Fenrir
Disclaimer: This is a test build, not a full release. Please ensure you make a backup of your scene collection and profile. This build may contain bugs or broken functionality. For production usage, we still recommend using the latest stable build of OBS. If you are willing to test this build, let us know if you run into any issues.
OBS Studio 32.0 Beta is now available for testing! This release comes with the addition of the long-requested Plugin Manager! Additionally, we now have automated crash log uploads for WIndows and macOS, new Voice Activity Detection and several optimizations for NVIDIA RTX Audio Effects, a chair removal option for NVIDIA RTX Background Removal, and hybrid MOV support. We have also updated our Game Capture hook signature on Windows, which should hopefully correct issues with Riot's games, such as Valorant. See the full list of changes below, and bug fixes at the full release notes.
To enable the beta version, either download from the GitHub link below, or on Windows/macOS go to Settings -> General and change the Update Channel to Betas / Release Candidates
Find the the full patch notes and download links for OBS Studio 32.0 Beta1 here:
For other ways to install the beta:
Please give the build a try and let us know here or in the #beta-testing channel on Discord if you have any issues or feedback. Thanks for your help!
32.0 New Features
- Added a basic plugin manager [FiniteSingularity/PatTheMav/Warchamp7]
- Please note that the current UI is very basic, and we plan to expand this in the coming versions with more features and info for your plugins.
- Added opt-in automatic crash log upload for Windows and macOS [PatTheMav/Warchamp7]
- Added Voice Activity Detection (VAD) to NVIDIA RTX Audio Effects, which improves noise suppression for speech, as well as several optimizations to NVIDIA Effects [pkviet]
- Added chair removal option for NVIDIA RTX Background Removal, allowing removal of chairs [pkviet]
- Added Hybrid MOV support [derrod]
- Brings ProRes support on macOS and HEVC/H.264 and PCM audio support on all platforms
32.0 Changes
- OBS Studio will no longer load plugins built for a newer release of OBS to prevent future compatibility issues [norihiro]
- Added custom OBS widgets in preparation for larger UI updates [derrod/gxalpha/Warchamp7]
- Added preparations for Metal renderer (stay tuned!) [PatTheMav]
- Improved audio deduplication logic to cover more cases of nested scenes, groups, and multiple canvases [pkviet]
- Prevent audio duplication when sources are set to "Monitor and Output" while the monitoring device is also being captured [pkviet]
- Updated the default settings for AMD encoders [rhutsAMD]
- Improved accuracy of chapter markers in Hybrid MP4/MOV [derrod]
- Re-hid the cursor in edit fields on macOS [gxalpha]
- Improved format selection for PipeWire video capture [tytan652]
To access the beta via Steam, right-click the OBS Studio entry in Steam or click the cog icon on the game page, select "Properties...", then navigate to "Betas" and select the "beta" option in the dropdown:
Ubuntu users: You can try the unstable branch with the following commands:
And if you want to remove it:
Bash:
sudo add-apt-repository ppa:obsproject/obs-studio-unstable
sudo apt update
sudo apt install obs-studio
Bash:
sudo add-apt-repository --remove ppa:obsproject/obs-studio-unstable
sudo apt update
sudo apt remove obs-studio
To use the beta version from Flathub, please use the following commands:
Bash:
$ flatpak remote-add --if-not-exists flathub-beta https://flathub.org/beta-repo/flathub-beta.flatpakrepo
$ flatpak install flathub-beta com.obsproject.Studio
