Question / Help OBS recordings are laggy
ezelbanaan
Hello
i started obs today adn i wanted to record a video but then when i was editing it it was laggy/stuttering could someone please help me set obs up right to record Rainbow Six Siege
Greets Bastiaan
  • 2018-12-27 17-37-32.txt
Narcogen
You are significantly overloading both your renderer and your encoder:
18:48:24.263: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 2222 (34.7%)
18:48:24.264: ==== Recording Stop ================================================
18:48:26.540: Video stopped, number of skipped frames due to encoding lag: 3301/3394 (97.3%)
1080p60 while capturing a high motion application on a single machine setup can be challenging.
The rendering lag indicates you need to reduce GPU usage of R6 by some method to make sure that GPU utilization stays between 90-95% so that OBS has access in order to render frames. One out of 3 frames is being dropped because when OBS tries to render a frame, it cannot access the GPU, so the encoder get a duplicate frames until the GPU can render a new one. This appears as stutter, and 34% is very, very noticeable. The easiest and fastest way of doing this is capping the in-game framerate. Next best ways are choosing to stream either 1080p30 or 720p60 instead of 1080p60.
You are also overloading your encoder. I'm not familiar with the AMF encoder or its settings, but 97% skipped frames indicating that you are asking it to do significantly more than it is capable of, or that there is a significant problem with your GPU's operation.
ezelbanaan
well i put my settings in r6 all the way down to low and i tried recording 720p60 and it was still stuttering and i am also not familiar with amd encoders so thats why i came here for help
Narcogen
Please provide a log of a session recording at 720p60 so we can see how much the lag has been reduced by and suggest different encoder settings.
