OBS Studio 32.0.2 streaming error
Miguel Rocha
Can´t stream with the latest versions of OBS to a Wowza server (4.8.20+1 version).
If i use OBS 31.0.4 or earlier everything works, from OBS 31.1.0 stream doesn't work.
The streaming url is "rtmps://658209edbc639.streamlock.net:1935/Mike" and streaming key "Mike", no authentication.
From the changelog i can't figure out what can be the culprit.
The log part that's relevant is the following, using OBS 32.0.2:
12:25:54.963: ---------------------------------
12:25:54.963: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: stereo, track: 1
12:25:54.963:
12:25:54.964: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmps://658209edbc639.streamlock.net:1935/Mike...
12:25:54.974: [rtmp stream: 'simple_stream'] Interface: Intel(R) Ethernet Controller (3) I225-LMvP (ethernet, 100↓/100↑ mbps)
12:25:54.994: RTMP_Connect1, TLS_Connect failed: -0x7500
12:25:54.995: [rtmp stream: 'simple_stream'] Connection to rtmps://658209edbc639.streamlock.net:1935/Mike failed: -2
12:25:54.995: ==== Streaming Stop ================================================
Thanks in advance.
Miguel Rocha
Hi, here goes the full log.
14:47:50.752: CPU Name: Intel(R) Core(TM) Ultra 7 165H
14:47:50.753: CPU Speed: 3072MHz
14:47:50.753: Physical Cores: 16, Logical Cores: 22
14:47:50.753: Physical Memory: 32188MB Total, 8052MB Free
14:47:50.753: Windows Version: 10.0 Build 26200 (release: 25H2; revision: 6899; 64-bit)
14:47:50.753: Running as administrator: false
14:47:50.753: Windows 10/11 Gaming Features:
14:47:50.753: Game DVR: On
14:47:50.753: Game Mode: Probably On (no reg key set)
14:47:50.755: Sec. Software Status:
14:47:50.756: Sophos Intercept X: enabled (AV)
14:47:50.757: Antivírus do Microsoft Defender: disabled (AV)
14:47:50.759: Sophos Intercept X: enabled (FW)
14:47:50.759: Firewall do Windows: enabled (FW)
14:47:50.760: Current Date/Time: 2025-10-31, 14:47:50
14:47:50.760: Browser Hardware Acceleration: true
14:47:50.760: Hide OBS windows from screen capture: false
14:47:50.760: Qt Version: 6.8.3 (runtime), 6.8.3 (compiled)
14:47:50.760: Portable mode: false
14:47:51.770: OBS 32.0.2 (64-bit, windows)
14:47:51.770: ---------------------------------
14:47:52.350: ---------------------------------
14:47:52.350: audio settings reset:
14:47:52.350: samples per sec: 48000
14:47:52.350: speakers: 2
14:47:52.350: max buffering: 960 milliseconds
14:47:52.350: buffering type: dynamically increasing
14:47:52.358: ---------------------------------
14:47:52.358: Initializing D3D11...
14:47:52.358: Available Video Adapters:
14:47:52.358: Adapter 0: NVIDIA RTX A500 Laptop GPU
14:47:52.358: Dedicated VRAM: 4157603840 (3.9 GiB)
14:47:52.358: Shared VRAM: 19238531727 (17.9 GiB)
14:47:52.358: PCI ID: 10de:25bb
14:47:52.358: HAGS Status: Enabled (Default: No, Driver status: Supported)
14:47:52.362: Driver Version: 32.0.15.7344
14:47:52.363: output 0:
14:47:52.363: name=
14:47:52.363: pos={0, 0}
14:47:52.363: size={1920, 1200}
14:47:52.363: attached=true
14:47:52.363: refresh=60
14:47:52.363: bits_per_color=8
14:47:52.363: space=RGB_FULL_G22_NONE_P709
14:47:52.363: primaries=[r=(0.639648, 0.330078), g=(0.299805, 0.599609), b=(0.150391, 0.059570), wp=(0.313477, 0.329102)]
14:47:52.363: relative_gamut_area=[709=0.998664, P3=0.736186, 2020=0.528164]
14:47:52.363: sdr_white_nits=80
14:47:52.363: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
14:47:52.363: dpi=120 (125%)
14:47:52.363: id=\\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:47:52.363: alt_id=\\.\DISPLAY1
14:47:52.363: output 1:
14:47:52.363: name=T24i-30
14:47:52.363: pos={1920, 0}
14:47:52.363: size={1920, 1080}
14:47:52.363: primaries=[r=(0.661133, 0.333008), g=(0.300781, 0.614258), b=(0.139648, 0.052734), wp=(0.313477, 0.329102)]
14:47:52.363: relative_gamut_area=[709=1.105152, P3=0.814686, 2020=0.584482]
14:47:52.363: dpi=96 (100%)
14:47:52.363: id=\\?\DISPLAY#LEN63CF#4&321b803d&0&UID8261#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:47:52.363: alt_id=\\.\DISPLAY2
14:47:52.364: output 2:
14:47:52.364: name=T24i-30
14:47:52.364: pos={-1920, 0}
14:47:52.364: size={1920, 1080}
14:47:52.364: attached=true
14:47:52.364: refresh=60
14:47:52.364: bits_per_color=8
14:47:52.364: space=RGB_FULL_G22_NONE_P709
14:47:52.364: primaries=[r=(0.657227, 0.329102), g=(0.303711, 0.615234), b=(0.143555, 0.056641), wp=(0.313477, 0.329102)]
14:47:52.364: relative_gamut_area=[709=1.085665, P3=0.800321, 2020=0.574177]
14:47:52.364: sdr_white_nits=80
14:47:52.364: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
14:47:52.364: dpi=96 (100%)
14:47:52.364: id=\\?\DISPLAY#LEN63CF#4&321b803d&0&UID12613#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:47:52.364: alt_id=\\.\DISPLAY3
14:47:52.364: Adapter 1: Intel(R) Graphics
14:47:52.364: Dedicated VRAM: 134217728 (0.1 GiB)
14:47:52.364: Shared VRAM: 19238531727 (17.9 GiB)
14:47:52.364: PCI ID: 8086:7dd5
14:47:52.364: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
14:47:52.365: Driver Version: 32.0.101.6913
14:47:52.366: Loading up D3D11 on adapter NVIDIA RTX A500 Laptop GPU (0)
14:47:52.524: D3D11 loaded successfully, feature level used: b000
14:47:52.524: DXGI increase maximum frame latency success
14:47:52.524: Hardware-Accelerated GPU Scheduling enabled on adapter!
14:47:52.525: D3D11 GPU priority setup failed (not admin?)
14:47:52.819: ---------------------------------
14:47:52.819: video settings reset:
14:47:52.819: base resolution: 1920x1080
14:47:52.819: output resolution: 1280x720
14:47:52.819: downscale filter: Bicubic
14:47:52.819: fps: 30/1
14:47:52.819: format: NV12
14:47:52.819: YUV mode: Rec. 709/Partial
14:47:52.820: NV12 texture support enabled
14:47:52.820: P010 texture support not available
14:47:52.822: Audio monitoring device:
14:47:52.822: name: Default
14:47:52.822: id: default
14:47:52.834: ---------------------------------
14:47:52.843: No AJA devices found, skipping loading AJA UI plugin
14:47:52.843: Failed to initialize module 'aja-output-ui.dll'
14:47:52.853: No AJA devices found, skipping loading AJA plugin
14:47:52.853: Failed to initialize module 'aja.dll'
14:47:52.854: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
14:47:53.071: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
14:47:53.145: Failed to load 'en-US' text for module: 'decklink-captions.dll'
14:47:53.224: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
14:47:53.302: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
14:47:53.302: Failed to initialize module 'decklink.dll'
14:47:53.488: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
14:47:53.490: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
14:47:53.492: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
14:47:53.496: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
14:47:53.497: Failed to get NVVideoEffects.dll version info size
14:47:53.497: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
14:47:53.576: [obs-browser]: Version 2.26.3
14:47:53.576: [obs-browser]: CEF Version 127.0.6533.120 (runtime), 127.145.7+g2b7d20b+chromium-127.0.6533.120 (compiled)
14:47:54.080: [obs-nvenc] NVENC version: 12.2 (compiled) / 13.0 (driver), CUDA driver version: 12.80, AV1 supported: false
14:48:01.406: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.6.3 | RPC Version: 1)
14:48:01.406: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.8.3 | Qt version (run-time): 6.8.3
14:48:01.406: [obs-websocket] [obs_module_load] Linked ASIO Version: 103200
14:48:01.436: [obs-websocket] [obs_module_load] Module loaded.
14:48:01.485: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
14:48:01.737: ---------------------------------
14:48:01.737: Loaded Modules:
14:48:01.737: win-wasapi.dll
14:48:01.737: win-dshow.dll
14:48:01.737: win-capture.dll
14:48:01.737: vlc-video.dll
14:48:01.737: text-freetype2.dll
14:48:01.737: rtmp-services.dll
14:48:01.737: obs-x264.dll
14:48:01.737: obs-websocket.dll
14:48:01.737: obs-webrtc.dll
14:48:01.737: obs-vst.dll
14:48:01.737: obs-transitions.dll
14:48:01.737: obs-text.dll
14:48:01.737: obs-qsv11.dll
14:48:01.737: obs-outputs.dll
14:48:01.737: obs-nvenc.dll
14:48:01.737: obs-filters.dll
14:48:01.737: obs-ffmpeg.dll
14:48:01.737: obs-browser.dll
14:48:01.737: nv-filters.dll
14:48:01.737: image-source.dll
14:48:01.737: frontend-tools.dll
14:48:01.738: decklink-output-ui.dll
14:48:01.738: decklink-captions.dll
14:48:01.738: coreaudio-encoder.dll
14:48:01.738: ---------------------------------
14:48:01.742: ---------------------------------
14:48:01.742: Available Encoders:
14:48:01.742: Video Encoders:
14:48:01.743: - ffmpeg_svt_av1 (SVT-AV1)
14:48:01.743: - ffmpeg_aom_av1 (AOM AV1)
14:48:01.743: - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
14:48:01.743: - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
14:48:01.743: - obs_qsv11_v2 (QuickSync H.264)
14:48:01.743: - obs_qsv11_av1 (QuickSync AV1)
14:48:01.743: - obs_qsv11_hevc (QuickSync HEVC)
14:48:01.743: - obs_x264 (x264)
14:48:01.743: Audio Encoders:
14:48:01.743: - ffmpeg_aac (FFmpeg AAC)
14:48:01.743: - ffmpeg_opus (FFmpeg Opus)
14:48:01.743: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
14:48:01.743: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
14:48:01.743: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
14:48:01.743: - ffmpeg_alac (FFmpeg ALAC (24-bit))
14:48:01.743: - ffmpeg_flac (FFmpeg FLAC (16-bit))
14:48:01.743: ==== Startup complete ===============================================
14:48:01.910: All scene data cleared
14:48:01.910: ------------------------------------------------
14:48:01.937: [win-wasapi: 'Áudio da área de trabalho'] update settings:
14:48:01.937: device id: default
14:48:01.937: use device timing: 1
14:48:01.939: [Loaded global audio device]: 'Áudio da área de trabalho'
14:48:01.939: [win-wasapi: 'Microfone/Auxiliar'] update settings:
14:48:01.939: device id: default
14:48:01.939: use device timing: 0
14:48:01.940: [Loaded global audio device]: 'Microfone/Auxiliar'
14:48:01.945: [duplicator-monitor-capture: 'Captura do monitor'] update settings:
14:48:01.945: display: (1920x1200)
14:48:01.945: cursor: true
14:48:01.945: method: WGC
14:48:01.945: id: \\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:48:01.945: alt_id: \\.\DISPLAY1
14:48:01.945: setting_id: \\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
14:48:01.945: force SDR: false
14:48:01.949: Switched to scene 'Cena'
14:48:01.949: ------------------------------------------------
14:48:01.949: Loaded scenes:
14:48:01.949: - scene 'Cena':
14:48:01.949: - source: 'Captura do monitor' (monitor_capture)
14:48:01.952: Device for 'Audio Output Capture' source is also used for audio monitoring:
14:48:01.952: Deduplication logic is being applied to all monitored sources.
14:48:01.952:
14:48:02.112: WASAPI: Device 'Altifalantes (USB Audio Device)' [48000 Hz] initialized (source: Áudio da área de trabalho)
14:48:02.567: WASAPI: Device 'Microfone (USB Audio Device)' [48000 Hz] initialized (source: Microfone/Auxiliar)
14:48:02.613: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Microfone/Auxiliar)
14:48:02.613:
14:48:11.928: [obs-nvenc: 'simple_video_stream'] settings:
14:48:11.928: codec: H264
14:48:11.928: rate_control: CBR
14:48:11.928: bitrate: 2500
14:48:11.928: keyint: 250
14:48:11.928: preset: p5
14:48:11.928: tuning: hq
14:48:11.928: multipass: qres
14:48:11.928: profile: high
14:48:11.928: width: 1280
14:48:11.928: height: 720
14:48:11.928: b-frames: 2
14:48:11.928: b-ref-mode: 0
14:48:11.928: lookahead: true (8 frames)
14:48:11.928: aq: true
14:48:11.928:
14:48:12.009: ---------------------------------
14:48:12.010: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: stereo, track: 1
14:48:12.010:
14:48:12.017: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmps://658209edbc639.streamlock.net:1935/Mike...
14:48:12.037: [rtmp stream: 'simple_stream'] Interface: Intel(R) Ethernet Controller (3) I225-LMvP (ethernet, 100↓/100↑ mbps)
14:48:12.068: RTMP_Connect1, TLS_Connect failed: -0x7500
14:48:12.069: [rtmp stream: 'simple_stream'] Connection to rtmps://658209edbc639.streamlock.net:1935/Mike failed: -2
14:48:12.070: ==== Streaming Stop ================================================
R1CH
Your Wowza server is sending too many certificates, generally only the intermediate and end entity certificates are needed.
Certificate chain
 0 s:CN=658209edbc639.streamlock.net
   i:C=GB, ST=Greater Manchester, L=Salford, O=Sectigo Limited, CN=Sectigo RSA Domain Validation Secure Server CA
   a:PKEY: RSA, 2048 (bit); sigalg: sha256WithRSAEncryption
   v:NotBefore: Nov 21 00:00:00 2024 GMT; NotAfter: Dec 18 23:59:59 2025 GMT
 1 s:C=GB, ST=Greater Manchester, L=Salford, O=Sectigo Limited, CN=Sectigo RSA Domain Validation Secure Server CA
   i:C=US, ST=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust RSA Certification Authority
   a:PKEY: RSA, 2048 (bit); sigalg: sha384WithRSAEncryption
   v:NotBefore: Nov  2 00:00:00 2018 GMT; NotAfter: Dec 31 23:59:59 2030 GMT
 2 s:C=US, ST=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust RSA Certification Authority
   i:C=GB, ST=Greater Manchester, L=Salford, O=Comodo CA Limited, CN=AAA Certificate Services
   a:PKEY: RSA, 4096 (bit); sigalg: sha384WithRSAEncryption
   v:NotBefore: Mar 12 00:00:00 2019 GMT; NotAfter: Dec 31 23:59:59 2028 GMT
 3 s:C=GB, ST=Greater Manchester, L=Salford, O=Comodo CA Limited, CN=AAA Certificate Services
   a:PKEY: RSA, 2048 (bit); sigalg: sha1WithRSAEncryption
   v:NotBefore: Jan  1 00:00:00 2004 GMT; NotAfter: Dec 31 23:59:59 2028 GMT
At least on my end, certificates 2 and 3 are already in the trusted root store.
Miguel Rocha
Hi,
Wowza has one certificate file installed, 658209edbc639.streamlock.net.jks, which was provided by them.
It works fine with OBS 31.0.4.
Here is the log of it, from the same machine:
16:53:40.012: CPU Name: Intel(R) Core(TM) Ultra 7 165H
16:53:40.013: CPU Speed: 3072MHz
16:53:40.013: Physical Cores: 16, Logical Cores: 22
16:53:40.013: Physical Memory: 32188MB Total, 7734MB Free
16:53:40.013: Windows Version: 10.0 Build 26200 (release: 25H2; revision: 6899; 64-bit)
16:53:40.013: Running as administrator: false
16:53:40.013: Windows 10/11 Gaming Features:
16:53:40.013: Game DVR: On
16:53:40.013: Game Mode: Probably On (no reg key set)
16:53:40.016: Sec. Software Status:
16:53:40.019: Sophos Intercept X: enabled (AV)
16:53:40.020: Antivírus do Microsoft Defender: disabled (AV)
16:53:40.021: Sophos Intercept X: enabled (FW)
16:53:40.021: Firewall do Windows: enabled (FW)
16:53:40.022: Current Date/Time: 2025-10-31, 16:53:40
16:53:40.022: Browser Hardware Acceleration: true
16:53:40.022: Hide OBS windows from screen capture: false
16:53:40.022: Qt Version: 6.6.3 (runtime), 6.6.3 (compiled)
16:53:40.022: Portable mode: false
16:53:42.812: OBS 31.0.4 (64-bit, windows)
16:53:42.812: ---------------------------------
16:53:44.334: ---------------------------------
16:53:44.334: audio settings reset:
16:53:44.334: samples per sec: 48000
16:53:44.334: speakers: 2
16:53:44.334: max buffering: 960 milliseconds
16:53:44.334: buffering type: dynamically increasing
16:53:44.373: ---------------------------------
16:53:44.374: Initializing D3D11...
16:53:44.374: Available Video Adapters:
16:53:44.375: Adapter 0: NVIDIA RTX A500 Laptop GPU
16:53:44.375: Dedicated VRAM: 4157603840 (3.9 GiB)
16:53:44.375: Shared VRAM: 19238531727 (17.9 GiB)
16:53:44.375: PCI ID: 10de:25bb
16:53:44.375: HAGS Status: Enabled (Default: No, Driver status: Supported)
16:53:44.378: Driver Version: 32.0.15.7344
16:53:44.380: output 0:
16:53:44.380: name=
16:53:44.380: pos={0, 0}
16:53:44.380: size={1920, 1200}
16:53:44.380: attached=true
16:53:44.380: refresh=60
16:53:44.380: bits_per_color=8
16:53:44.380: space=RGB_FULL_G22_NONE_P709
16:53:44.380: primaries=[r=(0.639648, 0.330078), g=(0.299805, 0.599609), b=(0.150391, 0.059570), wp=(0.313477, 0.329102)]
16:53:44.380: relative_gamut_area=[709=0.998664, P3=0.736186, 2020=0.528164]
16:53:44.380: sdr_white_nits=80
16:53:44.380: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
16:53:44.380: dpi=120 (125%)
16:53:44.380: id=\\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
16:53:44.380: alt_id=\\.\DISPLAY1
16:53:44.381: output 1:
16:53:44.381: name=T24i-30
16:53:44.381: pos={1920, 0}
16:53:44.381: size={1920, 1080}
16:53:44.381: attached=true
16:53:44.381: refresh=60
16:53:44.381: bits_per_color=8
16:53:44.381: space=RGB_FULL_G22_NONE_P709
16:53:44.381: primaries=[r=(0.661133, 0.333008), g=(0.300781, 0.614258), b=(0.139648, 0.052734), wp=(0.313477, 0.329102)]
16:53:44.381: relative_gamut_area=[709=1.105152, P3=0.814686, 2020=0.584482]
16:53:44.381: sdr_white_nits=80
16:53:44.381: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
16:53:44.381: dpi=96 (100%)
16:53:44.381: id=\\?\DISPLAY#LEN63CF#4&321b803d&0&UID8261#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
16:53:44.381: alt_id=\\.\DISPLAY2
16:53:44.382: output 2:
16:53:44.382: name=T24i-30
16:53:44.382: pos={-1920, 0}
16:53:44.382: size={1920, 1080}
16:53:44.382: attached=true
16:53:44.382: refresh=60
16:53:44.382: bits_per_color=8
16:53:44.382: space=RGB_FULL_G22_NONE_P709
16:53:44.382: primaries=[r=(0.657227, 0.329102), g=(0.303711, 0.615234), b=(0.143555, 0.056641), wp=(0.313477, 0.329102)]
16:53:44.382: relative_gamut_area=[709=1.085665, P3=0.800321, 2020=0.574177]
16:53:44.382: sdr_white_nits=80
16:53:44.382: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
16:53:44.382: dpi=96 (100%)
16:53:44.382: id=\\?\DISPLAY#LEN63CF#4&321b803d&0&UID12613#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
16:53:44.382: alt_id=\\.\DISPLAY3
16:53:44.382: Adapter 1: Intel(R) Graphics
16:53:44.382: Dedicated VRAM: 134217728 (0.1 GiB)
16:53:44.382: Shared VRAM: 19238531727 (17.9 GiB)
16:53:44.382: PCI ID: 8086:7dd5
16:53:44.382: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
16:53:44.384: Driver Version: 32.0.101.6913
16:53:44.386: Loading up D3D11 on adapter NVIDIA RTX A500 Laptop GPU (0)
16:53:44.720: D3D11 loaded successfully, feature level used: b000
16:53:44.720: DXGI increase maximum frame latency success
16:53:44.720: Hardware-Accelerated GPU Scheduling enabled on adapter!
16:53:44.721: D3D11 GPU priority setup failed (not admin?)
16:53:45.694: ---------------------------------
16:53:45.694: video settings reset:
16:53:45.694: base resolution: 1920x1080
16:53:45.694: output resolution: 1280x720
16:53:45.694: downscale filter: Bicubic
16:53:45.694: fps: 30/1
16:53:45.694: format: NV12
16:53:45.694: YUV mode: Rec. 709/Partial
16:53:45.694: NV12 texture support enabled
16:53:45.695: P010 texture support not available
16:53:45.698: Audio monitoring device:
16:53:45.698: name: Default
16:53:45.698: id: default
16:53:45.718: ---------------------------------
16:53:45.805: No AJA devices found, skipping loading AJA UI plugin
16:53:45.805: Failed to initialize module 'aja-output-ui.dll'
16:53:45.865: No AJA devices found, skipping loading AJA plugin
16:53:45.865: Failed to initialize module 'aja.dll'
16:53:45.868: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
16:53:45.903: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
16:53:45.929: Failed to load 'en-US' text for module: 'decklink-captions.dll'
16:53:45.970: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
16:53:46.018: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
16:53:46.019: Failed to initialize module 'decklink.dll'
16:53:46.174: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
16:53:46.176: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
16:53:46.178: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
16:53:46.210: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
16:53:46.212: Failed to get NVVideoEffects.dll version info size
16:53:46.214: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
16:53:46.729: [obs-browser]: Version 2.24.6
16:53:46.730: [obs-browser]: CEF Version 127.0.6533.120 (runtime), 127.145.7+g2b7d20b+chromium-127.0.6533.120 (compiled)
16:53:48.182: [obs-nvenc] NVENC version: 12.2 (compiled) / 13.0 (driver), CUDA driver version: 12.80, AV1 supported: false
16:53:55.969: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.6 | RPC Version: 1)
16:53:55.969: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.6.3 | Qt version (run-time): 6.6.3
16:53:55.969: [obs-websocket] [obs_module_load] Linked ASIO Version: 103100
16:53:55.969: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
16:53:56.006: [obs-websocket] [obs_module_load] Module loaded.
16:53:56.206: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
16:53:56.443: ---------------------------------
16:53:56.443: Loaded Modules:
16:53:56.444: win-wasapi.dll
16:53:56.444: win-dshow.dll
16:53:56.444: win-capture.dll
16:53:56.444: vlc-video.dll
16:53:56.444: text-freetype2.dll
16:53:56.444: rtmp-services.dll
16:53:56.444: obs-x264.dll
16:53:56.444: obs-websocket.dll
16:53:56.444: obs-webrtc.dll
16:53:56.444: obs-vst.dll
16:53:56.444: obs-transitions.dll
16:53:56.444: obs-text.dll
16:53:56.444: obs-qsv11.dll
16:53:56.444: obs-outputs.dll
16:53:56.444: obs-nvenc.dll
16:53:56.444: obs-filters.dll
16:53:56.444: obs-ffmpeg.dll
16:53:56.444: obs-browser.dll
16:53:56.444: nv-filters.dll
16:53:56.444: image-source.dll
16:53:56.444: frontend-tools.dll
16:53:56.444: decklink-output-ui.dll
16:53:56.444: decklink-captions.dll
16:53:56.444: coreaudio-encoder.dll
16:53:56.444: ---------------------------------
16:53:56.445: ---------------------------------
16:53:56.445: Available Encoders:
16:53:56.445: Video Encoders:
16:53:56.445: - ffmpeg_svt_av1 (SVT-AV1)
16:53:56.445: - ffmpeg_aom_av1 (AOM AV1)
16:53:56.445: - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
16:53:56.445: - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
16:53:56.445: - obs_qsv11_v2 (QuickSync H.264)
16:53:56.445: - obs_qsv11_av1 (QuickSync AV1)
16:53:56.445: - obs_qsv11_hevc (QuickSync HEVC)
16:53:56.445: - obs_x264 (x264)
16:53:56.445: Audio Encoders:
16:53:56.445: - ffmpeg_aac (FFmpeg AAC)
16:53:56.445: - ffmpeg_opus (FFmpeg Opus)
16:53:56.445: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
16:53:56.445: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
16:53:56.445: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
16:53:56.445: - ffmpeg_alac (FFmpeg ALAC (24-bit))
16:53:56.445: - ffmpeg_flac (FFmpeg FLAC (16-bit))
16:53:56.445: ==== Startup complete ===============================================
16:53:56.753: All scene data cleared
16:53:56.753: ------------------------------------------------
16:53:56.794: [win-wasapi: 'Áudio da área de trabalho'] update settings:
16:53:56.794: device id: default
16:53:56.794: use device timing: 1
16:53:56.795: [Loaded global audio device]: 'Áudio da área de trabalho'
16:53:56.795: [win-wasapi: 'Microfone/Auxiliar'] update settings:
16:53:56.795: device id: default
16:53:56.795: use device timing: 0
16:53:56.796: [Loaded global audio device]: 'Microfone/Auxiliar'
16:53:56.801: [duplicator-monitor-capture: 'Captura do monitor'] update settings:
16:53:56.801: display: (1920x1200)
16:53:56.801: cursor: true
16:53:56.801: method: WGC
16:53:56.801: id: \\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
16:53:56.801: alt_id: \\.\DISPLAY1
16:53:56.801: setting_id: \\?\DISPLAY#BOE0BFB#4&321b803d&0&UID8388688#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
16:53:56.801: force SDR: false
16:53:56.805: Switched to scene 'Cena'
16:53:56.805: ------------------------------------------------
16:53:56.805: Loaded scenes:
16:53:56.805: - scene 'Cena':
16:53:56.805: - source: 'Captura do monitor' (monitor_capture)
16:53:57.122: WASAPI: Device 'Altifalantes (USB Audio Device)' [48000 Hz] initialized (source: Áudio da área de trabalho)
16:53:57.542: WASAPI: Device 'Microfone (USB Audio Device)' [48000 Hz] initialized (source: Microfone/Auxiliar)
16:53:57.605: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Microfone/Auxiliar)
16:53:57.605:
16:54:05.896: OpenType support missing for "Open Sans", script 11
16:54:05.897: OpenType support missing for "Arial", script 11
16:54:05.898: OpenType support missing for "Tahoma", script 11
16:54:05.903: OpenType support missing for "MS UI Gothic", script 11
16:54:05.904: OpenType support missing for "SimSun", script 11
16:54:05.909: OpenType support missing for "Segoe UI Emoji", script 11
16:54:05.910: OpenType support missing for "Segoe UI Symbol", script 11
16:54:05.915: OpenType support missing for "Open Sans", script 12
16:54:05.916: OpenType support missing for "Arial", script 12
16:54:05.916: OpenType support missing for "Tahoma", script 12
16:54:05.917: OpenType support missing for "MS UI Gothic", script 12
16:54:05.919: OpenType support missing for "SimSun", script 12
16:54:05.920: OpenType support missing for "Segoe UI Emoji", script 12
16:54:05.922: OpenType support missing for "Segoe UI Symbol", script 12
16:54:05.922: OpenType support missing for "Open Sans", script 20
16:54:05.922: OpenType support missing for "Arial", script 20
16:54:05.923: OpenType support missing for "Tahoma", script 20
16:54:05.925: OpenType support missing for "MS UI Gothic", script 20
16:54:05.926: OpenType support missing for "SimSun", script 20
16:54:05.927: OpenType support missing for "Segoe UI Emoji", script 20
16:54:05.928: OpenType support missing for "Segoe UI Symbol", script 20
16:54:12.362: [obs-nvenc: 'simple_video_stream'] settings:
16:54:12.362: codec: H264
16:54:12.362: rate_control: CBR
16:54:12.362: bitrate: 2500
16:54:12.362: keyint: 250
16:54:12.362: preset: p5
16:54:12.362: tuning: hq
16:54:12.362: multipass: qres
16:54:12.362: profile: high
16:54:12.362: width: 1280
16:54:12.362: height: 720
16:54:12.362: b-frames: 2
16:54:12.362: b-ref-mode: 0
16:54:12.362: lookahead: true (8 frames)
16:54:12.362: aq: true
16:54:12.362:
16:54:12.420: ---------------------------------
16:54:12.421: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: stereo, track: 1
16:54:12.421:
16:54:12.422: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmps://658209edbc639.streamlock.net:1935/Mike...
16:54:12.440: [rtmp stream: 'simple_stream'] Interface: Intel(R) Ethernet Controller (3) I225-LMvP (ethernet, 100↓/100↑ mbps)
16:54:12.913: [rtmp stream: 'simple_stream'] Connection to rtmps://658209edbc639.streamlock.net:1935/Mike (94.46.171.131) successful
16:54:12.914: [rtmp stream: 'simple_stream'] Socket send buffer is 65536 bytes
16:54:12.927: ==== Streaming Start ===============================================
16:54:18.834: [rtmp stream: 'simple_stream'] User stopped the stream
16:54:18.834: [rtmp stream: 'simple_stream'] Socket send buffer is 65536 bytes
16:54:18.834: Output 'simple_stream': stopping
16:54:18.834: Output 'simple_stream': Total frames output: 161
16:54:18.834: Output 'simple_stream': Total drawn frames: 192
16:54:18.843: ==== Streaming Stop ================================================
Miguel Rocha
Hi,
I don't mind using OBS 31.0.4 or other softwares, for me this is not a problem.
I'm just informing that something is different between OBS 31.0.4 and more recent versions which is creating a problem.
Consider this a bug report, for lack of a better word.
Thanks.
R1CH
The bug is triggered by your Wowza server not accepting modern TLS key exchanges and forcing a fallback, that should be fixed for security regardless if old versions work.
