Question / Help OBS won´t start Streaming
Alex.tNC
Hello guys,
About a Year ago i startet Streaming, but after i bought myself a new GPU (from GTX1050 ti to Radeon RX 580 8Gb)
i get a error message, that i should check my Driver, but i have the current Driver installed.
I tried to reinstall OBS, but the message still apears.
I have attached the log file.
Thanks to everyone that can help me.
  • 2018-12-15 08-02-44.txt
koala
You probably used the nvenc codec to encode your stream previously, which is not present in a AMD card. Go into the output settings of OBS and choose an available codec, which is probably x264 or amd vce.
Alex.tNC
Thanks, it´s solved!
