Bug Report OBS won't start
Amphor
Here's my log file
Last game capture log:
2015-04-08, 19:04:52: we're booting up:
19:04:52: CaptureThread: attached to process Smite.exe
19:04:52: WARNING: Another hook is already present while trying to hook d3d9.dll, hook target is unknown. If you experience crashes, try disabling the other hooking application
19:04:52: D3D9 Present
19:04:52: D3D9EndScene called
19:04:52: WARNING: Another hook is already present while trying to hook dxgi.dll, hook target is unknown. If you experience crashes, try disabling the other hooking application
19:04:52: WARNING: Another hook is already present while trying to hook dxgi.dll, hook target is \Device\HarddiskVolume1\PROGRA~2\Raptr\ltc_game32-94307.dll. If you experience crashes, try disabling the other hooking application
19:04:52: D3DPRESENT_PARAMETERS {
19:04:52: BackBufferWidth: 1920
19:04:52: BackBufferHeight: 1080
19:04:52: BackBufferFormat: D3DFMT_A8R8G8B8
19:04:52: BackBufferCount: 1
19:04:52: MultiSampleType: D3DMULTISAMPLE_NONE
19:04:52: MultiSampleQuality: 0
19:04:52: SwapEffect: D3DSWAPEFFECT_COPY
19:04:52: hDeviceWindow: 72365619:04:52: DXGI Present
19:04:52: Windowed: true
19:04:52: EnableAutoDepthStencil: false
19:04:52: AutoDepthStencilFormat: D3DFMT_UNKNOWN
19:04:52: Flags: D3DPRESENTFLAG_LOCKABLE_BACKBUFFER
19:04:52: FullScreen_RefreshRateInHz: 0
19:04:52: PresentationInterval: 2147483648
19:04:52: };
19:04:52: WARNING: Another hook is already present while trying to hook d3d9.dll, hook target is \Device\HarddiskVolume1\PROGRA~2\Raptr\ltc_game32-94307.dll. If you experience crashes, try disabling the other hooking application
19:04:52: successfully set up d3d9 hooks
19:04:52: (half life scientist) everything.. seems to be in order
19:05:01: D3D9Present called
19:05:01: DoD3D9GPUHook: success
19:05:01: D3DSURFACE_DESC {
19:05:01: Format: D3DFMT_A8R8G8B8
19:05:01: Type: D3DRTYPE_SURFACE
19:05:01: Usage: D3DUSAGE_RENDERTARGET
19:05:01: Pool: D3DPOOL_DEFAULT
19:05:01: MultiSampleType: D3DMULTISAMPLE_NONE
19:05:01: MultiSampleQuality: 0
19:05:01: Width: 1920
19:05:01: Height: 1080
19:05:01: };
19:05:01: successfully capturing d3d9 frames via GPU
19:05:11: ---------------------- Cleared D3D9 Capture ----------------------
19:05:11: received restart event, capturing
19:05:11: DoD3D9GPUHook: success
19:05:11: D3D9EndScene called
19:05:11: D3D9Present called
19:05:13: D3DSURFACE_DESC {
19:05:13: Format: D3DFMT_A8R8G8B8
19:05:13: Type: D3DRTYPE_SURFACE
19:05:13: Usage: D3DUSAGE_RENDERTARGET
19:05:13: Pool: D3DPOOL_DEFAULT
19:05:13: MultiSampleType: D3DMULTISAMPLE_NONE
19:05:13: MultiSampleQuality: 0
19:05:13: Width: 1920
19:05:13: Height: 1080
19:05:13: };
19:05:13: successfully capturing d3d9 frames via GPU
19:05:17: ---------------------- Cleared D3D9 Capture ----------------------
19:05:17: received restart event, capturing
19:05:17: DoD3D9GPUHook: success
19:05:17: D3D9EndScene called
19:05:17: D3D9Present called
19:06:02: D3DSURFACE_DESC {
19:06:02: Format: D3DFMT_A8R8G8B8
19:06:02: Type: D3DRTYPE_SURFACE
19:06:02: Usage: D3DUSAGE_RENDERTARGET
19:06:02: Pool: D3DPOOL_DEFAULT
19:06:02: MultiSampleType: D3DMULTISAMPLE_NONE
19:06:02: MultiSampleQuality: 0
19:06:02: Width: 1920
19:06:02: Height: 1080a
19:06:02: };
19:06:02: successfully capturing d3d9 frames via GPU
21:28:12: ---------------------- Cleared D3D9 Capture ----------------------
21:28:12: received restart event, capturing
21:28:12: DoD3D9GPUHook: success
21:28:12: D3D9EndScene called
21:28:12: D3D9Present called
23:19:58: D3D9Reset called
23:19:58: ---------------------- Cleared D3D9 Capture ----------------------
23:20:00: WARNING: Another hook is already present while trying to hook d3d9.dll, hook target is \Device\HarddiskVolume1\PROGRA~2\Raptr\ltc_game32-94307.dll. If you experience crashes, try disabling the other hooking application
23:20:00: successfully set up d3d9 hooks
23:20:01: D3D9EndScene called
23:20:01: D3D9Present called
23:20:01: DoD3D9GPUHook: success
03:23:07: ---------------------- Cleared D3D9 Capture ----------------------
03:23:07: D3D9EndScene called
03:23:07: D3D9Present called
From the log file I can see OBS has conflicts with Raptr. But i closed Raptr and all of its processes before starting OBS and it's still telling me that. Is there another problem?
