Bug Report OBS-Studio v0.7.1 don't play well with Avermedia Extremecap U3
DEagleson
Seems the fresh build of OBS multiplatform don't play nice with my capture card at all, just eats up memory until the PC starts to hang. It's not a big deal since i can use the stable OBS for capture card streaming but just wanted to let you guys know about it. Regular PC gameplay worked just fine with the limited time i tested using Starbound. (under DirectX mode)
  • 2015-01-06 18-54-40.txt
FxPixel
Hi,same problem on my side (streaming PC) had a big memory leak with my U3 activated in OBS MP (in both 32 &64 bit releases)
The memory leak is not always here when you start OBS.
My gaming PC with a live Gamer HD have no memory leak problem with with the v0.7.1
Thanks for this amazing software to all the guys contributing.
edit: problem seem linked with the fps settings, seem ok if i set the same fps in the video capture device settings and encoding output fps settings.
will try to force the U3 to capture 1080p@30 only and test again
edit2: same problem if fps are caped to 30 in recentral settings
work only if i set the same fps in the video capture device settings and encoding output fps settings.i mean 60PFS
  • 2015-01-06 19-18-38.txt
dodgepong
Administrator
Community Helper
Looks like there is some sort of memory leak for several capture devices. This is being investigated.
