Hello!
Today I started to experience a strange problem, OBS just wont use my internet.
It will stick at 0 kbps at most of the time and sometimes shoot up to 900 kbps, causing more than 80% of the frames to drop. It was working normally just yesterday, I use 2600kbps CBR.
It will do the same thing when streaming just a still image.
Sorry if this is a known error, I don't seem to find anything to help me about it.
Thanks!
Test made just now:
Last log trying to stream a still image
Thanks!
Test made just now:
18:53:44: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
18:53:44: -------------------------------
18:53:44: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:53:44: CPU Speed: 3500MHz
18:53:44: Physical Memory: 16255MB Total, 12774MB Free
18:53:44: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
18:53:44: monitor 1: pos={0, 0}, size={1920, 1080}
18:53:44: monitor 2: pos={-1280, 0}, size={1280, 1024}
18:53:44: Windows Version: 6.2 Build 9200
18:53:44: Aero is Enabled
18:53:44: OBS Modules:
18:53:44: Base Address Module
18:53:44: 00000000DFBF0000 OBS.exe
18:53:44: 00000000832E0000 OBSApi.dll
18:53:44: 000000008C950000 DShowPlugin.dll
18:53:44: 000000008C8E0000 GraphicsCapture.dll
18:53:44: 0000000090820000 NoiseGate.dll
18:53:44: ------------------------------------------
18:53:44: Adapter 1
18:53:44: Video Adapter: NVIDIA GeForce GTX 670
18:53:44: Video Adapter Dedicated Video Memory: 4200529920
18:53:44: Video Adapter Shared System Memory: 3959023616
18:53:44: Adapter 2
18:53:44: Video Adapter: Intel(R) HD Graphics 4000
18:53:44: Video Adapter Dedicated Video Memory: 33554432
18:53:44: Video Adapter Shared System Memory: 1711276032
18:53:44: =====Stream Start: 2013-06-24, 18:53:44===============================================
18:53:44: Multithreaded optimizations: On
18:53:44: Base resolution: 1280x720
18:53:44: Output resolution: 1280x720
18:53:44: Loading up D3D10...
18:53:44: Playback device {0.0.0.00000000}.{5c6b30a2-2d3c-4bbb-98c7-be36db6a95c0}
18:53:44: Using desktop audio input: Corsair Vengeance (7- Corsair Vengeance 1500)
18:53:44: Using 7.1 surround speaker setup
18:53:44: Using auxilary audio input: Corsair Vengeance (7- Corsair Vengeance 1500)
18:53:44: Audio Encoding: AAC
18:53:44: bitrate: 128
18:53:44: Using bitmap image
18:53:44: Video Encoding: x264
18:53:44: fps: 60
18:53:44: width: 1280, height: 720
18:53:44: preset: veryfast
18:53:44: CBR: yes
18:53:44: CFR: no
18:53:44: max bitrate: 2600
18:53:44: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
18:53:45: Using RTMP service: Twitch / Justin.tv
18:53:45: Server selection: rtmp://live-mia.justin.tv/app
18:53:49: SO_SNDBUF was at 65536
18:53:49: SO_SNDBUF is now 65536
18:54:20: Total frames rendered: 2190, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
18:54:20: okay, this is strange
18:54:20: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:54:20: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
18:54:20: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
18:54:20: Number of times waited to send: 6, Waited for a total of 17186 bytes
18:54:20: Number of b-frames dropped: 741 (41%), Number of p-frames dropped: 746 (41%), Total 1487 (83%)
18:54:20: =====Stream End: 2013-06-24, 18:54:20=================================================
18:54:23:
18:54:23: Profiler results:
18:54:23:
18:54:23: ==============================================================
18:54:23: frame - [100%] [avg time: 1.2 ms] [avg calls per frame: 1] [children: 72.8%] [unaccounted: 27.2%]
18:54:23: | scene->Preprocess - [0.0833%] [avg time: 0.001 ms] [avg calls per frame: 1]
18:54:23: | video encoding and uploading - [72.8%] [avg time: 0.873 ms] [avg calls per frame: 1] [children: 72%] [unaccounted: 0.75%]
18:54:23: | | CopyResource - [1.17%] [avg time: 0.014 ms] [avg calls per frame: 0]
18:54:23: | | conversion to 4:2:0 - [0.167%] [avg time: 0.002 ms] [avg calls per frame: 0]
18:54:23: | | call to encoder - [69.5%] [avg time: 0.834 ms] [avg calls per frame: 0]
18:54:23: | | sending stuff out - [1.17%] [avg time: 0.014 ms] [avg calls per frame: 0]
18:54:23:
