Bug Report OBS Warframe Crash
NoobMister
I'm not sure if this is linked to OBS or the Warframe client, but I am having an issue with trying to stream the latter.
Whenever I try using the Game Capture option to stream Warframe, either live or just a preview, the game crashes. It doesn't matter which order you try it in, the same thing happens (i.e. Start the stream then tell it to pick up Warframe, or run Warframe first then start the stream and tab back to the game).
It works if I use Window Capture, but the frame rate of the stream drops to unacceptable levels (less than 10/fps). This may be just an issue with me, seeing as I'm streaming from a laptop, but I've streamed Warframe before and don't recall having any issues.
I've included all the log files of the tests I did over this evening, which also include 2 other games I tried (Smite and Garry's Mod) just in case there is an issue.
  • 2015-01-15-1945-54.log
  • 2015-01-15-2058-51.log
  • 2015-01-15-2225-22.log
R1CH
Make sure nothing else is hooking such as FRAPS, Synapse, OSD displays, overclock utils, etc.
NoobMister
Okay, turns out FRAPS was running at the time. It was hiding in the systems tray. I also got this answered by reading another topic with a similar issue.
In order to save yourself answering the same questions R1CH, might I suggest making a pinned topic of commonly known problems and any solutions? Or if there is one like that, might be worth linking to it from this sub forum.
