Bug Report OBS Studio not using my Full Upload Speed!
Siebakk
I was using the same settings of my stream for a Year and had no problems that i could't fix.
My Internet speed is 30/6 Mbs
After last weekend my OBS won't stream above 3000 kb/s and often drops to 0 kb/s (I am streaming on twtich with 4500/5000 kb/s with no problem until now)
I tried Multiple Platforms and the problem is still there like restream
I have contacted my provider and they are not seeing any issue on their side. Upload and Download Speed is FINE!
they even boost my internet to 70/70 Mbs and even i get drop bitrate
Both PC have same specs.
i5 8600k
GTX 1070ti
16gb
  • 2020-02-25 14-07-09.txt
Narcogen
Use TwitchTest. Generic speedtest results are not relevant to streaming performance.
17:08:00.547: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 184135 (31.2%)
Narcogen
If the problem is not with your local computer, its networking hardware and drivers, local cabling, router, then it is with your ISP and you should contact them.
Siebakk
ye like i write up i connent with they are not seeing any issue on their side they even boost my internet to 70/70 Mbs and even i get drop bit
