skip:90.4%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.9%  0.3%  0.0%  direct: 0.8%  skip:97.9%  L0:39.3% L1:40.3% BI:20.3%
x264: 8x8 transform intra:19.6% inter:20.0%
x264: coded y,uvDC,uvAC intra: 44.8% 33.7% 17.6% inter: 1.4% 0.2% 0.0%
x264: i16 v,h,dc,p: 57% 38%  3%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 36% 20%  2%  5%  4%  3%  4%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 32% 12%  4%  4%  5%  5%  5%  5%
x264: i8c dc,h,v,p: 58% 25% 14%  2%
x264: kb/s:886.98
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 23, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 76, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:27.53  size:145367
x264: frame P:10    Avg QP:25.02  size:   589
x264: frame B:27    Avg QP:30.44  size:    75
x264: consecutive B-frames:  2.4%  0.0%  0.0% 97.6%
x264: mb I  I16..4: 60.8%  5.4% 33.7%
x264: mb P  I16..4:  0.3%  0.0%  0.0%  P16..4:  0.4%  0.0%  0.0%  0.0%  0.0%    skip:99.2%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.0%  skip:99.9%  L0:38.6% L1:61.4% BI: 0.0%
x264: 8x8 transform intra:5.3% inter:5.5%
x264: coded y,uvDC,uvAC intra: 32.3% 34.9% 29.2% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 65% 32%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 45% 24%  1%  2%  1%  1%  0%  3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 28% 18%  3%  3%  4%  4%  4%  5%
x264: i8c dc,h,v,p: 60% 23% 15%  2%
x264: kb/s:968.68
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
Total frames rendered: 328, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:25.53  size:165219
x264: frame P:76    Avg QP:24.41  size:   156
x264: frame B:212   Avg QP:31.64  size:    77
x264: mb I  I16..4: 59.7%  5.5% 34.7%
x264: mb P  I16..4:  0.1%  0.0%  0.0%  P16..4:  0.1%  0.0%  0.0%  0.0%  0.0%    skip:99.8%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%  L0:59.2% L1:40.8% BI: 0.0%
x264: 8x8 transform intra:5.3% inter:8.0%
x264: coded y,uvDC,uvAC intra: 32.3% 35.8% 30.7% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 67% 30%  2%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 51% 22%  1%  2%  2%  1%  1%  3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 28% 18%  4%  3%  4%  4%  4%  5%
x264: i8c dc,h,v,p: 58% 24% 16%  2%
x264: kb/s:296.75
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2723
    buffer size: 2723
    quality: 6
bufferTime: 1680, outputRateWindowTime: 1000, dropThreshold: 2180
Total frames rendered: 1116, number of frames that lagged: 3 (0.27%) (it's okay for some frames to lag)
x264: frame I:5     Avg QP:25.38  size:207854
x264: frame P:272   Avg QP:25.74  size:   179
x264: frame B:801   Avg QP:32.36  size:    74
x264: mb I  I16..4: 49.3%  3.9% 46.7%
x264: mb P  I16..4:  0.0%  0.0%  0.0%  P16..4:  0.2%  0.0%  0.0%  0.0%  0.0%    skip:99.8%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%  L0:52.3% L1:46.4% BI: 1.4%
x264: 8x8 transform intra:3.9% inter:12.2%
x264: coded y,uvDC,uvAC intra: 53.9% 49.9% 44.2% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 73% 19%  6%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 37% 13% 28%  5%  3%  3%  2%  4%  4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 19% 21%  6%  5%  5%  5%  5%  5%
x264: i8c dc,h,v,p: 62% 16% 19%  4%
x264: kb/s:254.99
Profiler results:
frame - [100%] [avg time: 37.602 ms] [avg calls per frame: 1] [children: 98.2%] [unaccounted: 1.8%]
| scene->Preprocess - [56.5%] [avg time: 21.246 ms] [avg calls per frame: 1]
| video encoding and uploading - [41.7%] [avg time: 15.681 ms] [avg calls per frame: 1] [children: 6.74%] [unaccounted: 35%]
| | CopyResource - [0.199%] [avg time: 0.075 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.138%] [avg time: 0.052 ms] [avg calls per frame: 0]
| | call to encoder - [6.37%] [avg time: 2.394 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0346%] [avg time: 0.013 ms] [avg calls per frame: 0]
