Question / Help OBS Studio Audio Drop Fix
Afgan Rasulov
Hello streamers, I had a problem with Audio Drop on OBS studio. Download attached file to see audio drop example. Because it is more sensetive than OBS Classic sometimes Audio drops happening during record. I have found the solution. This happens because of CPU overload. Here is the solution video. Activate subtitles before watching. I have made an English sub to the videos. Hope it solved your Audio Drop problems.
Video link (Audio drop solution): https://www.youtube.com/watch?v=Evxvb9k11QM
Download Process Lasso ProReal-Time CPU Optimization & Automation: https://bitsum.com/
Cheers,
  • audio drop example.zip
R1CH
I think this has more to do with you running other programs at high priority that are then pre-empting OBS. Your video shows "bridge.exe" consuming lots of CPU at high priority which is likely causing your issues. Besides, if you want to adjust CPU priority, this is available in OBS Studio settings and you do not need 3rd party programs.
