OBS settings Greyed Out
BiopticPsyrus
So I want to change what format OBS is recording in but the option is greyed out.
Did some prior research and no sources are active that wouldn't be on first OBS opening. Nothing is streaming or Recording I have no clue what an NDI is but looked it up and nothing like that either.
Have attached log and SS so you can see what I see.
Any help would be great as I am losing my wits.
  • 2023-10-10 18-15-58.txt
Suslik V
Try to make a small script that writes info to OBS log-file about active outputs (it may give you a clue what output is active in your setup):
