BlockAboots
I have read through the guide for OSB for optimal settings for streaming but the guide is from a few versions back now and a few things have been altered and extra options added so i was wondering if there was a guide for what these new settings show be set at? I have attached my log from the last stream i did.
For example, should CBR option be used in Encoding settings, should a 'Scene Buffering Time' and 'Use CFR' be set in Advanced Settings? I have also noticed a get a message saying, 'The Colour Scheme has changed to Windows Basic' when i start up OBS??
This is my connection speed:
Im running an i7 @4Ghz and 6GB of RAM on Windows 7 64-Bit
These are my current settings:
http://minus.com/lXWwgsmdZCQ1c
