Question / Help OBS Studio constantly crashing
LainS
im havng problems with obs constantly crashing during streams or even starting up, here's last log https://obsproject.com/logs/mic8pe40kky_8-O8
and here's te crash log so i dont really know whats going on, sometimes it works fine and other times just crashes left and right.
  • Crash 2019-01-09 23-36-34.txt
koala
According to the crashlog, you're using Chromacam, which is known to cause crashes. From the crashlog it's not clear what exactly caused the crash, because the call stacks are corrupted, but Chromacam was a crash generator in the past, so it might be that updating or removing that might help.
LainS
lets see what i can find, cause i dont use the chroma cam on obs i'll upload some previous crash logs.
  • Crash 2019-01-06 20-46-01.txt
  • Crash 2019-01-05 01-14-17.txt
  • Crash 2018-12-28 23-45-41.txt
LainS
got another crash in, not sure of its the same type? as i cant read these lol
  • latest-crash-dec-13-19.txt
Suslik V
Yes, it's same thing. It even shorter...
As mentioned above the
"C:\Program Files (x86)\Personify\ChromaCam"
application is need to be removed completely, then try again OBS Studio.
Any changes?
LainS
i removed it already and that crashing is still there so i dnt know what else to remove or try.
LainS
yes no chroma cam on the system at all going to reinstall display drivers and restart and try to stream again
LainS
this is the latest crash bt it had a exception smething abojut obsbrowser page.exe or somethng like that
  • Crash 2019-01-15 12-50-54.txt
  • 2019-01-14 23-04-17.txt
Suslik V
How many memory consumes your Browser sources in the end of the event (from the Windows Task Manager, the exe with the highest memory consumption)?
Suslik V
@extillrey this is general error because of the video driver crash (you may contact manufacturer of the video card for the more info, in case the error constantly reproducible).
